Test/review of Keeppower 16340 850mAh P1634C2 (Black) 2020
1 post / 0 new
HKJ
HKJ's picture
Last seen: 2 days 18 hours ago
DSC_4115
Official specifications:
  • Voltage: 3.70V
  • Rated capacity: 850mAh
  • Minimum Capacity: 800mAh
  • Discharge cut-off voltage: 2.50V
  • Charge voltage: 4.20V +/- 0.05V
  • Standard charge current: 500mA
  • Maximum constant discharge current: 3A
Keeppower%2016340%20850mAh%20P1634C2%20(Black)%202020-info
Protected LiIon 16340 batteries from Keeppower.
DSC_4113 DSC_4114
DSC_4116 DSC_4117
DSC_4118
DSC_4119
Keeppower%2016340%20850mAh%20P1634C2%20(Black)%202020-Capacity
The two cells do not match perfectly, but being a protected cell it do not prevent using them in series.
Keeppower%2016340%20850mAh%20P1634C2%20(Black)%202020-Temp-2.0
Keeppower%2016340%20850mAh%20P1634C2%20(Black)%202020-Temp-3.0
Keeppower%2016340%20850mAh%20P1634C2%20(Black)%202020-CapacityTimeHours
Keeppower%2016340%20850mAh%20P1634C2%20(Black)%202020-Energy
Keeppower%2016340%20850mAh%20P1634C2%20(Black)%202020-PowerLoadTime
Keeppower%2016340%20850mAh%20P1634C2%20(Black)%202020-TripCurrent
Keeppower%2016340%20850mAh%20P1634C2%20(Black)%202020-Charge
Discharge-Keeppower%2016340%20850mAh%20P1634C2%20%28Black%29%202020-pulse-0.5%2010%2010-IR
Conclusion
The battery has good capacity for its size and protected makes it safe to use in series configurations, but as usually for protected cells it is a bit longer than a standard cell.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
