Test/review of Keeppower 14500 1100mAh P1450C3 (Black) 2020
Official specifications:
  • Voltage: 3.70V
  • Rated capacity: 1100mAh
  • Minimum Capacity: 1000mAh
  • Discharge cut-off voltage: 2.50V
  • Charge voltage: 4.20V +/- 0.05V
  • Standard charge current: 500mA
  • Maximum constant discharge current: 2A
Protected high capacity 14500 LiIon batteries from Keeppower
The two cells tracks fairly well and are not high current cells.
Conclusion
These cells looks like good high capacity 14500 cells.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
Is keepower a real manufacturer or a re-wrap?
The are a distributor, i.e. they buy from many manufacturers and sells smaller quantities to dealers and others. One of their services is to rewrap batteries They run their own line of rewraps, but can also rewrap for other brands.
Hi, sorry to disturb you here. Could you kindly check the PM for testing xtar new charger? Thanks!
