Tritium Inlay Source?
13 posts / 0 new
JL724
Last seen: 2 weeks 6 days ago
Anyone have a good source for red 1.5 × 6 mm inlays? Most seem to be out of stock right now. Thanks.
moderator007
moderator007's picture
Last seen: 1 month 13 hours ago
Aliexpress has them, but they are not cheap.
https://www.aliexpress.com/item/32865085427.html
They were half the price a few months ago. Shocked
JL724
Thanks, will probably just buy those unless someone has a better option.
JL724
Found a $4 coupon, so only ended up being $11 shipped. Thanks!
aggillator
aggillator's picture
NealsGadgets seems to be listing them as in stock for only 99 cents each! I tried confirming that with him but no response. So buy at your own risk.
UltraMagnus
Last seen: 2 weeks 5 days ago
Not any-more, they seem to have increased the price.
Jasetaylor
Jasetaylor's picture
Last seen: 2 days 15 hours ago
The 99 cents version are not Tritium, they are glow in the dark GITD material.
aggillator
Ur right. That makes more sense
MascaratumB
MascaratumB's picture
Last seen: 56 min 36 sec ago
Wow, that was a great increase in the price Shocked
At JL724: I guess that maybe you can check these again in some weeks, if you can wait some more time.
Sometimes after the Chinese New Year prices go up and then go down again after a while. I’m not sure if this is the case though.
From this store, I know they are reliable at least!
Jasetaylor
Mixglo.com has them in 1.5mm x 6mm.
Edited to add – only in blue, pink or yellow. Yellow will glow the brightest / longest of the remaining three options.
https://www.mixglo.com/store/p135/T1.html#
JL724
How do you guys “attach” these to the cutouts in your lights? Hesitant to stick glue on it.
MascaratumB
I use UV glue.
Put the glue and the tritium vial in place, then use a UV flashlight or let it cure “under the sun”.
Make sure the vial is placed correctly, not too deep nor too protruding in the cutout (in case it is “horizontal). If vertical, take care too, of course.
Perception
Last seen: 1 day 17 hours ago
I haven’t done it, but I know a lot of people use a UV activated epoxy like Norland.
