Hi, guys, this is John from ledbe.com, welcome to order the LED Light Products on our website,
here some newest coupon codes available on ledbe.com
- 10% Off Code For the LED Aluminium Profiles, Code: “ LED-Profile ”
- 10% Off Code For the first order on Ledbe.com, Code: “ Ledbe “
Use the code “ COB “ to purchase any single color COB Flexible LED Strips to get 10% off in July.
Link: COB LED Strips Single Color—-7 Colors Available, DC12V Or DC24V
Use the code “ LED-Driver” to purchase any LED Drivers will get 10% off in July includes the 5 years warranty Authentic Mean Well LED Power Supplies and other Dimmable LED Drivers.
Link: LED Drivers Include Authentic Mean Well LED Power Supplies And Dimmable LED Drivers
Check the LED Music Controller for RGB/RGBW LED Strips, with audio input jack and audio connector, working in DC5V-24V, with 3 or 4 output channels design, max output up to 360W when works with RGB LED Light, the max output up to 384W when works with RGBW LED Light, the side with voice sensitivity dial, the 24keys RF Remote Control included, you can use it to adjust the brightness and change the color-changing style.
Link: DC5V-24V LED Music Controller For RGB/RGBW LED Strips
Silicone LED Channels, 5 meters per reel and cuttable, flexible and bendable, waterproof and dustproof, the inner width is 11mm and compatible with 10mm Flexible LED Strips,
can be used for outdoor linear lighting project in a wet, damp or water location.
Link: https://tinyurl.com/54vsm4nu
4 In 1 LED Controller, you can use as a Single Color or CCT LED Dimmer, LED Controller for RGB or RGBW LED Strips. with 4 output channels, the max output power up to 576W when working in DC24V. there is a dip switch on the left top corner, you can switch the type of LED Light you want to connect to. the 2.4G RF Wireless Remote Control included, you can use it to turn on/off the LED Light remotely, adjust ght brightness, change the static color or dynamic modes, select the control zone and group control. one LED Controller for 4 types of LED Lights.
Link: 4 In 1 LED Light Controller
Recessed Aluminum LED Profiles, the standard length is 1meter and max length 3 meters per piece, can be cut to any length for your project. made of 6063-T5 aluminum alloy material and with silver anodized surface treatment, anti-oxidation resistance and has a longer lifespan. there are 6 types of diffusers available for the various lighting effects, you can choose the Opal Matte Diffusers, Semi-Clear Diffuser and Clear Diffuser. the inner width is 12mm and compatible with 8mm or 10mm Flexible LED Strips, the end caps with wire holes included, easy to connect to the LED Driver to light up.
the LED Alu Profiles have a flanged exterior lip to allow to be sunken into an opening with the flange to ensure a neat finish. you can use them as the main lighting or supplementary lighting under wardrobe, cabinet, kitchen wall, house wall, etc.
Link: Recessed LED Aluminum Profiles
Check 16mm Drywall LED Profile Light With Single Flange, the standard length is 1meter per piece and max length is 3meter, cuttable and you can cut to any size for your project. the inner width is 13.9mm and compatible with LED Strip Lights a width up to 12mm. the LED Drywall Profiles with single flange, and the flange with holes, easy to recessed into 5/8" drywall, floating ceiling, you can use them as linear lighting indoor.
Features:
Product Link: https://www.ledbe.com/16mm-drywall-led-profile-light-with-single-flange
March Sitewide 5% Coupon Code available:
Code: LedbeMarch5%Off
use the code to order anything on our website will get 5% off in March.
Black LED Channels with up and down lighting design, the standard length is 1M and max length can do 6M, cuttable and custom lengths available, there are 6 types of diffusers available for various lighting effects. the PVC anti-skid covers are included, which allows to walk on the LED Channels and not damage the LED Channels. you can install them on the steps or stairs for indoor decoration.
Link: https://www.ledbe.com/up-and-down-black-led-profil-aluminium-for-step-light
Check the LED Strip Housing for 28mm shelf board, with up down lighting design, max length can do 6M and cuttable, there is one type diffuser available, the PC diffused cover for the smooth light output. the inner width is 10mm and 1.5mm, allowing the max-width of LED Strips is 10mm, easy to install and light up.
Link: https://www.ledbe.com/25mm-shelf-board-strip-light-house-with-up-down-li...
The Recessed LED Diffuser Profile with long flange, you can recess into the drywall for interior lighting projects. the max length can do 6M and cuttable, the inner width is 15.2mm and allows the max width of LED Strips is 15mm, recommend installing high-density COB LED Strips as the light source. only PC diffused cover available for the smooth light output.
Link: https://www.ledbe.com/recessed-led-diffuser-profile-with-long-flange-for-dry-wall
