NiMH AA(A) charger recommendation
7 posts / 0 new
Woet
Last seen: 8 months 21 hours ago
Hi,
I’ve been browsing a few threads from a few years ago and came across many different recommendations, but most threads mentioned the Panasonic chargers from the Eneloop bundles (BQ-CC55 or BQ-CC16). Are these still the best value chargers out-there nowadays?
I just need to charge AA(A) NiMH as fast as possible while keeping them as healthy as possible.
Thanks!
Edited by: Woet on 01/20/2021 - 04:13
xtarflashlight
xtarflashlight's picture
Last seen: 2 days 40 min ago
For small AA and AAA Ni-MH batteries charger, maybe you can take a look at this BC4 charger: independent four-slot, compatible with AA and AAA Ni-MH batteries, also 1.5V Li-ion batteries.
https://www.xtar.cc/product/XTAR-BC4-Charger-135.html
zoulas
zoulas's picture
Last seen: 8 hours 58 min ago
If you have a lot of NiMH batteries, its hard to beat the Maha Powerex
https://mahaenergy.com/mh-c980/
flydiver
Last seen: 13 hours 24 min ago
Is that ALL you want to charge? What about other chemistries?
Do you have a mess of them to charge at one time, such that an 8-bay charger is worth the extra?
Having capacity testing is a very nice feature, and worth the small amount of extra money.
To Air is Human, to Respire….Divine.
Woet
That’s all I want to charge, and 4 bays should be enough. If the difference in price is minimal, having more features, supporting other batteries, or having more bays would always be nice. Smile
What is the fastest speed to safely charge a NiMH without damaging it too much? As long as the charger detects -dV/dt termination, I should be able to charge at 1A per battery, right?
d_t_a
Last seen: 4 hours 26 min ago
I think 1A for AA NiMh seems OK, but may still be a bit too fast for AAA NiMh… also may depend on the battery’s age/condition. (older / higher resistance NiMh probably should be charged slower… although I think some chargers automatically adjust the charge current if detecting a higher-resistance battery)
flydiver
I tend to generally charge AA @ 500-700. 1A is OK but a bit harder on the battery.
For AAA I use 200-300, and don’t exceed 500.
HKJ has a table of tested chargers with a great sorting mechanism. Here’s a link;
https://lygte-info.dk/info/roundCellChargerIndex%20UK.html
Go the [Extras] column, click on it, scroll down to a section with [analyzing chargers] and whatever else you want, plus at least 2 smiley faces, and start doing some research.
Don’t forget to look at the current capability.
