The Wowtac A3 may not be the best option for rifle mount, but is the Wowtac A3 a good DIY source? I say Yes!
The OPs questions prodded me in to trying some mods on the A3 that I had been planning.
So here goes…
- Remove battery tube and battery.
- I was able to open the bezel with a little heat and some grippy gloves.
- Unsolder the LED MCPCB and remove. Tuck the wires back into the head.
- Next came the aluminum LED holder screwed into the head (not really a pill since driver is separate). A little heat and grippy gloves again.
- Driver is pressed in from the batter end. Press out the driver. Careful not to damage the switch board. I used a flat blade screwdriver and tapped around the out edge.
- Mod driver by stacking resistor on existing sense resistor. I put 0.25 ohms on the 0.24 ohm R that was already there. This gave me 3.8 amps on Turbo.
- Replace driver and aluminum holder.
- Replace LED with 1mm white flat on 16mm MCPCB.
- Reassemble head. Don’t screw bezel on tight.
- Reassemble battery tube and battery.
- Turn on light. Unscrew bezel slightly to achieve desired spot focus (lens is attached to bezel, so unscrewed bezel gives longer focus length to “fine tune” desired focus).
Wow! The white flat makes a nearly perfect square. Much nicer than other LEDs in zoomies I’ve had in the past.
The white flat really makes this light come alive! I didn’t measure the before and after, but it is at least 4x higher intensity with a much cleaner output.
Lux is significantly higher than an Emisar D1 I have sitting here. Not as high as my D1s modifed with a white flat. I may need to learn to start measuring Lux…
I slipped an o-ring over and into the groove that was left with the bezel unscrewed for looks and a little water resistance (it is not compressed, so resistance is about all it will provide).
So, is the Wowtac A3 a good DIY source… only if you like a good quality, easy to mod, zoomie for $10 with battery!
FB
