Test/review of Keeppower 18350 1400mAh P1835C3 (Black) 2020
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 22 min ago
DSC_4108
Official specifications:
  • Voltage: 3.70V
  • Rated capacity: 1400mAh
  • Minimum Capacity: 1300mAh
  • Discharge cut-off voltage: 2.50V
  • Charge voltage: 4.20V +/- 0.05V
  • Standard charge current: 500mA
  • Maximum constant discharge current: 3A
Keeppower%2018350%201400mAh%20P1835C3%20(Black)%202020-info
This is a high capacity 18350 cell, but current is fairly limited.
DSC_4106 DSC_4107
DSC_4109 DSC_4110
DSC_4111
DSC_4112
Keeppower%2018350%201400mAh%20P1835C3%20(Black)%202020-Capacity
The two cells match nicely and it is the highest capacity cell I have tested to data (3-2021).
Note: To see the full curve at lower currents look at the “Discharge, time” curve. The capacity can be seen in the table.
Keeppower%2018350%201400mAh%20P1835C3%20(Black)%202020-Temp-5.0
Keeppower%2018350%201400mAh%20P1835C3%20(Black)%202020-Temp-7.0
Keeppower%2018350%201400mAh%20P1835C3%20(Black)%202020-CapacityTimeHours
Keeppower%2018350%201400mAh%20P1835C3%20(Black)%202020-Energy
Keeppower%2018350%201400mAh%20P1835C3%20(Black)%202020-PowerLoadTime
Keeppower%2018350%201400mAh%20P1835C3%20(Black)%202020-TripCurrent
Keeppower%2018350%201400mAh%20P1835C3%20(Black)%202020-Charge
Discharge-Keeppower%2018350%201400mAh%20P1835C3%20%28Black%29%202020-pulse-0.5%2010%2010-IR
Conclusion
A few years ago the 18350 cell to a leap in capacity and current, this time it is another leap, but only in capacity and there is not high current ability in this cell.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
thefreeman
thefreeman's picture
Last seen: 2 hours 36 min ago
This is welcome for low current applications, thanks for the test.
Edit : it is Protected so we’ll see better performances from the unprotected version. Have they sent it to you as well ?
jon_slider
jon_slider's picture
Last seen: 15 min ago
1400mAh sounds great!
thefreeman wrote:
it is Protected
The Protected 18350 Keepower is 39mm long.
disadvantage of protected 18350:
It is too long for my Original RRT-01.
I think it will also be too long for the Emissar D4 w short tube. (and the high output demand will trip protection, producing sudden darkness.)
the UNprotected Keepower 1200mAh is 35mm long and does fit and works, in my Original RRT-01. And in a D4 it wont produce sudden darkness.
supreme
Last seen: 1 week 22 hours ago
Where can I find the unprotected version?
Can I use the protected version in a Convoy S2+ 7135 without any problems? It seems the max it can pull is 2800mA
thefreeman
No idea, it’s actually not listed on their website, I’m just assuming they’ll have an unprotected version just like with the 1200mAh cell.
But Vapcell has a 1400mAh unprotected cell which is probably the same cell underwrap.
Sounds adequate for an 7135 based S2+.
supreme
I couldn’t find a US vendor which carries the Vapcell 1400mAh Sad
