Wuben New Product on Sale! E6 Small Steel Cannon!
18 posts / 0 new
WubenLight
WubenLight's picture
Last seen: 1 week 4 days ago
Good news!!! Wuben New product on sale now!!! WUBEN E6 "Small Steel Cannon"
Pre-sale starts Today until April 23rd. A limited number, Pre-order ASAPcool   Learn More - https://bit.ly/3agUaoP
WUBEN E6, commonly known as a "Small Steel Cannon", is a high lumen EDC flashlight. Utilized one piece of OSRAM KW CSLPM1.TG LED, maximum output comes to 900 lumens and 410 meters beam distance. Powered by AA battery and compatible with 14500 series. Due to its exquisite workmanship, it will and must be shocking to flashlight enthusiasts.
  • [Type of Light] Combined with both spotlight and floodlight, one hand operation;
  • [High Power] Max output comes to 900 lumens;
  • [Beam distance] Wide beam throws up to 410m;
  • [Compact size] ONLY 87mm*30mm. Pretty portable and great for EDC enthusiasts.
Edited by: WubenLight on 04/17/2021 - 00:06
2A
Last seen: 3 months 1 day ago
that is a cool light, I was hoping for a stainless steel based on the name though Smile
Cesconetto
Cesconetto's picture
Last seen: 3 days 10 hours ago
waiting for shipment… Love
WubenLight
2A wrote:
that is a cool light, I was hoping for a stainless steel based on the name though :)
Hi friend, the flashlight uses 6061 T6 Aircraft grade aluminum material with anodized finish. Calling this name since it looks like a "Small Steel Cannon". What do you think of it?
WubenLight
Cesconetto wrote:
waiting for shipment... :LOVE:
I believe you would like it! Don't forget to share your feeling on the product thenlaughing
weklund
weklund's picture
Last seen: 12 min 1 sec ago
Just pre-ordered.
... Happy Landings ...
Lightbringer
Lightbringer's picture
Last seen: 4 min 24 sec ago
Nice! Almost same length like E05.
I don’t know if I like the part about being shocked, though. Maybe I can wrap it in electrical tape…
WubenLight
weklund wrote:
Just pre-ordered.
Thank you for your support!
Tendou
Last seen: 13 hours 24 min ago
Doesn’t have USB C charging right?
jimahi
Last seen: 4 hours 29 min ago
Wuben –
Can you please answer these questions:
1. It states that it is compatible with NiMH and Alkaline. Is it FULLY compatible? Obviously, the brightness will be lower vs 14500, but there are some other compatibility considerations:
1a. Does the breathing function work when using NiMH and alkaline?
1b. Does the battery level indicator function work properly when using NiMH and alkaline? Or does it only work for 14500?
Thanks.
Mike173
Last seen: 3 days 5 hours ago
jimahi wrote:
Wuben –
Thanks.
Would like to know about this too..
Thanks WubenLight.
WubenLight
 Hello, there shows the properties of different batteries, please check the picture below for details.
WubenLight
Tendou wrote:
Doesn't have USB C charging right?
Yes, this is an edc that can replace the battery at any time.
TexasToasted
TexasToasted's picture
Last seen: 4 hours 28 min ago
The battery level indicator does not function with NiMH AA cells. I ran my light for 2 hours on a Ladda AA battery and the switch LED stayed blue the entire time. During this run, I turned the light off and back on several times. When the light is turned on, the switch LED illuminates solid blue for about 5 seconds then either turns off or goes back to breathing, if I have breathing enabled. After 2 hours, I turned off the light and it would not turn back on. I checked the cell and it was 1.0V.
The light is still working fine, it just won’t turn back on with a depleted cell.
I’m going to run the tests again, later, to see what happens if I never turn off the light, to see how low the cell gets.
Update- just ran the light with the supplied Li-Ion cell. The breathing light stays blue forever, but at some point between 3.6V and 3.5 V the switch led will turn red on startup only. As long as the light is on, the breathing LED will stay blue, never turn red.
The red, low voltage indicator, only works for Li-Ion cells and only when the light is turned on.
Update- The switch LED does flash red while turned on, with an Alkaline cell that is low.
jimahi
Thanks TexasToasted.
zoulas
zoulas's picture
Last seen: 22 min 23 sec ago
Does it work with alkalines?
MascaratumB
MascaratumB's picture
Last seen: 3 hours 37 min ago
It does:
TexasToasted
Update- I’ve had the light running a long time on Alkaline AA and the blue breathing light has changed to a flashing red light.
If I turn it off, the switch LED goes back to blue breathing light. Turn it on again and I get the red flashing light.
I will have to break out my bench power supply and do some proper testing.
