【Add a 18350 Tube】Wurkkos HD15/HD15R USB-C Dual Emitters Rechargeable Headlamp(Update)
287 posts / 0 new
Wurkkos Terry
Wurkkos Terry's picture
Last seen: 2 min 2 sec ago
Udpate—HD15R prototype
Updated 20211019
How about adding a 18350 tube for the HD15? Do you notice the update on the tail cap?
Update 20210910
SST20+LH351D
Same UI as HD20
Charging&Discharging
Magnetic tail cap
Dual way clip
Hi BLFers,
Thanks for your paticipation in designing the Wurkkos HD15 headlamp with me, please vote for the emitter combinations
Wurkkos HD15 headlamp will features as below:
1.Powered by protected or non-protected 18650 cell.
2.Dual way clip.
3.USB C charging and discharging.
4.UI same as HD20 UI, so no press and hold for off.
(Press and hold for moonlight startup, click and hold for brightness selection, double click and hold for emitter selection, triple click for battery check, qual click for lockout and unlock)
5.Switch with indicator on the top, not the side for this product, sorry but still fine.
6.Magnetic or non-magnetic tailcap optionalable.
And the most important, still need your opinion on it. Please vote for your favourite ones.
7.Dual emitters with led combination options:
A. LH351D-CRI90-TIR
B. SST20-CRI95-TIR
C. SST20-CRI95-TIR
D. SST20 Red-TIR
E. SST20 Red-TIR
AB, AD, AE, BC, BD, BE, CD, CE
Please click here to vote, and commend VOTED so that more people will see this and generate a good result. We will giveaway HD15 ramdomly to one or more voters, depends on how many votes total.
Wurkkos HD15 design.
【Updated 2021/7/23 】
[Updated on 2021/8/13]
Hi BLF friends,
Wurkkos TS21 Anduril UI is available on Amazon, if you have interest in coupon for 20% OFF, you can buy with the coupon below, if you want to review the product, private message me.
US: 9LOCAQUP “ Amazon US
DE: XHIOQIG9 “ Amazon DE
Edited by: Wurkkos Terry on 01/10/2022 - 02:01
jasontheguitarist
Last seen: 1 day 18 hours ago
Cool. Recent version of Anduril? Also does this use standard Carclo triple optics?
TimMc
TimMc's picture
Last seen: 3 hours 32 min ago
1. Does the USB-C port charge with a USB-C to USB-C cable?
2. Can the USB-C port be used as a power bank for your phone?
3. Is there Anti-Reflective coating on the lens in front of the triple-optic?
4. Are there pins/pads available so that the Anduril UI can be easily updated?
Sirstinky
Last seen: 3 hours 6 min ago
How much throw? What version of sst20 are available? Will it be available with xp-l hi? I would lume ro know if it can also NW charged with USB c to c with power delivery.
maxchaos92
Last seen: 2 months 2 days ago
Will there be High CRI options? Lanyard hole? Always on standby led?
Wurkkos Terry
Good questions. It is the old version of Anduril, but you may update with interface and extra tool. Triple optics refer to the pic other member shared ahead.
Wurkkos Terry
!https://intl-outdoor.com/media/wysiwyg/D4V2/r2.jpg!
1. Does the USB-C port charge with a USB-C to USB-C cable? It can be charge with that, but it will come with USB-C cable.
2. Can the USB-C port be used as a power bank for your phone? Not in this one, we try to make it simpler, to bring the price down, for power bank you may consider Wurkkos HD20.
3. Is there Anti-Reflective coating on the lens in front of the triple-optic? Yes, to protect the optic.
4. Are there pins/pads available so that the Anduril UI can be easily updated? We will leave the interface accessable, so you guys can update the UI according to your taste.
Really appreciate for all your questions.
Wurkkos Terry
Robin Dobbie wrote:
Someone somewhere else shared this one of it.
Absolutely a fan of triple and quad TIR lights. I think if I get another light with a charger built in, I’d rather have the connector behind a screw cap with an o-ring.
Good suggestion, like that idea.
Wurkkos Terry
Beam distance will be around 200m. Maybe farther, you will see when you have one in hand. Cash
Wurkkos Terry
Lanyard hold in the tailcap, same as HD20. If you use Anduril UI, then you an set it on standby led. Regards CRI, you can choose according to your taste.
TimMc
TimMc's picture
Is the optic made by Carclo, LedLink or another brand?
Carclo 10511 Frosted Narrow
http://www.carclo-optics.com/optic-10511
https://www.ledsupply.com/led-optics/10511-carclo-lens-3-up-frosted-narr...
LedLink LL03LU-DMxxL
https://www.ledlink-optics.com/files/uploads/Multi%20Lens.pdf
http://www1.futureelectronics.com/doc/LEDLINK%20OPTICS/LL03LU-DMxxL.pdf
I only ask because it’s nice to be able to play around and swap the optic to produce different beam angles etc. Big Smile
Unheard
Unheard's picture
Last seen: 2 hours 55 min ago
Thumbs Up
Smile, you cannot kill them all.
maxchaos92
Wow I Will love It then,looking forward for some tests Cool
Fescron
Last seen: 10 hours 16 min ago
Yeeessss very nice Big Smile Sounds like I'll get this light Big Smile
Also, what is the driver based on? Just FET or is there a buck/boost/constant current circuit?
swhs
Last seen: 17 hours 40 min ago
Looks nice, bigger version of the FC11.
The design isn’t finished it seems, but what do you expect will the weight with battery but without clip approximately be?
I’m curious as the IF25A with 4x SST20 is too heavy (ca. 166g with battery) for me in daily use, I prefer to use the FC11 though the SST20 4000K has a nicer light colour than the LH351D.
I prefer the UI of the FC11 to Anduril btw. With the IF25A I get too often into stepped ramping or other states that I didn’t want, I will make a general suggestion of this in another post of a different UI that I’m working on which largely avoids such issues.
Fescron
The programming interface should be accessible so with this light it would be possible to flash Anduril 2 or other firmware Big Smile I might do that because the only thing I miss in the FC11 UI is a battery voltage check so I guess Anduril 2 will do just fine. I too get sometimes stuck in settings with Anduril, even though I know the presses sometimes I miss a click and stuff…
Caleb
Caleb's picture
Last seen: 1 day 12 hours ago
Following
Parametrek
Parametrek's picture
Last seen: 8 months 2 days ago
When will it be added to your website?
Try the largest, fastest, most flexible flashlight search engine: parametrek.com
58 brands, 2773 models and still growing!
NEW: US battery database and European battery database
JaredM
JaredM's picture
Last seen: 3 months 4 days ago
Buck driver?
https://fundrazr.com/osturaband
No affiliation, just a fan.
nishayume
Last seen: 1 day 19 hours ago
JaredM wrote:
Buck driver?
Want to know this too
Wurkkos Terry
Flatter than the above optics, therefore it is different. We try to make it as short as possible.
Wurkkos Terry
Yeeessss very nice Big Smile Sounds like I’ll get this light Big Smile
FET, buck driver.
joebob4501
Last seen: 2 weeks 6 days ago
Wait, is it a buck+FET driver? Or is it a FET driver for the actual flashlight and a buck in the USB C charging circuit?
Wurkkos Terry
Any other improvement you would like to see on it?
Wurkkos Terry
It is buck driver.
JaredM
JaredM's picture
Yes.
  1. Matte anodizing or raw aluminum.
  1. The pocket clip. Please use a one way deeep carry pocket clip. Deeper than the current design. Please refer to the new Noctigon KR4 clip:
Notice a few things:
  • The clip reaches the end of the flashlight
  • The starting / open end of the clip has a standoff that allows fabric to easily slide under when inserting it into the pocket.
  • One direction clip. You already have a second mounting groove near the head for reversibility, don’t make a redundant and bulky clip.
  1. Increase the opening of the bezel so that it’s not blocking any light from the optic. Looks like it needs an extra 1-2mm or so in the pic below.
  1. Make 100% sure this optic is compatible / swappable with Carclo 105xx optics.
maxchaos92
Even brass or copper edition would be great, I second the use of standard size optics so we Can use turboglow Inside It Cash
Fescron
The only things “missing” is IMO an/a few AUX LED’s Innocent Other than the powerbank functionality this light seems to have everything I want in a flashlight Big Smile
funwok
Wurkkos: Here is a budget friendly 21700 size light with buck driver.
BLF: Please add everything to make it more expensive.
xD
swhs
Low weight is for me most important but here are a few wishes:
What I miss in the IF25A is that when the battery gets low, high/turbo is then not very bright. I wondered the first time this happened “What is wrong?” And then: “Aha, battery must be low”. The indicator is still green in that case but the battery needs to be charged for full power.
So how about an indicator on the button like this:
- Off: Green, to find it in the dark
- On: green if battery at 100%-30% [ = all ok ] orange if battery at 10% – <30% [ = you need to charge soon ] red if battery < 10% [ = you need to charge now! ]
And to colour: what about a nice gray instead of black anodising? E.g. similar to the gray as used by the Skilhunt E2A, or a colour like sandblasted titanium or sandblasted stainless steel.
And, not really serious for this project of yours, but it would be cool for a high end light, if you are thinking of making such lights: if I can wish anything: USB to not just charge but to program the light Smile
Wurkkos Terry
Thanks for the info, hope we will have such kind very soon.
