My gaming laptop is at the repair shop.
If it cannot be fixed, I want to replace it with a pre-built budget gaming desktop.
Right now I'd like to keep it under $1500.
I found some advice here:
https://www.ign.com/articles/best-budget-gaming-pc
and here:
https://www.pcgamer.com/best-cheap-gaming-pc/
Then I started looking at gaming desktops mostly on Newegg and Amazon.
This is the system that I like at the moment:
https://www.amazon.com/CyberpowerPC-Xtreme-i5-10400F-GeForce-GXiVR8060A10/dp/B08FBK2DK5/
Basically I want some BLF advice as well, which is the point of this thread.
General advice is good, but links to professional websites are also welcome.
Thanks in advance!
I'd like the system to be at least as powerful as the one I linked to, and I'd like to be able to upgrade it fairly easily.
Also important: a gaming desktop that doesn't overheat.
How to Post Images on BLF // Many knives for sale (USA only)
How to move a thread
Building a gaming PC is the absolute best and cheapest strategy, If you cant do this for whatever reason, I would make a list of the parts you like and see which vendor comes close to what you are looking for. There are hundreds of companies like this one:
https://www.ibuypower.com/
and
https://www.cyberpowerpc.com/category/gaming-pcs/
I don't feel comfortable building a PC.
And once I learn that I need to get a new PC, I don't want to wait for a company like cyberpowerpc to assemble it.
That's why I said that I want a pre-built system.
My kids godparents bought the ibuypower pc’s and ran into a bunch of problems so stay away from them. Dell has refurbished alienware, republic of gaming, Lenovo also has refurbished and razer has gaming pc’s though on the expensive side s
never fear shadows…it means a light shines nearby
Unfortunately companies like ibuypower take $1000 worth of pc parts and sell them to you for $2000. If you do some analyses you can see what you are getting and what they are charging. Beware that companies like Dell embed the video card on the motherboard so when they say it comes with a RTX2070, its really not a full video card just a chip on the motherboard.
Ain’t there companies that built it for you from parts that you choose?
Problem with pre-built seems always be overpricing, not good motherboards, power supplys or something else that will be bottleneck or just bad quality. Some even make upgrading it in future almost impossible without swapping pretty much everything. Also you can save hundreds of bucks and end up with much better result. Choosing your own parts also makes your PC a personal computer and not just a computer that someone else made thinking this will do, I just work here. Customized for you, by you.
I been waiting to order parts for my new pc build. for awhile now. Only thing I take pre-assembled will probably be cpu with cooler to motherboard which also includes testing and newest bios at the same time. Only 25€ so why not. Full assembly and testing would be 89€, not bad price really. Just to save some time so I can just plug and play when everything arrives.
Just saying. Maybe you should consider. Games ain’t going anywhere if you need to wait week or two extra. I been thinking about upgrading for almost few years now. Well I got good case waiting for parts maybe four years ago, but hey Rome wasn’t built in a day. Last good game I played with pc was Stalker Call of Pripyat anyway. After that maybe few games I would like to play. My build is going to last probably good 10-20 years when ready, unless something really revolutionary comes and not much has happened in the last 10 years. If I need then maybe getting better GPU at some point, but can’t imagine that my needs would require anything else. This laptop is maybe 15 years old too already.
To me it seems like current GPUs are hard to find and expensive to buy unless you get them in a computer. I haven’t built a gaming PC for a long time because I don’t have the time for playing games and the budget is allocated elsewhere.
I have purchased a few “Powerspec” and Dell gaming computers from Microcenter recently for use as X-ray capture computers (needed strong GPUs). They seem to be fairly priced and available locally (for me in the Dallas area). Microcenter puts the GPU in most of the Dells they have listed. It is a discrete card, not a chip on the motherboard.
If you have a Microcenter near you, check them out or look here: Microcenter
Building a computer has the advantage of reusing old parts, or getting exactly what you want. PCpartpicker is a great resource for figuring out what can fit together if you go that route. PC componenets aren’t nearly as fragile as they used to be, and you can find good tutorials on youtube for putting the pieces together if needed.
Some tips:
be very careful with CPU pins, they are fragile and can make for an expensive mistake
use the right thermal paste. and apply it the right way (check youtube if you don’t know). The stock CPU cooler is probably enough if you don’t want to overclock (I wouldn’t).. and it usually has a thermal adhesive already applied.
Use standoffs under the motherboard (DO NOT screw the motherboard directly to the case)
Get a big SSD for your main drive initially and add extra storage later if your budget doesn’t allow for it now
Don’t bother before DDR5. It even has ECC as a mandatory spec. Literally wasting your money.
CPUs supporting it won’t be out before ’22.
(before anyone complains, the biggest benefit of ECC is actually never needing to run memtest for weeks on end to test borderline faulty ram that could be outed much faster with a proper testing gear only the mfgr can afford…..)
I only like high CRI. Collection:
Fireflies NOV-MU 21 4500k E21A
Fireflies ROT66 219B SW45 D220
Fireflies E07 219B SW45k (all copper)
Fireflies E07x Pro sst20 FA4 4000k (preorder)
Varmint removal:
Convoy M21A C8 ver SST20 4000k (5a)
Convoy S2+ SST20 4000k FB4 (3200ma)
Memes:
BLF GT94
CRI test dump https://drive.google.com/drive/folders/1kcl_uOhgfpR4RSsa8F4b-UUVP9mkL6Cr...
Decent for a budget gaming rig and here’s the difference among the following 3 1660 series card…
GTX 1660 (low)
GTX 1660 Super (medium)
GTX1660 TI (high)
1) GTX 1660 Super sits between the GTX 1660 and GTX 1660 TI
2) The DDR6 video memory is faster than the GTX1660 memory. Same as RTX 2080 TI
3) No RT and Tensor cores. Yes you can do Ray Tracing but it’ll be choppy.
4) 1660 Super uses over 130 watts so need 600 watt and over power supply
WROOOOOONG
130 watts is nothing. You can literally add up an estimate of how much power you need, and it’s not likely going to be over 650w for any single card system on the market. Unless you got one of those exotic new 400 watt cpus they’re coming out with soon.
I’ve never seen my 2080 Ti pull over 50% from a 1080w rated UPS (700w psu), furmark cpu/gpu burn puts it up to 44
Generally speaking, a /good/ 500W PSU will power anything you throw at it. There’s a lot of falsely rated stuff out there though.
https://imgbox.com/3dJXUQ9G
Varmint removal:
Memes:
BLF GT94
If you don’t want to build it yourself look for local shops like “microcenter” you can map out parts and etc on PC part picker and have Microcenter put it together for you locally for a very modest fee so IF something happens to any of the components you can bring it in for warranty without hassle of mailing it out etc.
Yeah sounds good.
I was just approaching this topic with the idea of efficiency today and in the future.
1) At half PSU load, the PSU will be the most efficient.
2) If you’re gonna over clock your GPU or processor in the future, then it’s better to get something beefy.
Good idea, right there!
Choosing parts ain’t really difficult either and we can help. First thing would be about what games you are going to play? Or maybe more important question would be your max resolution? Full-HD enough? 4K? 8K? After that its easier to choose motherboard, cpu, memorys and everything else like how much ssd you need? What about those NVMe SSD. I’m going to get one that for my future build for Win7 ultimate go theres and maybe few regular ssd’s for games. Choosing good GPU and and after that just choosing good power supply, dont’t save on this. Buy good quality, golden stuff! Then choosing right coolers. It’s kinda easy though even though there are lot of parts, but good parts for certain builds are less so easier to choose/compare etc.
I don’t know that much about computers or these newest parts, but I have builded atleast few pc’s in my past, also I’m a bit intoxicated right now.
Sadly you’ll have to pay a premium for a decent GPU due to the current mining craze and overall low supply. Getting a pre-built might be the only way to get a GPU at a reasonable price.
I received a phone call from the repair shop.
I think they were able to fix my gaming laptop.
I'll probably be picking it up later today.
I still might want to get a gaming desktop, but time is no longer of the essence.
That means I can get a custom made desktop from cyberpowerpc instead of buying a pre-built system.
And, yes, I still do not feel comfortable building my own system even though that path is probably cheaper.
Thanks for all of the advice so far!
You can toss together a build on pcpartpicker.com and have it check basic compatibility. High speed Memory still needs to be checked against the motherboard qvl. Ddr5 would be great to have but like others have said it’ll be a while before that’s on mainstream platforms. If you didn’t mind buying used you might find deals on today’s hardware when people upgrade platforms for the ddr5 stuff in a couple years, just use new hdds just to be safe.
ZL SC600w III HI - ZL H600Fc IV - BLF Q8 - D4S - D1S - Reylite Ti Lan AA - Olight i3E EOS - BLF FW3A - BLF LT1 - BLF LT1 - Olight S1R Baton II - Olight Perun mini - Olight i1R 2 EOS
I picked up my laptop, and they fixed it.
The repair company also cleaned it inside and out, so it looks really nice.
I wish I knew someone locally that wanted to buy an older gaming laptop.
(I don't want to ship it anywhere.)
I think I will wait some months/years to get a gaming desktop.
They're selling for a premium right now, and I'm hoping the prices will eventually go back down.
