Battery Pack Cell Identification (18650)
14 posts / 0 new
Hank33
Hank33's picture
Last seen: 8 min 12 sec ago
Long story short, was told from scooter place that battery pack will either be LG or Samsung batteries. So from the photo, label says "S3500mAh". Safe to assume it's the Samsung 35E battery then?
zoulas
zoulas's picture
Last seen: 5 hours 46 min ago
If you trust what it says. It could be a rewrap. You can try measuring the IR and see how it matches the spec sheets.
Hank33
Hank33's picture
Ok thanks but I don't wanna open the battery pack to measure. Actually I found their site label and it does say Samsung 35E so I'm pretty sure it's the 35E one.
Sirstinky
Last seen: 49 min 30 sec ago
35E’s are often copied, so you won’t know unless you measure the cells (dimensions, weight, internal resistance, capacity) and compare it against the data sheet. If this is a reputable manufacturer, then they may be trustworthy.
Hank33
Hank33's picture
Okay I’ll have to think about it. Thanks again. Smile
chops728
Last seen: 3 hours 51 min ago
What are you wanting to do —use as a pack or repurpose the cells
Hank33
Hank33's picture
I’m using it as a pack only. They told me their battery’s that come in only use LG or Samsung. I just wanted to be doubly sure. Smile
chops728
to get those kind of specs it must have 108 — 35Es in it —- must of been pricey
Hank33
Hank33's picture
Yeah quite a few of em in the pack huh. Takes a while to charge em too. But I always charge to 80% anyways so not that bad.
The 60V 21aH 3000w (5A) goes for around $500 USD at aliexpress. It's not that bad I guess. It's gone down in price recently.smile
chops728
I’ve been testing and Repurposing a ton of cells lately —from most of my testing I’d charge to around 90% and only drain down to around 30% —your cycle life should double up
51volt —- 65 volt range
Hank33
Hank33's picture
Hey thanks for the tip and yes I’ve been doing the 80% to 90% charging way. I always charge to 80% though and for longer runs at 90%. About once a month I’ll go 100%. Hmmmm maybe next time if I repurpose, I can still use em for flashlights! Cash
chops728
You’d be surprised how many are still good in your old Pack — sometimes just the Electronics in the pack go bad
bilakos10
bilakos10's picture
Last seen: 17 min 43 sec ago
As said, you can never be sure about who manufacturers a certain cell, unless you measure its exact specifications (and even that can be faked to a certain degree).
Provided that the seller is trusted, I would just roll with it Big Smile
funwok
Last seen: 16 hours 20 min ago
Yeah, agree with bila here. When it comes to batteries a lot of shenanigans are in play. If you can trust your seller then good for you, but remember only because the package says something doesn’t mean the content will be like stated. Wink
See the good old Ultrafire 5000mAh batteries: https://lygte-info.dk/review/batteries2012/UltraFire%20TR18650%205000mAh...
