✌ LUMINTOP THOR1 THOR II LEP 500lm 1800m Aluminium/ Titanium Flashlight Group Buy - ALIVE!
248 posts / 0 new
a1sealbeach
a1sealbeach's picture
Last seen: 1 hour 11 min ago
Can I still use same code that I received for Aluminum version to buy Titanium?
"Three things you should never break: promises, trust, and someone’s heart.”
Artiet59
Last seen: 6 hours 5 min ago
Any idea on the pricing break for the Titanium Freeme? the raw aluminum sold out.. i guess ill have to grab gray unless Titanium comes in at a stellar price that is a no brainer..
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
Artiet59
Also, thought it was funny - I've never seen so many people so excited for the black version of a flashlight, kind of shocked it was the first one to sell out...
dave1010
dave1010's picture
Last seen: 2 hours 30 min ago
amahoola wrote:
Are the cutouts in the back big enough for additional trits or GITD strips?
Yeah, they should be. They look to be the same size. About 7mm * 1.5mm * 1.5mm
https://davestechreviews.wordpress.com/ / Email: <my BLF username>@gmail.com
leviwhite9
Last seen: 47 min 41 sec ago
Flat tops or button batteries?
I can't seem to find the Samsung 35e in stock anywhere reputable.
I want the best batteries possible for this thing, in both 18650 and 18350.
Photon Master
Last seen: 1 hour 39 min ago
Sweet! Which color?
freeme
freeme's picture
Last seen: 2 hours 19 sec ago
Most likely, i will make a separate PM for Titanium version.
I suspect Ti discount rate will be slightly lesser than Al. We will know by next week.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
freeme
freeme's picture
You don't need super high discharge 18650 battery for THOR. As for 18350, i am using 2yr old batch of Keeppower IMR18350 1200mAh 10A.
freeme
freeme's picture
Turbo Glow bars should fit the slots will minimum alteration? Due to the rounded rectangular shape, it is rather tricky to get precise measurements of them. Therefore, i don't dare to recommend trits until someone has tried and confirmed.
dave1010 wrote:
Yeah, they should be. They look to be the same size. About 7mm * 1.5mm * 1.5mm !{width:40%}https://i.imgur.com/o8NC4Jy.jpg!:https://i.imgur.com/o8NC4Jy.jpg[/quote]
a1sealbeach
Would you send me a Titanium version code when it’s available? Thanks.
cloggy
Last seen: 1 hour 3 min ago
freeme wrote:
You don’t need super high discharge 18650 battery for THOR. As for 18350, i am using 2yr old batch of Keeppower IMR18350 1200mAh 10A.
I can’t seem to find the Samsung 35e in stock anywhere reputable.
I Also use the Keeppower 18350 button top and a Samsung 30Q flat top 18650- both work fine.
cloggy
leviwhite9
Cloggy,
Thanks for the confirmation!
I'll be placing a decent battery order tonight it looks like. Need to see if my chargers can handle the 18350s too... Heh, first light with that style battery so I haven't had any around yet. I'm sure one of my 4-5 chargers will work.
Photon Master
Wow, I didn’t know there was going to be a titanium version. The stonewashed looked awesome. Does the discount code work for it too?
ih8winter
ih8winter's picture
Last seen: 1 day 3 hours ago
Indeed. All Ti versions are stunning.
I’m very interested in Sandblasted.
Photon Master
Definitely me too
leviwhite9
Maybe a silly question but do we know about things like if it's got LVP or do I need protected cells? Battery voltage readout in any way?
I'm looking at getting some unprotected flattop Panasonic NCR18650Bs and maybe a bucketful of the Epoch 18350 1100mAh 9A batteries.
I hope these kinda comments are okay around here. I've been more active in other flashlight communities so I'm still testing the waters here.
Thanks all, and thanks all for making this possible. I'm excited for the day mine shows up to my box! I sure hope there's tracking for the US...
raccoon city
raccoon city's picture
Last seen: 8 hours 29 min ago
I just reported your post.
Comments like that are not allowed on BLF!
Just kidding.
(I see nothing wrong with your post.)  :-)
JasonWW
JasonWW's picture
Last seen: 4 hours 56 min ago
leviwhite9 wrote:
Maybe a silly question but do we know about things like if it’s got LVP or do I need protected cells? Battery voltage readout in any way?
I’m looking at getting some unprotected flattop Panasonic NCR18650Bs and maybe a bucketful of the Epoch 18350 1100mAh 9A batteries.
I’m not familiar with the software it’s running, sorry. I just wanted to point out that the Panasonic B came out in 2012. It’s a pretty old chemistry and has been replaced by the Panasonic GA in 2015. The GA is better in several ways such as 10 continuous output while the B is only 5A continuous output. It can also handle higher charging rates plus more cycles. I’d try to get the GA or similar newer cell like LG MJ1 or Samsung 35E, etc…
ollywood
Last seen: 49 min 54 sec ago
Interested in a titanium one, thanks!
LDIBP
Last seen: 22 hours 37 min ago
Interested in Ti.
leviwhite9
Ah I figured you were just as friendly of a bunch, hell I know there's a lotta overlap.
I'm just not used to this site layout and whatnot and don't wanna jam up a thread too bad with all my junk questions and harassment.
dave1010
dave1010's picture
It has low voltage protection. The manual says it steps down at 3.2V and cuts off completely at 2.8V.
I just ran it on high and after 3 hours it had turned off. Checked the voltage a few minutes later and it was at 3.03V.
I forgot to check the tail cap LEPs though but they’re very low current.
Unprotected cells should be perfectly fine but if you’re leaving it on a shelf for months then unscrew the tail cap.
akhyar
akhyar's picture
Last seen: 13 hours 26 min ago
Can PM me the code for Al and Ti please?
Thank you
Photon Master
I want to buy the titanium immediately. Just got your PM freeme. Ordering now
ih8winter
ih8winter's picture
Thanks freeme,! I got a code and ordered a Ti with some glow rings.
a1sealbeach
I got the code this morning, and I order polished TI. Thanks freeme. Ist LEP ever!
Toglud
Last seen: 2 hours 41 min ago
Hi Freeme.
Can I have a code for the Al version.
Toglud
Order placed.
Thank you freeme.
Photon Master
I ordered the titanium stonewashed. Looks Beautiful
Anyone done any comparisons between this and the Acebeam W10 or W30?
HERBIEVERSTINX
Last seen: 11 min 21 sec ago
Quick question. Which battery does this take? Any recommendations for me?
