New Cree Leds(XHP70 in HI coming 2022)
63 posts / 0 new
Th558
Th558's picture
Last seen: 5 hours 54 min ago
18 of these in an MF01S…hmmm..
ArtieT59
ArtieT59's picture
Last seen: 10 hours 10 min ago
djozz wrote:
Nice! So we can expect 720 lumen at 3A, and 5000K, now see how they compare to the Osram version Smile
agreed. ill take a 800-900 (hopeful) lumen K1 with > 500kcd range and 5000k tint. sign me up. Big Smile
plus, 3 amps sounds to me like good battery life?
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
ArtieT59
ArtieT59's picture
yup! or 4 of them in a KR4 or D4. I just sold my beautiful brass d4v2 with W2 because i couldn’t justify the 6500k tint any more.. It’d be awesome to have similar range in a 5000k tint!
Enderman
Enderman's picture
Last seen: 1 day 10 hours ago
Even with the highest bin, 800lm at 3A won’t give much more than 900lm at the peak of about 4-4.5A
Still quite short of the 1000-1100 of the CULNM1
Scallywag
Scallywag's picture
Last seen: 6 hours 44 min ago
Still quite short of the 1000-1100 of the CSLPM1
CULNM1?
Superstocker
Superstocker's picture
Last seen: 8 hours 32 min ago
90% of cslnmn and 5k is good for me. 3A makes driver options pretty easy and cheap too.
Enderman
Enderman's picture
CULNM1?
Yeah sorry, that one Smile
JaredM
JaredM's picture
Last seen: 2 hours 19 min ago
Seems like the XP-P is ‘here’. As in it’s on Cree’s website. https://cree-led.com/products/xlamp-leds-discrete/xlamp-xp-p
1.05*1.05 mm die though, so it’s going to need some miracles to compete with the white flats on brightness alone. Likely lower cost, better availability, 5000K cct, and 3535 footprint are a big win though. I like how the surrounding silicone pour is below the plane of the phosphor. This should make for cleaner beams / less artifacts. 3A vs 3A, it should hold it’s own. Looks to be not much room for overdriving. Let’s hope we’re wrong about that somehow.
Sunnysunsun
Sunnysunsun's picture
Last seen: 3 hours 42 min ago
It has a pretty high forward voltage. The 219b/sst-20/LH351D have a forward voltage under 3.3V at 3A. The Xpp has a forward voltage of over 3.6v at 3A on the datasheet. This should be a fet capable emitter but I don’t see it going much over 800 Lumens even when overdriven.
JaredM
JaredM's picture
As soon as one is available at reasonable cost I’ll test it and post results. Latest datasheet only shows U5 bin (360lm) available but in all CCTs. Hopefully 5000K rolls out soon and isn’t puke green.
Edit: The Vf looks to be nearly identical to the Osram Black Flat S (HHL532.TK). Running DD from an LG H26 I see a max of about 4.95A in a super low resistance build. So these should run nicely off of 3500mAh 18650s and 5Ah 21700s
Scallywag
Scallywag's picture
Oh, we’ll throw the strongest cell we have at them and see if we can turn them blue.
JaredM
JaredM's picture
I got 3 XP-P emitters in the mail today. Will post test results soon, but initial eyeballing says that our predictions are right. Not much headroom here. 3A lux reading was 1350, peak was 1500 around 4.25A (roughly). I ordered the 5700K (lowest in stock). Tint is purplish from the bare emitter. Check back later..
Scallywag
Scallywag's picture
Yeah I’m more excited about the XHP50.? HI version.
JaredM
JaredM's picture
The Vf on this thing is crazy high. Here’s a test comparing to all the Osrams that I have.
Put one in my Jacob A60. Beam and color are very, very nice. Will get kcd numbers shortly and edit this post. XPP yielded 224kcd. CSLNM1 (MTNe) did 233kcd, HHL532.TK(mouser) did 278kcd. Guessing this will slot in between, but nearer the NM1. For having 10% larger LES, this is a nice number.
djozz
djozz's picture
Last seen: 4 min 47 sec ago
Thanks for testing.
Difficult to say what this led adds to the CSLNM1, it may be a bit more efficient at lower currents, but less than seems because of the higher Vf. But if it comes in a range of attractive tints that could convince me to use it.
JaredM
JaredM's picture
I think it would’ve been a hit about a year or two ago before 3030 and 4040 mcpcbs and gaskets were widely available and when DD FET drivers were king. Nowadays it’s not really doing anything special. If the 5000K comes in a bin or two higher flux, then it’s a different story.
Measured that A60.. got 224kcd. So not quite hitting the NM1, but close enough. I feel like the hotspot is noticeably larger, but I can’t be sure since I only have one of these lights.
jasontheguitarist
Last seen: 1 day 19 hours ago
Could be useful for lights that have a weird reflector hole size with a non standard centering ring. Or a multi emitter light like a convoy S12 that use a non standard MCPCB that doesn’t come in 3030. I know it’s possible to put osrams on a 3535 but It seems like a pain.
ArtieT59
ArtieT59's picture
Thanks for testing JaredM. This emitter is exciting to me. I, just thinking multi emitter light like a Noctigon KR4 or even a 7 emitter or 18 emitter light, in 5000k with throw 90% of a cslnm1? Amazing.
now, the real interest, when are xhp50 HI coming out, and is there a data sheet?
degarb
Is the only way to subscribe to a thread in blf, is to post?
For myself, I am not interested in high currents. Looking at relative flux, it looks like around 144 ish at 350 ma. Might be good with 1 watt, single amc7135 small lights and small optics.
The rest of this post is my personal use for wearable lighting, daily use, inspection etc, 10 hour work daysj, with crews and family (hoping this emitter might crack an old problem): I typically look for 4000 lux at 1 meter for as close to 10 hours (grudgingly, I will take 8 hours) flat output. The 2011 4aa Fenix hp 10, could do this with a 139 lpw xpg1, some good heat sinking, a 1 watt ish cc buck driver, ar lens, and a 26 mm aluminum reflector. it would be nice to see this same performance in a single 18650 and a 20 mm lens. So far, all I see is 6 amc7135 and pwm down to useless efficiency and runtimes, made to impress with the lumen numbers, rather than efficiency numbers. Leds are about efficiency and what we can do with the limitations we place on ourselves for practical work a day applications. Not one off experiments.
This is why I make my own lights and have lost interest in just about anything sold today. I need lights that meet specs, since I loan them out to people who do not, and should not, be changing batteries, but need 10 or even 20 hours at 4000 lux at one meter (1000 lux at 2 meters). I am pretty happy with 2s18650 buck efficiency, but I see a big difference going down to linear drivers. However, it is 2021 and the problems remains: The smaller the light, the fewer the cells, the smaller the optic, the less intensity per ma, the less juice can be fed to the led if you need runtime, the less efficient the driver… I struggle to see with my smaller lights. The best was the imalent hp 10, which was an xplhi and dial, I bought 3. They offered best intensity and runtime, but only offered me barely 4 hours of useful light (barely enough time to finish a day after sundown, but maybe not if used in morning during loading time) which is about 2 hours more than convoys, etc. The only reason I bought them is that I can wear them on the belt when not using them on my head. I can’t do this with 2p18650 lights, which means I must quit what I am doing to find those lights, if I brought them to the job.
Runtime=Usefulness
thefreeman
thefreeman's picture
Last seen: 1 hour 24 min ago
Subscribe button at the bottom of the 1st post.
dave1010
dave1010's picture
Last seen: 8 hours 9 min ago
That’s 4000 candela (4kcd) or 126m throw.
The ThruNite Catapult Mini does 21 lm on low for 12 hours with a 18350 cell. It’s about 200 cd/lm, so that’s over 4000cd. 40mm head though, which is probably not what you want.
The 27mm bezel Convoy S21B with W2 LED is 9000cd on the 10% mode, which should last about 7 hours. There isn’t a 5% mode unfortunately but that almost sounds like exactly what you want. A smaller 18650 host with W1 might even do it too.
degarb
Dave, thank you greatly. I am a spec guy, so I need the lpw, the current at each steps, the amc number, and where to buy (I am thinking banggood or gearbest.). The convoy’s have been reasonable enough in the past, to be great impulse buys.
The key word here is “should” . These amc7135s throttle down when heated too long, and they are only 70% efficient. When arrays are used rather than just powering 1 or 2, they are pwm, which means more led heat…..
Nevertheless, this osram convoy mention has my attention. After reading the data sheet on the led, I know very little more about the lpw, and the light’s 10 percent current. I don’t see the current listed on the light product page, or the number of amc’s they are using.
Yeah, in a single cell light, 21700 is the way to go. A 2s18650 would be the way to go, but I haven’t seen a lightweight (wearable) 2s18650 version on the shelves. My Fenix tk series is an obscene heavy tank that I really can’t use for very long before it becomes fatiguing to wear.
I will need to dig more, later, if I remember on the led. How many lumens on low, and where is best place to buy it?
(I can easily take a glove, cut the fingers and palm off, amazing goop or sew elastic on to hold a convoy, which frees up my hands and adds a valuable light to aid a headlamp.
The advantage is it is quick to make, and durable in theory. The downside, is I never got more than 2 hours and 15 minutes of enough light to work with in the real world. In fact I struggle to see well, unless I am in the total dark, and usually they crash aroung 1h45 minutes, even when the mutimeter thinks the light should run 5 hours. Losses add up which creats heat, and heat throttles these drivers. Also, what is weird, is my attempts to build 1+1 amc7135 lights that I have two switches for each amc, run flat output, while most lights that claim flat output, clearly drop-which may be that I mount my amc’s on copper that I thermal glue to almuminum, away from the hot led, while I believe light makers put the amc’s closer to the led because you need a cap if wired longer than 2 inches, as I recall. While, I (since 2014) can take a dimming buckpuck 700 and make an “aircraft carrier design, using upsidedown 2s18650 holder, thermal epoxy a 31 to 36 mm aluminum reflector, ar lense, avid heat sink to hold and act like a vented vent the bezel, old school cpu heatsink, some elastic, and I got a killer work light for my left wrist that is light and bright, super efficient, and lasts 9 hours on high—not water proof, and need to be toted around inside lunch box inside my bookbag of lights. I posted one thread on cpf with pics and plans in 2014, called spikey aircraft carrier, in homemade lights forum.)
Runtime=Usefulness
dave1010
dave1010's picture
The best place to get a Convoy is from their official store on AliExpress:
https://a.aliexpress.com/_uIuwMU
It might be worth contacting Simon (owner of Convoy) via AliExpress for more information. Convoy sometimes let you buy lights with different drivers if you ask. You may be able to get one that’s more efficient at low modes. I don’t know enough about 7135s to know what’s best though.
Anyway, we seem to have gone off topic a bit from the new CREE LEDs. If the Convoy is no good then it may be worth starting a new thread with what you’re after.
welight
welight's picture
Last seen: 2 days 8 hours ago
XHP70.3 HI
cheers
Cutter Electronics Pty Ltd
Web: https://www.cutter.com.au
JaredM
JaredM's picture
I like how Cree is recognizing the flashlight industry as a major target. This is good news. Thanks for the update.
Anything update on the XPG4?
Sirstinky
welight wrote:
XHP70.3 HI cheers
That’s awesome! They say 2022, but that means we won’t see them in flashlights until at least 2023 Tired guess I’ll keep slicing and dicing.
welight
welight's picture
first samples Nov 2021, production 1st quarter 2022 ie jan onwards
cheers
thefreeman
welight wrote:
XHP70.3 HI
Excellent!
ArtieT59
ArtieT59's picture
Amazing! Thanks Welight!! great news! and. i bet well see them by next summer!
Any update on the 50.3 HI??
Are you selling the 50.3 HI? Specifically 6volt? or even 12volt would be fine too.
EDIT: sorry about mentioning your competition.. i forgot you are Cutter... i am an idiot. i promptly edited my post
JaredM
JaredM's picture
XHP 50 / 70 are all (except 3V versions) simultaneously 6V and 12V. The voltage depends on the mcpcb configuration
