What charger meets my requirements? Recommend me something.
10 posts / 0 new
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 8 hours 1 min ago
I haven’t found many chargers on lygte-info that meet all the requirements below.
What do you recommend?
  • 4 slots
  • Capacity and resistance measurement
  • Store function (important for me)
  • Must fit protected 21700 or at least button top 21700
  • Must fit at least two 26650 and two 18650 at once
  • Manual selection of the charging current
  • Does not overheat
  • Nimh charging possible
  • 12V power input (not very important)
  • About $50
YuvalS
YuvalS's picture
Last seen: 12 hours 16 min ago
I am sure you can find the best charger for you at HJK table
https://lygte-info.dk/info/roundCellChargerIndex%20UK.html
My FW repository
My BLF/OL contest entries: 7th 8th 9th
Chatika vas Paus
As I already mentioned, I was there. I want to know what the BLF people would choose.
ChrisGarrett
ChrisGarrett's picture
Last seen: 6 hours 2 min ago
I’m not going to go back and check every one of your parameters, but the Opus BT-3400/3100 might be just the ticket?
Ditch the protected 21700s and you’re probably golden.
Chris
d_t_a
Last seen: 34 min 17 sec ago
Quote:
4 slots Capacity and resistance measurement Store function (important for me) Must fit protected 21700 or at least button top 21700 Must fit at least two 26650 and two 18650 at once Manual selection of the charging current Does not overheat Nimh charging possible 12V power input (not very important) About $50
I think the “Store” function is quite rare…
The only chargers I’m familiar with that have that function would be the SkyRC MC3000 (programmable) and the Xtar VC4S / Xtar VC8.
The Opus BT-C3100 / BT-C3400 has a hidden internal switch that can charge to 3.6 or 3.7v (but I suppose other chargers that can charge LiFePO4, can also be programmed to charge to that level if manually selecting “LiFePO4” as the battery type (must discharge the battery to lower voltage, then charge to the ~3.6v level for LiFePO4.
SkyRC MC3000 might have the most features, but won’t fit protected 21700, and even flat-top 21700’s can be a somewhat tight fit in terms of length (it fits 4× 26650 in terms of width, or actually I think it fits 2× 32650 + 2× 26650)
Vapcell S4 Plus doesn’t have a Store function, and doesn’t charge LiFePO4. it does have all the other features you require (it fits 2× 26650 + 2× 21700 in terms of width)
Liitokala Lii-600 also doesn’t have a Store function, and doesn’t charge LiFePO4, it fits unprotected button-top 21700 (in terms of width, it can fit 4× 26650 at the same time)
I think the Opus BT-C3100 can fit unprotected button-top 21700, and fits 2× 26650 + 2× 18650 in terms of width.
Chatika vas Paus
Thanks for the input. I think I’ll say goodbye to the “store” function. SkyRC is out of my budget. I am now wondering between Miboxer C4-12 > Xtar VC4S > Opus BT-C3100.
I noticed that the Miboxer C4-12 comes in two versions. With one and two buttons. It is known if the version with two works like the one with one (charging parameters)?
xtarflashlight
xtarflashlight's picture
Last seen: 1 hour 34 min ago
XTAR VC4S can’t charge protected 21700. For your needs of charging protected 21700 and other demands, if 8-bay charger is also fine, you can take a look at xtar vc8 charger.
For the charger you described, maybe we will keep developing ideal one in future. Thumbs Up Beer
LTC
Last seen: 7 hours 42 min ago
I have been looking for a charger with exactly what you are looking for around 2 years ago.
Most important I think it’s all about budget. If no budget constrain, we can easily buy 2-3 charges to cover everything.
But I’m just like you with about that budget you stated.
As dta mentioned, store function is the one that is hard to find. And what voltage you want to store at is even harder to find.
I have the Lii-500 n and Lii-500S, Nitecore UMS4 before. All Sold.
I ended up with and still on a Miboxer C4-plus(as spare) and a Vapcell S4+ V1. Using the Vapcell most of the time unless needed for the C4-Plus.
LTC
Seriously once again xtarflashlight, I like xtar charger design a lot, but I yet to own one. Please seriously consider a 4 bay charger that allow manual current setting and able to charge protected 21700 cell. Thanks
xtarflashlight wrote:
XTAR VC4S can’t charge protected 21700. For your needs of charging protected 21700 and other demands, if 8-bay charger is also fine, you can take a look at xtar vc8 charger. For the charger you described, maybe we will keep developing ideal one in future. Thumbs Up Beer
Dalamar
Last seen: 17 hours 19 min ago
XTAR VC8 has the best balance of price, features. Will apparently charge 21700.
It has accurate IR readings (unlike many that advertise the feature) and even has a storage setting (3.6v)
IR readings are not a common feature of chargers…
I only like high CRI. Collection:
Fireflies NOV-MU 21 4500k E21A
Fireflies ROT66 219B SW45 D220
Fireflies E07 Copper 219B SW45k? (odd/higher lumen bin with lower r9 and higher cct?)
Fireflies E07 219B SW45k
Fireflies E07x Pro sst20 FA4 4000k
Varmint removal:
Convoy M21A C8 ver SST20 4000k (5a)
Convoy S2+ SST20 4000k  FB4 (3200ma)
Memes:
BLF GT94
Emisar D18 660nm SST20
CRI test dump https://drive.google.com/drive/folders/1kcl_uOhgfpR4RSsa8F4b-UUVP9mkL6Cr...
