Test/review of Keeppower 18650 3500mAh P1835U (White-blue) 2020
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 day 23 hours ago
DSC_4140
Official specifications:
  • Minimum Capacity: 3350mAh
  • Nominal Capacity: 3500mAh
  • Nominal Voltage: 3.7V
  • Discharge End Voltage: 2.5V
  • Standard Charging Current: 1.0A
  • Max. Continuous Discharging Current: 5A
  • Built in micro-usb charge port
Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-info
A 3500mAh protected 18650 with build-in USB-charger.
DSC_4138 DSC_4139
DSC_4141 DSC_4142
DSC_4143
DSC_4144
DSC_4146
DSC_4147
A pack contains two batteries and a dual usb charge cable.
Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-Capacity
The two cells tracks nicely and can handle more than 7A before getting too hot or protection will kick in.
Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-Temp-7.0
Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-Temp-10.0
Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-CapacityTimeHours
Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-Energy
Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-PowerLoadTime
Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-TripCurrent
Keeppower%2018650%203500mAh%20P1835U%20(White-blue)%202020-Charge
It looks like the USB charger reduces current probably due to temperature at the start of charging.
USB%20Charge%20Test%2020201215030539
Discharge-Keeppower%2018650%203500mAh%20P1835U%20%28White-blue%29%202020-pulse-1.0%2010%2010-IR%20backup
Conclusion
A good protected battery with good capacity, the USB charging can be useful on the go or if you only have a few 18650 batteries.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
phantom23
phantom23's picture
Last seen: 1 week 1 day ago
So essentially they are 18700 cells, not 18650.
HKJ
HKJ's picture
Usually protected batteries are longer than the number says. I have recently tested a few round cells that contains a pouch cell inside, this means they match the specified size, but until now I have only seen them in smaller sizes.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 2 days 33 min ago
