Fireflies E07 Copper vs regular differences. (mini review)
8 posts / 0 new
Dalamar
Last seen: 6 hours 22 min ago
Disclaimer: sometimes manufacturers revise. The E07 was bought q2 2019 (and should be a v2), and the Copper was bought q1 2021
1st I noticed was it is filthy and gritty (seems to be copper after looking at the toothbrush I used on it) -> https://photos.app.goo.gl/yuobio9m4QpnEgNP7
Washed that off with some Hornady One Shot lube (similar performance to Frog lube)
2nd thing I noticed, why did they include a regular lanyard? There’s nowhere to put it, the hole on the fins is not good for anything but a string…
https://photos.app.goo.gl/qK9v5jrWPUTYgiGo8
3rd thing I noticed, the beam is a bit more focused (and less smooth) than the original which has 25 deg TIR. Like 10-15% narrower. You can even see the LED looks slightly larger through the optic.
https://photos.app.goo.gl/5Kz8AiwgMGy6ebvu6
Is the optic just farther from the LED? The lens doesn’t look different to my bad eyes.
#4, the switch is tighter (and harder to press – similar to the new buck driver series)
Lastly, just a minor complain, aux and switch LED color weren’t what I ordered, but not worth fussing over.
Update: Got around to taking both apart for a closer inspection. The TIR is unquestionably different, as is the PCB
https://photos.app.goo.gl/dYCwRiDeSd7ePXcn9
I only like high CRI. Collection:
Fireflies NOV-MU 21 4500k E21A
Fireflies ROT66 219B SW45 D220
Fireflies E07 Copper 219B SW45k? (odd/higher lumen bin with lower r9 and higher cct?)
Fireflies E07 219B SW45k
Fireflies E07x Pro sst20 FA4 4000k (mail)
Varmint removal:
Convoy M21A C8 ver SST20 4000k (5a)
Convoy S2+ SST20 4000k  FB4 (3200ma)
Memes:
BLF GT94
Emisar D18 660nm SST20 (mail)
CRI test dump https://drive.google.com/drive/folders/1kcl_uOhgfpR4RSsa8F4b-UUVP9mkL6Cr...
Edited by: Dalamar on 05/04/2021 - 17:39
Marc E
Last seen: 2 days 17 hours ago
As a thought, if you didn’t get the right aux and switch colour (which is something i would personally want sorted) did you get the main LEDs you asked for? I don’t know if there are options but a different LED could account for the difference in beam. Your pic isn’t sharp enough for me to see though they look like quite different tints.
Dalamar
Unmistakeable rosy tint of 219b. they aren’t “on”, the aux emitters are just different brightness
Varmint removal:
Memes:
BLF GT94
Dalamar
I just tested it, specs are very similar to my other 219b’s, but the duv seems lower (maybe from copper body)
Varmint removal:
Memes:
BLF GT94
Dalamar
image host
Odd that was said, considering there was so much paste that lifting the optic revealed a ton on its pegs…
Varmint removal:
Memes:
BLF GT94
Dalamar
Varmint removal:
Memes:
BLF GT94
Limsup
Last seen: 21 min 33 sec ago
Regarding your first observation (gritty tail threads), my NOV-MU (delivered this March) had the same problem. I suspect the tools for making the square cut threads are worn out, causing uneven or gritty edges.
Did lube help? I tried high end grease, but it still felt rough. Only after I used high-grit sand paper to smooth rough edges out, it was smooth.
Dalamar
I didn’t mean the threads are rough, I literally meant they had dark grit in them, used a toothbrush to wash that junk out if i remember right
The nov-mu turns on as you screw the head on, anodization is not conductive…this shouldn’t occur, normally. Nov-mu doesn’t have square threads on the anodized side, you should not be unscrewing the unanodized back end. It’s kinda bizarre they didn’t use square threads on both sides
Varmint removal:
Memes:
BLF GT94
