ELECTROPHORUS - My new Lamp
25 posts / 0 new
Barou
Barou's picture
Last seen: 1 day 14 hours ago
Hello guys,
I want to present my new Lamp design here,
After a decade involved in antique Lantern collection, restoration, and electrification, i proudly present you my new Lamp design.
The one that marries the past and contemporary technology with a steampunk twist. It took me like 2 years of painstaking experimentation, design and development, refinements and improvements (with a lot more room to improve or further develop). I present you my Electrophorus thermo-lamps / Electrical generators.
I developed 3 parallel models with variations
E001 – photos – https://photos.app.goo.gl/jm9vSFGrHDVh3aun6
E002 – photos – https://photos.app.goo.gl/eYNhgX3J8dsHcq529
E003 – photos – https://photos.app.goo.gl/qpHZXpf5enPxBQ7M7 Videos:
E002 presentation – video- https://youtu.be/BjtWoN1rnWQ ,
E002 – Operation – video – https://youtu.be/qCtQchNKTqA
+Specs +
Weight: 2150 – 2400 grms (metric)
Height: around 45 cm Tank capacity: around 300 gr kerosene
Optimum working condition : E002 – around 4 watts TEG, E003 – 5 watts TEG output Useful output: E002 – 2.8 watts , E003 – 3.7 watts
Light output: Around 400 lumens for E002, 500 Lumens for E003, no glaring, evenly distributed, warm white pleasing light Custom made led bulbs, with 160 l/w leds efficacy, mount on heatpipes that always run at almost ambient temp (max brightness)
Generator Output
Electrical output: female USB port, give or take 400mA at 5V Kerosene consumption: around 16-18 gr / hour (optimum flame setting for given power output)
Lamp Features
Regulated burner airflow for optimum flame performance One tank lasts around 15 hours at full power
No excessively hot areas. Not a spot anywhere in the lantern exceeds 250 degrees Celsius Noise: less than 28 db
Start-up time: Around 2 minutes, full power around 5min
video of start-up pending
Comments are welcomed and desired.
Cheers,
Barou
Edited by: Barou on 01/18/2021 - 12:06
Barou
Barou's picture
Excuse the links, but i have not figured out yet how to embed photos, links, videos
Cheers,
Barou
EasyB
Last seen: 2 hours 1 min ago
Cool. I think you did a nice job with the steampunk look and function. What exactly is the dial showing? Voltage or current?
Have you thought about using a Stirling engine?
Barou
Barou's picture
Thanks for the credits EasyB,
The dial, or the Gauge as i call it, shows, in an analog mode the power output of the Peltier element.
Voltage / watts. This lamp bears a circuitry that dynamically matches impedance so its a power output indicator. A functional one.
Stirling Engine – Lamp?
It is quite away from my knowledge fields of lamp making / upcycling.
Besides who would want a humming vibrating lamp in his living room with rattling cogs ? Silly
Cheers,
Barou
JamesB
Last seen: 1 week 6 days ago
Here is Barou’s awesome lantern
Mark M
Mark M's picture
Last seen: 1 day 10 hours ago
I am thoroughly amazed. Big Smile They are beauties and I can’t believe they are functional, nice! Your videos are simply awesome, very well done. The E001 is my favorite.
thijsco19
Last seen: 3 days 10 hours ago
Wow! This is the next level!
They look real great.
CR888
Last seen: 5 days 8 hours ago
Really interesting lamp, hard to take your eyes off it once you look at it. Really clever concept.
CR888
djozz
djozz's picture
Last seen: 7 hours 22 min ago
Love love it!
raccoon city
raccoon city's picture
Last seen: 46 min 57 sec ago
There is a link in my signature on how to post pics on BLF.
FlashPilot
FlashPilot's picture
Last seen: 4 hours 52 min ago
Such creativity! It looks great!
iamlucky13
Last seen: 2 hours 2 min ago
That is awesome. Very creative, and well executed.
At first I thought it was just quirky, in a charming steampunk sort of way, to have light bulbs hanging off the side of a kerosene lantern. Then I realized there were heat pipes in the middle and figured out what was going on before reading the text.
Are they dimmable?
Are you just using a couple TEG’s in series to get an appropriate voltage to run the LED’s and/or regulate down to USB voltage, or is there a boost circuit in there? Are the electronics off the shelf or custom? I ask in part because I have a few TEG projects in mind to tinker with and am interested to know what worked well for you.
Thanks for sharing this project.
CNCman
CNCman's picture
Last seen: 3 hours 10 min ago
Welcome to BLF Barou Smile
Very nice Lantern. Does it use more than 1 Peltier ?:BEER:
I will bet you have taken it apart a time or two. It is definitely a keeper. Cool
raccoon city
I hope you have fun here, Barou!
118_milla
Barou
Barou's picture
Thanks guys for your kind words.
I intend to build a blog with a full technical description of those Thermo-lanterns.
A patent is already filed, so there is no reason to hold anything back.
My goal is to give it a shot for fundraising at Kickstarter. (either for making steampunk thermo-lanterns as those depicted, but more refined i guess or to go mainstream and develop cheaper thermo-lanterns in greater production like an alternative to mantle lanterns for general use or indoor use)
Their advantage is less power consumption almost 1/3 of fuel for equal luminosity (for current efficiencies) , not very hot spots on that lamps, low glare, subtleness
Their disadvantage obviously is their complexity.
Time will tell.
Just to answer the curious ones, it employs just one 40×40mm TEG element (Peltier) by II-VI Marlow.
Steampunk is only for the looks. It is a really functional piece as already told.
No, the light is not electronically dimmable. It is analogic dimmable Smile by just turning the flame down. It takes a bit to do so due to thermal inertia, but who is in a hurry?
Those lamps have been made so as to be also power generators( 4 watts out max) (because i could Smile )
Circuit employs OP-AMPs, for dynamic impedance matching, a 2 stage boost converter (in that version) for a low voltage output rail and a higher voltage output rail, a burner fan regulator (knob on right side), USB voltage regulator etc.
The circuitry is totally custom made – hand drawn concept, components searched in databases and purchased, arranged and tested at breadboard, then Eagle drawn to specific pcb dimensions, PCB printed, hand soldered, debugged, proceed to version 2, version 3 etc
i have some experience in custom made circuitry, but it takes me a while to do properly.
Besides electronics, a lot of those lamps parts had to be created and refined by experimentation, as the heat exchanger, the chimney, or the burner.
Great efforts were given for achieving efficiency in every aspect of it, having the final look in mind always.
Cheers,
Barou
Mark M
Mark M's picture
When you are ready to sell, I will be there. Big Smile
DBSAR
DBSAR's picture
Last seen: 4 hours 15 min ago
Awesome job! reminds me of the Apocalypse lantern i built a few years back. Thumbs Up
DBSAR
DBSAR's picture
!https://images2.imgbox.com/ac/fa/W6FQNuX5_o.jpg!
That is a work of beautiful art!
Marc E
Last seen: 4 days 13 hours ago
They look fantastic, and kerosene powered, so cool!
jp9mm
Last seen: 4 months 12 hours ago
Very cool!
Barou
Barou's picture
Hello,
The time is about right.
I am launching a crowdfunding campaign Octomber 2021 in order to bring my lamps to production.
Campaign’s main theme is my thermoelectric lamp model
Also will be available the electrified lamps (converted per specs)
Learn more at
www.baroulamps.com (thermoelectric lamps)
https://electrified.baroulamps.com/ (electrified lamps)
Cheers,
Barou
Cheers,
Barou
mattlward
mattlward's picture
Last seen: 47 min 43 sec ago
Dude, you are an artist and a light master! I have a couple of old railway light the I would love to mod but I am afraid to tinker with.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Barou
Barou's picture
Hello mattlward,
Thank you for your kind words.
As everything in life, you start small and keep going
Cheers,
Barou
Cheers,
Barou
Unheard
Unheard's picture
Last seen: 7 min 50 sec ago
It looks beautiful. Love the steampunk aspect of it. Absolutely fantastic.
Smile, you cannot kill them all.
Barou
Barou's picture
Thank Unheard you for your kind words.
If you would like them, consider supporting us in the upcoming campaign.
thanks
If you like the steampunk aspect of those, i believe you will find interesting my future plans..
https://www.baroulamps.com/beyond-electrophorus/
Cheers,
Barou
Cheers,
Barou
