I have NX brand (panasonic) unprotected 3400mah which seem to be accurately rated. How would the official Fenix 3500mah protected cells compare om terms of runtime? Would that extra 100mah just end up being wasted on the protection circuit?
My light only takes button-top batteries but I noticed these:
There are different batteries for different purposes. Some lights require high drain. I have been into flashlights for 20 years and I am still learning about the lights and batteries. Much more complicated than it looks.
Hmm well these panasonic cells can discharge at up to 17A. No way my flashlight with a stated runtime of 2h 50min off a single cell is pulling that kind of power.
Years ago the Japanese cells were assumed to be the best. Now that does not hold true as too many companies are making cells in China. Sorry to say but this includes Panasonic.
Battery manufacturing is big business. It’s highly likely the Fenix batteries are re-wraps. So they don’t make them, they just put their name on them.Vapecell does the same thing. It sounds like you need to stick with Orbtronic. Super high quality re-wraps.
There aren’t too many Sanyo-Panasonic 18650s that can pull a constant 15-20 amps. 10 amps, sure—the NCR-GA will do 10A constant.
Samsung, LG and Sony can do upwards of 15-20-30A, continuous.
What is the light in question?
For reference, I’m using Sony 5As in my Emisar D4 and D4V2, which can pull 15A-18A on turbo. That’s smoking for a single cell light and atypical.
Most applications will be <10A and the cell in your first link looks to be a common Sanyo-Panasonic NCR-GA 3500mAh cell, which ‘was’ good for 10A continuous. If it’s not what I suggest, all bets are off, but you need to tell us the specific load, your light requires.
I have a Fenix PD32 v2.0 which has an OSRAM KW CSLPM1.TG LED. No idea what it’s max power draw is but I’d be surprised if it’s above 10A even for a brief few minutes in turbo mode.
Given the lower power requirement I don’t think the power output matters all that much, it seems to be more a question of capacity. I found these: https://www.18650.uk/lg-mj1-18650-battery-button-top but at only 100mah more that’s like 3% so probably wouldn’t make a big difference.
Well these LG batteries that are rated 10A continuous discharge are cheap enough, should I grab a couple of them to try? 18650.uk don’t have any other 3500mah capacity button tops
Best is very subjective. Although 3400mAh are probably ICR’s, which are usually better with a protection circuit.
Personally I find IMR high performance cells work best for me. And on high drain high lumen outputs will normally last longer, despite having lower capacity.
I’m tempted to just get a Fenix battery or two tbh, they’re bound to be as good as they can be for the light… they sell them for a premium so it would make sense that they sourced the best cells they could to make their lights run longer.
I would imagine like most of Fenix stuff. The batteries will just be over priced. Fenix do not make batteries, they just sell other peoples with a different wrapper on and add a mark-up.
I have some Rofis, Egaletac and Klarus branded batteries. They all under perform compared to the 30Q’s.
