Battery check BLF Q8 question
8 posts / 0 new
SIGShooter
SIGShooter's picture
Last seen: 6 hours 58 min ago
On one of my Q8’s (original batch) the battery check blinks the switch rather than the LED’s. Not sure how I got it into this state but how do I switch it back so that the LED’s blink rather than the switch? It’s not the worse thing in the world but I want it to be consistent with my other lights.
Thanks Smile
nick779
nick779's picture
Last seen: 1 hour 24 min ago
Still on stock Narsil or did you flash to Anduril?
SIGShooter
It’s still stock from the initial buy. Never got around to flashing it since my clip broke.
pennzy
pennzy's picture
Last seen: 6 min 41 sec ago
From the battery check mode press and hold for at least 1.2 seconds to enter advance configuration UI operation. The light blinks twice quickly and once slowly. There are three setting and operate like the main configuration UI
1 locator led feature 1=disable 2= enable default 2
2 battery level indicator led only 1=disable 2=enable default 1
3 indicator led enable 1= disable 2=enable default 2
SIGShooter
Thanks that did the trick. I can’t believe I missed that on the instructions Sad
pennzy
pennzy's picture
Does one of those 3 enable the side led while on?
SIGShooter
Haven’t been able to get it to do that but that doesn’t mean I’m doing it correctly Shocked
pennzy
pennzy's picture
Me neither.
