Is my maths right?
13 posts / 0 new
negev
Last seen: 6 days 19 hours ago
Is my maths right?
I was curious how much more power an 18650 has than a typical AA battery, being not that much bigger in size.
A duracell AA at 1A output (typical for a small flashlight) returns 506mAh (source: https://rightbattery.com/118-1-5v-aa-duracell-alkaline-battery-tests/)
so that’s 506mA at 1.5V. Adjust that up to 3.6V – 506 / (3.6 / 1.5) = 210.8mAh
So a 3500mAh 18650 has the same amount of power as 16.6 duracell AAs at 1A output. That’s staggering. It does halve to 8.3 AAs at 0.5A current but even still.
xxo
Last seen: 2 hours 22 min ago
Using HJK’s data, a Keep Power 3500 mAh 18650 has 11.881 Watt hrs and a Duracell AA has 1.297 Watt hrs, both at 1 Amp.
18650
AA
11.881/1.297 = 9.16 so this 18650 has a little over 9 times the power of the AA cell.
Scallywag
Scallywag's picture
Last seen: 11 hours 19 min ago
negev, as xxo already used, the comparison for total energy of a battery is not amp-hours but watt-hours. This is calculated by multiplying the capacity in amp-hours by the nominal voltage of the battery. So for a 3500 mAh (=3.5 Ah) 18650, we multiply by 3.6 (or 3.7 for some cheeky manufacturers) for a value of 12.6 rated watt-hours. Of course xxo referred to HKJ’s test (and at a specific discharge current, too!) so the value is different, but perhaps better since it’s based on an actual test rather than rated capacity.
If we were to compare the amount of energy the cells are able to deliver in bursts, the 18650s pull even further ahead! Check 10, 15, or even 20 amp discharge curves for 18650s (maybe 30Q or VTC6). If you want to be more generous to AAs you could use Energizer Lithium or Eneloop NiMh to compare.
Old Lumens Contest 2020 - Hand-made light category
ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20 | Baton S1
Boruit D10 w/ Quadrupel Fet+1/Anduril | EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S15 Ti | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special | Thrunite T10Tv2
Supfire M6 3xXHP50.2, Sofirn C8F, Unfinished: Sofirn SP70, IYP07/Tool AAA hot-rods, Jetbeam E3S
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
pepinfaxera
Last seen: 6 hours 15 min ago
Error; Confusing watts with watt hours
Power can be expressed in watts, not watts / hours.
Sorry for my bad English
(google translator) , (https://www.deepl.com/translator)
richbuff
Last seen: 27 min 36 sec ago
Power equals work divided by time. Power = Watts. Watts = amps times volts.
Watts equal work divided by hours.
Work equals power times time.
Work equals watts times hours.
Time equals work divided by power.
Hours equal work divided by watts.
Because I like big lights, my flashlightical views lean heavily toward both the extreme bright and the extreme heft.
Lightbringer
Lightbringer's picture
Last seen: 8 hours 13 min ago
Whatt?
RobertB
RobertB's picture
Last seen: 3 days 10 hours ago
I don’t know how many watt hours I worked shoveling snow today, but I could feel the BTU’s dripping from my forehead
Sidney Stratton
Sidney Stratton's picture
Last seen: 15 hours 1 min ago
Energy = Watt Hours
‘xxo’ never mentioned power.
xxo
Energy = Watt Hours
Pepinfaxera is right I should have said energy instead of power.
aginthelaw
aginthelaw's picture
Last seen: 15 hours 3 min ago
Math’s good but the English is lacking
never fear shadows…it means a light shines nearby
Boaz
Boaz's picture
Last seen: 2 days 6 hours ago
RobertB wrote:
I don't know how many watt hours I worked shoveling snow today, but I could feel the BTU's dripping from my forehead
 the BTU is much to large to be used as a headlamp. Wrong tool for the job .
JaredM
JaredM's picture
Last seen: 2 hours 49 min ago
As my dad used to say.. “the heat is in the work”
Barkuti
Barkuti's picture
Last seen: 1 hour 46 min ago
First of all, you are speaking about energy, not power.
Alkaline cells, along with any sort of expendable cells, are not designed for heavy loads.
And this calculation, while seemingly valid is far from correct. This is because you are considering “nominal” voltages, and nominal voltages are sort of average voltage values at typical loads. A high energy 18650 li-ion cell is expected to provide an average of 3.6V during discharge at 1A load current, maybe a little bit more. However, the expected typical load for an alkaline 14500 cell is much lower than 1A, a lot lower. This means that the average output voltage from a 14500 cell at 1A load is quite a bit lower. In fact, in your above review the average output voltage from the akaline cell down to 1V at 1A is just ≈1.12V.
Let's see a more proper Duracell alkaline 14500 test: Duracell Plus Power AA
The guy in the test you linked obtained 506mAh at 1A, cutting-off at 1V. This matters, too.
HKJ (see above graph) obtained ≈687mAh at 1A with cut-off at 1V, and 1097mAh with cut-off at 0.7V. Cut-off must be considered.
You should compare cells in terms of energy, which is average load voltage (V) times capacity (Ah): E = V × Ah = Wh.
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
- Yeah, but is it ultra high CRI? Innocent
