Test/review of Keeppower 14430 950mAh P1443C2 (Black) 2020
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 days 1 hour ago
DSC_4067
Official specifications:
  • Voltage: 3.70V
  • Rated capacity: 850mAh
  • Minimum Capacity: 800mAh
  • Discharge cut-off voltage: 2.50V
  • Charge voltage: 4.20V +/- 0.05V
  • Standard charge current: 500mA
  • Maximum constant discharge current: 2A
Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-info
Protected LiIon 14430 batteries from Keeppower, these batteries are about 5mm shorter than AA batteries, but with the same diameter and the higher LiIon voltage.
DSC_4065 DSC_4066
DSC_4068 DSC_4069
DSC_4070
DSC_4071
Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-Capacity
The two batteries tracks nicely, they are rated for 2A and can handle it.
Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-Temp-1.0
Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-Temp-2.0
Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-Temp-3.0
Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-CapacityTimeHours
Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-Energy
Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-PowerLoadTime
Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-TripCurrent
Keeppower%2014430%20950mAh%20P1443C2%20(Black)%202020-Charge
Discharge-Keeppower%2014430%20950mAh%20P1443C2%20%28Black%29%202020-pulse-0.5%2010%2010-IR
Conclusion
This looks like good batteries, but they are not for high current and there size is a bit uncommon.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
Superstocker
Superstocker's picture
Last seen: 2 hours 46 min ago
Thanks HKJ!
d_t_a
Last seen: 22 hours 26 min ago
Just wondering, are there flashlights or which devices make use of the 14430 size battery? Or perhaps can be used for a substitute of some other battery type/size?
MascaratumB
MascaratumB's picture
Last seen: 7 hours 27 min ago
I guess that some flashlights that take 14500 cells will also take these!
The black Sofirn 14500 cells and the White/Blue Lumintop cell (with USB charging port) are shorter than most of the 14500 but they are named as such, so these may fall, more or less in the same category. Depending on the flashlight!
Thanks for your review HKJ!
EDIT: Forget what I said about the Sofirn cells, they are longer. But the LT has approximatelly the same length!
Agro
Agro's picture
Last seen: 1 min 27 sec ago
I think that this would be a good target for a rewrapper to add a USB port while still fitting all 14500-powered devices.
toobadorz
toobadorz's picture
Last seen: 1 day 13 hours ago
There have been some. For example, Keeppower P1495U and Vapcell P1409A .
