I purchased an FW21 pro from nealsgadgets but 8 days after it arrived it stopped working. I’ve checked the tail switch for and even tried other batteries with no success. Nealsgadgets still has not responded after 3 days so I might be stuck repairing it if I want it to work and the search feature on this page just kept throwing me to google, so my apologies if there is a post on repairing one of these already.
So far I have checked:
21700 battery sitting at 4.1 v. even used an 18650 in the included sleeve that works fine in my gt mini
switch has continuity.
No success. Tried all manner of tightening and no dice I also checked continuity of the copper rings in the head, and the tail as well as through the barrel and theyre fine. whatever it is it’s in the pcb in the head and I can’t figure out how to take it apart because the lens cap seems stuck.
New products regardless of where they are purchased have an implied warranty. You credit card or paypal will side with you every time. All you have to do is show them the emails you sent the seller and the lack of a response.
I’ve heard removing the front bezel or something up front causing the LEDs to accidentally dedome at time so be cautious and I’d recommend doing a bit more research on how to do it.
The main LED board right? Take it out and verify that it’s fully flat. You might have to do some sanding if it’s not. Then put it back with a healthy dose of thermal paste. This along with setting your temperature limit lower on anduril might help.
