Can I drill a hole in a stuck battery?
48 posts / 0 new
DMS1970
Last seen: 4 months 4 days ago
I have a zebra light sc600ii with an lg 18650 stick in in. Happened before but was able to shake it out. No luck this time. I cut the wrapper and folded it up in sections and tried pulling the battery out with a pair of pliers. All the pieces broke off. The cell is fully charged and if I screw the cap on the light does not come on. This light has the pins on the cap not a spring and I think the cell is too long for this light
Any help appreciated
xxo
Last seen: 56 min 57 sec ago
Don’t drill it! Very dangerous.
You might try a really strong magnet to help coax it out.
NeutralFan
NeutralFan's picture
Last seen: 1 day 20 hours ago
Not a good situation! Is the battery a button top? I would not drill a hole in the battery if you can avoid it. Have you tried to put the flashlight in the freezer for awhile and then try to shake it out? Or maybe put some silicone between the battery and the flashlight tube?
I’d rather use my flashlight around the house than turn on the lights.
Zappaman
Zappaman's picture
Yes, you CAN drill a hole.. right up ‘til the explosion occurs Big Smile
ZappaMan
kennybobby
kennybobby's picture
Last seen: 1 hour 17 min ago
Turn ON the light to drain the cell first, then it will be safe to drill a small hole and use a slide hammer with a screw attachment to yank that thang out of there.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
nobody
Last seen: 1 min 13 sec ago
Sorry to hear this.  The freezer idea sounds like it might work.  Hope you get it out.  If you do, I would advise not putting that brand cell in the light again.
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 day 17 hours ago
Take a video when you do it Glasses Evil LOL
Juslearnin
Last seen: 1 hour 13 min ago
I would use epoxy or jb weld to glue something like a wooden dowel to it and then try to pull it out.
Pip
Last seen: 3 hours 29 sec ago
Find a way to attach a paracord or some heavy string on the other end a swing it in circles really hard to centrifuge it out.
jon_slider
jon_slider's picture
Last seen: 8 min 40 sec ago
> Happened before
stop doing that! Facepalm
post a video on youtube, and send zebralight the link
ask zebralight whether they want you to send them the light
of if they want to just ship you something else in stock, based on the video alone
hurry
they might be going out of business Cash
DMS1970
Some good, and maybe not so good suggestions, thanks! I think I’ll try the jb weld first
cohoer
Last seen: 30 min 19 sec ago
The freezer idea sounds good.
Robin Dobbie
Last seen: 35 min 5 sec ago
Make sure it’s clean and everything before you jbweld. Or if you know someone with a tack welder, you could just tack a bundle of nickel strips in there to pull on.
Frostcream
Last seen: 2 weeks 5 days ago
Definitely epoxy and a popsicle stick.
SIGShooter
SIGShooter's picture
Last seen: 1 hour 5 min ago
I think I would try making a loop at one end of some 12/14 gauge wire and solder it to the top of the battery, and then try to pull the battery out that way.
Scallywag
Scallywag's picture
Last seen: 55 min 59 sec ago
Biggest issue here is going to be that he’s only got access to the bottom of the battery because the light is a unibody design. I agree with the epoxy ideas. Maybe freezer and epoxy. I’d see if you can drain the cell by connecting the negative end to the body of the light and leaving it on, just in case anything unfortunate happens.
If this ever happens with alkalines, though, feel free. It’s a bit messy but there’s no fire danger.
ImagioX1
Last seen: 1 hour 41 min ago
Yeah combination of freezer and epoxy sounds like the best idea. Good luck.
Robin Dobbie
Soldering could work if the iron tip was blunted with enough solder dangling at the tip to transfer heat to the battery terminal quickly. You wouldn’t want to be waiting around heating up the whole cell.
Soldering to cells isn’t a great idea, but to quote diode gone wild, “it’s not the best idea, but it works”
The key is a powerful iron and getting it done quickly.
Unheard
Unheard's picture
Last seen: 1 hour 52 min ago
Will the battery shrink more than the tube in the freezer? Why?
Smile, you cannot kill them all.
SIGShooter
Hummm super glue ads state that 9 drops will bond enough to lift a 5 ton car. So maybe give that a try?
Scallywag
Scallywag's picture
Yeah but probably not bonding to metal.
Oh for bonus points, scratching the metal a bit with something (sandpaper, but idk if you can get to it easily?) should help with adhesion.
bansuri
Last seen: 13 hours 25 min ago
I have successfully removed stuck batteries by taping the light to the end of a broomstick perpendicularly to the the broomstick and slamming the stick against a table or something. The broomstick and light come to a stop but the battery keeps going.
Marc E
Last seen: 1 week 5 days ago
Watch this from 1:45 for a couple of seconds: https://www.youtube.com/watch?v=WnZuMfq6kec
Be aware there is swearing so sound down if that’s an issue.
nobody
Yup — whatever you try, don’t drill a hole in the battery!
MoreLumens
MoreLumens's picture
Last seen: 17 min 44 sec ago
LOL
Katherine Alicia
Katherine Alicia's picture
Last seen: 8 months 1 week ago
Freezing will shrink the alu tube and hold the battery even tighter, it will shrink 3x for every 2x of the steel battery.
ImagioX1
Maybe carefully heat it then? I would assume it should expand 3x for every 2x also correct?
alpg88
Last seen: 3 weeks 1 day ago
al gets hot lot faster than steel, so the AL tube will expand sooner than steel battery will. but i still would not do it, temp needed to expand the tube enough will heat the battery above safe temp.
alpg88
put a bit of wd40 between the cell and tube walls, let it sit, then swing it hard, as you would mercury thermometer, it may get the cell out.
Henk4U2
Henk4U2's picture
Last seen: 4 hours 18 min ago
Maybe best of both worlds. Leaving it a night in the freezer. And then holding it in your hand.
In bare hands is perhaps a bit too much, in that case I would suggest a pre-heated oven mitten.
Assuming that the alu on the outside will get warm faster than (the cold core of) the battery.
Tapping from time to time. On a piece of wood, if the battery does not protrude from the body.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
alpg88
is it a protected cell with a pcb on the negative side? if so solder something to the negative end, and pull on it, even if it s not protected, solder anyway, it’ll destroy the cell, most likely but it’ll be out
