convoy s2 bad tail switch
16 posts / 0 new
cmwr
Last seen: 5 days 1 hour ago
I have a convoy s2 plus that is a few years old but really hasn’t had extensive use. It is in like new condition. Recently the tail switch started acting up. Sometimes when you click it on the light goes out and comes back on depending if you hold the light differently and other times the light may go from dim to bright on its own. I’m rather disappointed because this light hasn’t had hard use. is there anything I can do to clean the switch with brake or electronic cleaner or is the switch junk? For no more than I paid for this light I can’t see spending money on replacement parts.
zoulas
zoulas's picture
Last seen: 9 min 58 sec ago
I am sure you can get another tailcap on Ali Exp / Convoy store.
aginthelaw
aginthelaw's picture
Last seen: 11 hours 21 min ago
If you look in the tail cap, you see the two holes on the gold-colored ring? See if it’s tight. If it is, try taking it apart and putting it back together. It’s a simple process if you want to undertake it.
never fear shadows…it means a light shines nearby
Yokiamy
Yokiamy's picture
Last seen: 3 hours 17 min ago
You might check the switch retaining ring, it probably needs to be tightened, which will probably solve the issue.
If you have a retaining ring on the driver side, please tighten that one as well.
(S2+ es with more tan 4*7135 chips have a soldered driver)
WTB: Jetbeam TCR-1 or Sunwayman V10R Ti
Oli
Last seen: 1 day 11 hours ago
Yes something is loose. The retaining ring in the S2+ tail cap is reverse threads. This is why a lot of flashlight companies want to glue these things in place. People immediately think it’s broken. There’s another thread within the last day about the tools required.
RobertB
RobertB's picture
Last seen: 1 day 10 hours ago
Along with the good advise from others, there is a chance one of the posts on the switch came un-soldered or is barely holding on to the circuit board. But probably a loose retaining ring.
NeutralFan
NeutralFan's picture
Last seen: 1 day 13 hours ago
And depending on the type of S2+ you have, the issue could also be a loose retaining ring on the driver. Some drivers are soldered to the pill, but others are held in by a retaining ring. That retaining ring tightens normally clockwise.
I’d rather use my flashlight around the house than turn on the lights.
toddcshoe
toddcshoe's picture
Last seen: 4 hours 28 min ago
After trouble shooting, if you think you need a new tail switch, just shoot me a PM. I have a box full of them. Stock ones and lighted ones. I’ll send you one so you don’t have to wait for an overseas shop.
"Everywhere I go, there I am"
cmwr
Hey guys thanks for all the info. Believe it or not I never got any emails telling me I had replies and then forgot all about it lol. I’ll check these things out. Thanks guys!
Boaz
Boaz's picture
Last seen: 5 hours 12 min ago
Surprised no one suggested
 take it apart clean with alcohol and reassemble
    It works 96% of the time
Penny wise but ...
Penny wise but Lumen foolish's picture
Last seen: 5 days 12 min ago
They changed the threads on the S2+ recently,  you might run into an issue with a new switch being compatible with your older light.
RobertB
RobertB's picture
The switch has nothing to do with the threads
cmwr
It apparently does because that fixed the problem. The brass threaded piece that holds the switch tightly in the cap was a little loose. I got it tightened up with a small spanner and life is good!. I’m assuming if it works loose then you get loose connections in there as the pieces are probably sandwiched together I don’t know. But it’s fixed now apparently so thanks for all the advice guys!
RobertB
RobertB's picture
He was talking about the threads Convoy changed on the tail cap itself, not the threaded retainer ring
cmwr
My bad sorry
Penny wise but ...
cmwr wrote:
RobertB wrote:
It apparently does because that fixed the problem. The brass threaded piece that holds the switch tightly in the cap was a little loose. I got it tightened up with a small spanner and life is good!. I'm assuming if it works loose then you get loose connections in there as the pieces are probably sandwiched together I don't know. But it's fixed now apparently so thanks for all the advice guys! The "switch":https://i.imgur.com/vt6bA1s.jpg has nothing to do with the threads
My bad sorry
Yes I just wanted the OP to know the threads would probably be different  on a replacement tail cap, I wasn't sure if that would effect the parts he needed to replace his switch.
