V4 of my B17 17mm boost driver, success finally!
51 posts / 0 new
Mike C
Mike C's picture
Last seen: 5 min 45 sec ago
I’ve been at this for a while, a 17mm boost driver for all switch types using my own firmware. My first version was based on MP3429 and ATtiny1634 but I never got it fully functional, I posted some pics here: https://budgetlightforum.com/comment/1464140#comment-1464140
My previous version was with the ATtiny3217, it’s the same size as the 1634. It’s a little too big to have on the spring side so I had it on top side and just squeezed it on but that meant having the inductor a little too much off center. That caused the power traces to be a little too small and the driver maxed out at just under 30W. I still considered that a success as the MP3429 datasheet specifies 30W is max supported average, but Loneoceans was able to get 50W out of his driver. He did use the MP3431 but the datasheet specifies same max 30W average. By this time I took my long break from all this light stuff, but now since I’ve returned back at it I wanted to give this another go.
So I replaced the 3217 with the smaller 1616 and moved it to the back side. This allowed me to move the inductor closer to the center and have fatter power traces. I also replaced the MP3429 with a MP3431. Besides supporting both clicky and momentary switches, the main difference with my driver compared to loneoceans GXB172 is that I use the DAC instead of RC filtered PWM. The DAC can use 2.5 VREF so my output can be precisely controlled without using a LDO to fix the voltage on the output pin. I’ve also used 0603 size for the smallest passive components, I can’t stand working with 0402 size.
MCU on the back, and I just manged to squeeze in thefreeman’s “high dynamic range” solution for stable low to moonlight modes (https://budgetlightforum.com/comment/1739319#comment-1739319). I use a small charge pump IC to drive the FET gate.
I hooked it up with a XHP70, current sensing and high dynamic range system works so it’s time to crank it up and see what it can do:
I wasn’t quite expecting these numbers, or the smoke! I just managed to take the photo before the LED MCPCB unsoldered itself from the wires. I’ve wanted to match Loneocean’s 50W on a 17mm board since I started with this boost driver and I finally made it, 9 amps at about 7 volts is over 60W (cheap clamp meter measured), that will do fine. I didn’t hit the roof either, if I swap out a resistor in my DAC divider I might be able to squeeze out some more. I did use parallel cells for this test so that a single cell wouldn’t be a limiting factor.
I’ve also designed an built the exact same driver around the TPS61288. It worked nicely but I accidentally shorted the output before I could crank that one up, I have to make another one.
Ultimately I’ll settle on one of the BOOST ICs but my WATT addiction will probably go for the MP3431 driver as it has passed the switching current limit of the TPS61288. Anyhow, now I finally have a driver to motivate me to finalize my firmware, I have hardly touched that stuff since coming back to this.
Edit: Credit where credit’s due, a big thanks to Loneoceans who has been extremely helpful with explaining things about his driver, patiently answering all of my questions, and to thefreeman for the “high dynamic range” schematics, I would not have thought of that myself.
Edited by: Mike C on 04/08/2021 - 05:00
Sunnysunsun
Sunnysunsun's picture
Last seen: 12 min 51 sec ago
Wow, impressive. That looks like a really tight squeeze onto a 17mm driver!
Mike C
Mike C's picture
It sure was a lot of component shuffling before finding a design that could fit it all.
Scallywag
Scallywag's picture
Last seen: 30 min 52 sec ago
Impressive stuff. How large is the spring pad? I’m a bit nervous around cramped double-sided drivers after I killed one in my Old Lumens project…
Thanks for using 0603 though, in case I ever build one.
agTac D25C TiL6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special |
Agro
Agro's picture
Last seen: 2 min 33 sec ago
Congratulations Mike. Smile
Quadrupel
Quadrupel's picture
Last seen: 1 min 20 sec ago
Congrats! There is no limit to improvement.
2A
Last seen: 1 hour 26 min ago
congratulations. good looking driver, looking forward to seeing it in a flashlight soon.
Mike C
Mike C's picture
Thanks guys. If I had been a little less stubborn hanging on with the 3217 I probably would have had it done a long time ago. Good thing is that 1616 code is 100% identical to 3217 code if using the same pins, just copy and paste and it’s good to go.
It’s 5mm. I think I could increase it by maybe half a millimeter by moving some components a little, but I don’t think it makes much a difference. Cramped like this is not ideal, but for me 17mm is the holy grail size for high power boost drivers. I have a bunch of hosts that use 17mm drivers, and it’s always easy to make a bigger driver than a smaller one.
If anyone wants to build one I can make the PCB available for purchase on OSH Park and provide BOM. However, it requires you to familiarize yourself with the new 1-series MCUs, it’s a different flashing kit. My firmware isn’t finished yet but all basic functionality is done.
I also have to thank Loneoceans, he has been extremely helpful with explaining things about his driver, patiently answering all of my questions.
Dlux
Last seen: 14 min 58 sec ago
Congratulations Mike! I am glad you are back.
contactcr
Last seen: 7 hours 53 min ago
Just use a custom sized brass/copper button on driver side and make the other spring do double duty.
Marc E
Last seen: 1 day 16 min ago
The tech stuff is beyond me but 60W! I know that’s damn impressive. As is designing your own driver of course.
What’s it going in?
Mike C
Mike C's picture
Thanks. I needed the break, now I’m motivated again.
That’s what I had in mind when designing. I’ve used brass buttons on my previous versions, I put them on during reflow if I intend to install the driver in a light.
Marc E wrote:
What’s it going in?
I didn’t get a chance to test before the LED unsoldered itself. I have to provide cooling for it before I turn it on full blast again, but I do want to find out so I’ll get that measurement soon.
Marc E
Mike C wrote:
Marc E wrote:
What’s it going in?
I definitely want to know it’s max capability is but i meant what host is it going in, what torch are you going to build with it?
thefreeman
thefreeman's picture
Last seen: 8 min 1 sec ago
Very nice Thumbs Up .
2 questions :
Where do you get your brass button ?
Do you get flickering at very low current, <100uA (I mentionned it in my thread)
Sirstinky
Last seen: 2 hours 33 min ago
Awesome! That’s a lot of power in a 17mm driver.
Scallywag
Scallywag's picture
Yeah, brass buttons seems to be the way on crowded drivers. And I agree, 17mm opens up a ton of host options. I think if I want to start putting brass buttons on anything, I’m gonna have to buy a brass rod and cut them to length myself.
How can this be configured for a maximum output current, for example if one intended to use it with XHP35.2 HI?
When you settle on a final design, oshpark and BOM would be awesome!
Mike C
Mike C's picture
Ahh, with “in” I though in current Big Smile I will make some pocket rockets out of some old Convoy S2 and M2 hosts, and I have a bunch of Brynite B158B hosts which have custom pills for wider zoom (https://budgetlightforum.com/node/48112). I plan on building B158B with these drivers configured for 12V and use XHP35 HIs in them, I think I have four of those LEDs laying around somewhere.
I’ve had them for so long, sorry I don’t remember. It could have been intl-outdoor.com but if so they are no longer in stock. I’ve bought so many small bits and bobs over the years, I don’t remember where I got all this stuff from.
thefreeman wrote:
Do you get flickering at very low current, < 100uA (I mentionned it in my thread)
With my MP3431 version I don’t get visible flickering. I use it ultrasonic mode, I haven’t tested the other modes (not automatic). Loneoceans used this mode so I just went with it on mine too.
I didn’t get much testing time with my TPS version before I popped it by shorting LED cables. I have not built another one yet but I will soon enough, I can report my results.
thefreeman
Oh yeah good idea.
JaredM
JaredM's picture
Last seen: 2 hours 5 min ago
We should ask Simon/Convoy to offer the brass buttons in his store. I’m sure he can find a cheap source.
bilakos10
bilakos10's picture
Last seen: 15 min 29 sec ago
Congrats Mike! Great works as always!
thefreeman
Mike C wrote:
With my MP3431 version I don’t get visible flickering. I use it ultrasonic mode, I haven’t tested the other modes (not automatic). Loneoceans used this mode so I just went with it on mine too. I didn’t get much testing time with my TPS version before I popped it by shorting LED cables. I have not built another one yet but I will soon enough, I can report my results.
Yes USM is better for this, as current decreases it decreases the frequency until 20KHz after that it uses forced conduction mode if the current decreases further, the efficiency is not as good at low loads but there is no issue with flicker, also no risk of audible noise (as the name implies)
Mike C
Mike C's picture
My firmware has a configurable max amp setting. It can be programmed when flashing the firmware or it can be entered by config menus with a bunch of clicking. Unfortunately the current accuracy is a little less with the HDR FET, it changes it’s resistance a little, but I think it will be good enough. If very low(moon) modes are not wanted, then the HDR FET doesn’t have to be mounted, and the high power sense resistor can be placed in the low/moon sense resistor’s position. Current control by firmware will be more accurate then. There is a possibility to limit it by resistors, but I don’t think that’s very flexible if the LED should be replaced with something newer later on.
I’ll build another TPS61288 based version and fully test it. If it has flickering like thefreeman reported, then I’ll for sure stick with the MP3431 as it does not have this issue. I do have a bit more functionality testing on the MP3431 too, but if that all checks out it’s ready to go.
JaredM
JaredM's picture
Big Smile
id30209
id30209's picture
Last seen: 3 hours 4 min ago
Whenever i see these drivers all i can say is amazing and how much(?)
WTB Titanium 4sevens 2xAA tube
Scallywag
Scallywag's picture
Oh sweet. That will be fantastic. When you say less accurate, are we talking more than +/- 0.1A? I love my moonlight modes.
Do you expect any clearance issues with retaining rings? I know some of the double-sided 7135 drivers are tough in a S2+
JaredM
JaredM's picture
I’m thinking of a Convoy M2 with a SFT-70 and another with a sliced Nichia 144 R9050
Agro
Agro's picture
Why not Nichia NV4B35AM? I would think it’s better than 144A and would be glad to learn why it’s not. Smile
Mike C
Mike C's picture
When I list the BOM I will at least be able to provide material cost.
Possibly a bit more, I have to do more testing. I also have an idea on how to eliminate the issue while having the FET but so far it’s just an idea. I have to do some research, it could be far fetched.
I just checked with a S2 host, I haven’t opened one of those in ages. The retaining ring would have to be filed out. But I noticed that the pill depth has no chance of fitting the XAL7070 inductor, darn! A lower height one would have to be used, like the XAL7030. I couldn’t find any S2+ host in my drawer although I’m sure I have one or two somewhere.
I checked with a S3, the retaining ring on those is no issue at all, plenty of clearance, but same issue with driver depth. I haven’t done any testing at all with the XAL7030 but that’s something I will have to do as I see some of my target lights won’t fit the XAL7070.
JaredM
JaredM's picture
No proof yet, but I am assuming the smaller package is going to be thermally limited. I also fear they’ve used newer silicone phosphor binders that burn at low temps like the e21a and 219F etc. I really hope I’m wrong and that they can be driven to 40W+ like the 144. For anything but a max power build, I’d prefer b35a for all the reasons I chose against it.
thefreeman
When I designed my driver I thought of using a mux for Vsense :
That way the mosfet is taken out of the total Rsense and doesn’t interfere with it, the gate driver could even be removed.
There are small ones in SC70 package, though I haven’t looked into it much, if possible smaller would be better. I don’t know if they can interfere with the very small Voltages.
It doesn’t need a separate control signal because it can be the same as the one for Q1.
The disadvantage is that it adds one more component (obviously), also now Q1 resistance is added to the circuit and thus incurs additional conduction losses, so maybe keeping the gate driver for a lower resistance would be better.
Yeah height clearance is a problem with many hosts.
The solution I used seems to work well, even though it reduces efficiency at very low levels it’ll still be more efficient than USM at low level. But if you want that crazy output then yeah the MP3431 is a better choice.
Mike C
Mike C's picture
The mux idea is what I was thinking of. I’ve never used one before but I’ve just made a V5 design and managed to squeeze one in. The one I went for is the Texas Instruments SN74LVC1G3157 because it comes in a variety of packages, two of them very small: SON (DSF) 1.00mm × 1.00mm and X2SON (DTB) 0.80mm × 1.00mm.
How it works for these low voltages I don’t know, the datasheet list of features includes “rail-to-rail signal handling” so I assume it shouldn’t be an issue. I don’t know about noise though. I haven’t found anything in the datasheet that suggests this one is a bad choice but I’m all ears. Otherwise I guess we’ll find out.
