Is this small dent ok?
12 posts / 0 new
Goatlvl
Hi
I received a pair of 30Q and noticed a small dent while charging it for Cap Test. I think it is OK but this is my first purchase of Li-ion cells (the one I have came with flashlight) so I am afraid I misjudge. What do you think about this?
edited : correcting picture codes
Edited by: Goatlvl on 01/17/2021 - 22:10
Mark M
Mark M's picture
Last seen: 9 hours 42 min ago
I would not hesitate to run that battery one bit. I have dented batteries FAR worse than that and ran them. Big Smile
raccoon city
raccoon city's picture
Last seen: 50 min 24 sec ago
The dent looks very small.
I wouldn't worry about it.
Goatlvl
Thanks. I will confirm the order receiving now. This one actually has a less resistance than the other cell (according to my the S4+ charger).
FlashPilot
FlashPilot's picture
Last seen: 2 hours 20 min ago
If it were mine, I’d probably restrict its use to single cell flashlights and be wary of it. Having said that, a small dent, especially near the anode or cathode (which your has) can lead to failure. The 30Q was designed as a high discharge cell and could potentially change your life forever if mistreated.
Unheard
Unheard's picture
Last seen: 41 min 26 sec ago
A survey will gain no knowledge about the condition of your battery.
Smile, you cannot kill them all.
Agro
Agro's picture
Last seen: 7 hours 1 min ago
I would use it but be careful about it. But note that I’m not a battery expert.
Dalamar
Last seen: 17 hours 21 min ago
I’ve seen Samsung’s battery defect testing method, and that’s hardly even a dent compared to what they did to them.
If in doubt throw it out, as they say…
I’ve manhandled some pretty badly trying to reclaim a pack, they were fine but I tossed them because I don’t have a way to cleanly remove tabs, they were unusable in some lights because of the tab/solder remnant.
I only like high CRI. Collection:
Fireflies NOV-MU 21 4500k E21A
Fireflies ROT66 219B SW45 D220
Fireflies E07 Copper 219B SW45k? (odd/higher lumen bin with lower r9 and higher cct?)
Fireflies E07 219B SW45k
Fireflies E07x Pro sst20 FA4 4000k
Varmint removal:
Convoy M21A C8 ver SST20 4000k (5a)
Convoy S2+ SST20 4000k  FB4 (3200ma)
Memes:
BLF GT94
Emisar D18 660nm SST20
CRI test dump https://drive.google.com/drive/folders/1kcl_uOhgfpR4RSsa8F4b-UUVP9mkL6Cr...
Agro
Agro's picture
I tear tabs away with pliers and then file the solder until it’s flat enough.
Yokiamy
Yokiamy's picture
Last seen: 8 hours 34 min ago
i have cells damaged more than that. This looks brand new to me
Goatlvl
Thanks for all comments. I have used it in single-cell flashlight now. No problem but I will be careful and monitoring it.
FlashPilot
Best answer.
