I’m an engineering student and I’m currently building my own high power flashlight.
I’m using the Cree XHP70B-00-0000-0D00N40E1which has the following features:
Vf = 12V
If = 1050mA
Pt = 12.6W
θJA = 0.9°C/W
I’ve already made the driver for this LED but I can’t really find any clear information on how to cool the LED.
I’m planning on using a double sided PCB (dimmensions : 20mm X 20mm) but do I need any aditional cooling?
I will also 3D print the case for the flashlight so little to no heat will be disipated trough the case.
yes, you will need A LOT of additional cooling/thermal mass if you are planning to run the XHP70.2 anywhere close to full power. Enclosing the flashlight in a plastic case (generally a bad idea) means you will have to add thermal monitoring. Check the max junction temp that's allowed for your LED, you want to stay below that or your LED will degrade really fast (and/or outright melt your 3D printed case).
Here is what I did to run a 70.2 in a plastic case.. 1A is not a lot of power so you do not need too much cooling. Use a heat sink and make sure nothing touches the 3D printed plastic with its low softening point. You will need airflow to extract heat out of the plastic if you plan on running the light for a long time since the heat builds with no way to escape.
