i’m in the hobby since 2012 and i saw the new leds generations over the years XML, XML2 and now XML3
i’m a big fan of the MT G2 and XHP leds with high output opening the field of the 10k+ lights
But i’m also very disapointed with all the marketing. Now all the lights are 5000 or 9000lm on turbo for 15sec hahahah so useless
So i have watched all the reviews from ZEROAIR and 1LUMEN with the so helpful runtime graphs !!! these 2 guys are really helpful and their reviews very interesting and professional. thanks guys
My need for everyday use is a mid size light 100-180mm length and 40mm head max size
I love the sofirn IF25A form factor but can’t sustain 1200lm and my HAIKELITE SC26 can sustain 1200lm with my so loved MT G2
Every single review of the new 21700 lights are disapointing because lights can’t sustain 2000lm for 10 to 20min
Ok i understand that heat management is related to the head size directly and design (fins for heat dissipation) so the mid size will throttle the output sustainable power
So is there any light with 2000lm output for 10+min time???
The convoy M3 isn’t that bad with 3000lm for 2min and 1400 for 40min
The convoy 4X18 with the sodacan form factor is not really better (nor the Q8 flashlight)
The convoy M21B can sustain 1600lm for 20min !!! not bad
All the astrolux are useless…ok in the midsize i mean
Do you have any better ideas ?
I’ll try a mod of a M1 convoy host + SST40 or XHP50.2 with the head design i hope to get some decent ouptup
There aren’t many single cell lights lights that can sustain 2000Lm for a long time.
Even the Q8 can’t maintain that, unless you disable thermal stepdown.
Without thermal stepdown it will get burning hot
Found this. It has a fair amount of cooling fins and should do about 2500lm but don’t know for how long.
Also, the NSX3 and NSX4 which should do over 2000lm for 10mins but are also very floody so keep that in mind. The temperature limit is set to 50°C which I guess is designed to prevent your hand from burning but also will limit the output if not kept cool.
Not sure if the FT03 is in the right size category but yh I’ve run it for 10 minutes. Can go longer but will get hot. If you’re outside which you probably will be with a throwy light, then continuous turbo shouldn’t be a problem…I think so anyway.
The zeroair review does not give the same results?! It can’t even sustain the high mode with standard thermal settings…
Well it is do big for my purpose 70mm head…
Now that some of the MF01 Mini’s are coming with a brass plate from the factory, I bet it could do 2000 lm for 10 minutes. Here’s my testing with our custom copper plate before the manufacturer picked up on it:
If it can do 3500 for 4 minutes, I bet 2000 for 10 is within reason.
Yeah, I’ve learned to do thermal calibration as soon as I pull any Anduril light out of the box. Hopefully that won’t be necessary for much longer. I’m working with Sofirn to get them to use the new AVR 1-Series which has an accurate factory-calibrated thermal sensor.
I just put together 6 flashlights using a 1-Series and D4 V2 UI. No calibration done. After leaving them all sit on my table for a while, I picked them all up and did a temp check. Every one of them read 21°C. I think ambient temp was 20-21°C.
the convoy M3 will probably do it, it has the Mass needed and will do your 2000lm for 10 mins (level 3) with some warming but nothing dangerous.
It`s a real workhorse.
