Anyone know if this charger/ powerbank is compatible with Olight 18650 batteries? Specifically the batteries for the warrior mini, with both the pos & neg on the head of the battery, and the plastic ring around the button top.
I can't tell from online pics if the pos terminal in the Xtar will reach the Olight 18650 button top or if the plastic ring will interfere.
Reallllly specific question I know, but I know someone around here has the answer, you guys never let us down lol.
Thanks in advance!
If it doesn’t reach or the ring is an issue then use a neodymium magnetic maybe
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
The nipples on the PB2S at the top are just under 1mm long.
Does the Olight 18650 button top recess lower than that?
https://www.bmengineer.com/2019/09/xtar-pb2s.html
Now that I took a better look at the battery (instead of going from memory) The button is actually taller than the ring. Must have confused this battery with another... I think the Xtar will work
You just buy some Samsung 50Es for cheap from Illumination and have 10Ah of capacity for hurricane season in a couple of months.
Chris
FYI the PB2S charges at 2A, which might be high for some uses. A 5W USB wall charger will limit the current if necessary and the PB2S won’t complain.
