Hi, I have a quick comparison between those two Wizard headlamps. So if you are wondering which one to choose, this might be helpful :)
White version is rather cool-neutral, more to the cool side, unfortunately. Expect CCT above 5500K
Warm is a bit warmer than previous Warm version of Wizard Pro. Expect CCT below 4000K
There should be an option between those two - a nice 4500K Wizard would be welcome. Yes, there is a Nichia version, but I thing there should be a lower-CRI-but-brighter-4500K option.
All pictures was taken using the sunlight white balance
I've tested both versions in the mountains this year, and I am sure the Warm version is way better for snow hiking.
Now comparison between the old Wizard Pro Warm, and the new C2 Pro one:
Differences I've noticed:
- Old Wizard is slightly less yellowish
- Old Wizard renders colors a bit worse (my opinion)
- New Wizard has a tint shift, which is common for 2nd gen XHP leds.
My C2 Pro White version is a bit cooler than the old one. It is more to the cool side, than the neutral-cool.
After couple of days of testing, I can choose the Warm version as my favorite. This doesn't mean the White one is bad - it has many pros, but I need a headlamp for mountain hiking and camping, so the Warm version is a better choice.
I hope this short comparison helped! I have more Wizard comparisons, so stay tuned.
