WildTrail WT90 - SBT90.2 1800m+ throw 90mm 3x 21700 With Texas_Ace driver
303 posts / 0 new
Artiet59
Last seen: 22 min 35 sec ago
That battery tube machining / design is awesome!
JordanZHP
Last seen: 1 hour 12 min ago
I would like silver if available!
Texas_Ace
Texas_Ace's picture
Last seen: 58 min 34 sec ago
He is checking to see how long it would take to make more silver since that is what everyone so far has wanted lol.
Artiet59
Thumbs Up Party
Rat
Last seen: 6 hours 7 min ago
In for a RAW.
Will the high drain cells be best for this light? I have 40T’s & 30T’s
PatX
Last seen: 1 week 2 days ago
Looks good! Interested for silver or black.
Artiet59
I didn’t see mention of it, but is there a way to ensure the cell carriers can accept flat top batteries? This way standard high drain / high amp 21700’s (30t, 40t, etc). can be used without the need for solder blobs and, even worse, tac welded button tops. Thanks TA
JaredM
JaredM's picture
Last seen: 2 hours 45 min ago
So two or three thoughts here ..
3p 21700 is a lot of capacity. 2A is okay, but QC or 3A charging would be ideal. C-C should be a must.
I think that with a light this size, carrier based charging is a choice. For use as a power bank, it is nearly a necessity. My recommendation here is for the development of a plastic enclosure for it. Something from PC ideally but whatever is cost effective and can provide enough protection and containment of the cells for safe use and luggage in a backpack for example.
Lastly is my thoughts on how to make these upgraded parts available. I’d suggest shipping the lights as they are now basically, and offering carrier upgrade kits for early buyers at a super sweet price Wink
qandeel
Last seen: 1 day 4 hours ago
Will they include batteries?
 عُمَانْ
sandro
Last seen: 1 week 6 days ago
In for one clear/silver, thanks.
d_t_a
Last seen: 6 hours 37 min ago
Interested..
I wonder how long can it last in Turbo mode typically before starting to stepdown (I understand it’s possible to turn off stepdown in Narsil — will that be ‘still safe’ for the flashlight? (this may make the flashlight too hot to hold though.. but flashaholics probably understand the trade-off..)
zoulas
zoulas's picture
Last seen: 5 min 23 sec ago
When will they go into regular production and not just group buy?
zoulas
zoulas's picture
How does the 3 × 21700 config compare to the 4 × 18650 config in the MF02S?
raccoon city
raccoon city's picture
Last seen: 6 hours 59 min ago
This light looks pretty impressive.
I think the 3x 21700 setup is really smart, though I don't do multi-lithium-ion flashlights.  :THUMBS-UP:
vit55
Last seen: 3 days 18 hours ago
I’m in for 1 silver thanks Texas_Ace.
djozz
djozz's picture
Last seen: 2 hours 8 min ago
If I’m in it will be for a black one. But I’m hot decided yet, it competes my FT03-SBT90.2. That one is between 400 and 500 kcd throw so just half of the Wildtrail, but it is way smaller/lightweight too. Decisions….
Texas_Ace
Texas_Ace's picture
Rat wrote:
In for a silver.
Yeah, high drain cells will work best, although it will work fine with any 21700 to be honest, just lower output naturally.
Texas_Ace
Texas_Ace's picture
Yes, they already accept flat top batteries, this is why they have the FET’s in the carrier for polarity protection, it allows for flat top cells to be used.
Texas_Ace
Texas_Ace's picture
Yes, faster charging would be nice but the carrier charging / battery bank feature is basically a bonus / emergency option, Like always the best option is to charge on a dedicated charger whenever possible. Beefing it up for higher currents is possible but it starts to get much more expensive and bulky when you do that.
Basically there are common charge circuits available for 2A that are proven, compact and affordable. Above that you get into more custom setups as there is a lot less development in higher current mass production.
Along with added complications in the variable QC setup. Honestly I am impressed they were able to fit a 2A charging setup in the space provided. I think they struck a good balance of cost / size / complexity with the setup they have right now.
If people truly feel that the added costs and size of a more powerful charging / battery bank would be worth it, I could see if they could increase it to 3A, I don’t see a variable rate tech like QC being a good idea in a setup like this though.
Texas_Ace
Texas_Ace's picture
I don’t believe so as they already had issues trying to ship batteries to me with the prototype.
Texas_Ace
Texas_Ace's picture
d_t_a wrote:
Interested..
I listed up the results of my thermal test in the OP. Long and short of it, it was ~6 mins until 60C (common step down point) and ran until the cells were dead without overheating the light. Although need to check the specs on the cells to make sure they are rated for 80c if you do that, the cells came out at 75c. The light itself will have no issues running until the cells are dead though.
Texas_Ace
Texas_Ace's picture
Yes, pretty sure they intend to make these a production light.
Texas_Ace
Texas_Ace's picture
I don’t have the MF02S but the 3× 21700 is basically the same size as the GT handle which is 4×18650.
Texas_Ace
Texas_Ace's picture
I was going to try to get some comparison shots with a GT90 last night but I realized, I actually don’t have a working GT90 at the moment. I took mine apart for an optic mod I am working on and it is still in pieces. I only have a GT and GT4 working right now and those are not fair comparisons for this really.
I will try to get a pic of the reflector and LED today.
RobertB
RobertB's picture
Last seen: 14 hours 21 min ago
Personally, I don’t care about GT90 comparison beam shots, but would like to see some on it’s own merits. The GT was too big and unwieldy for my purposes, so I sold it. This one may work better
zoulas
zoulas's picture
I agree, the proportions are better on this one.
Texas_Ace
Texas_Ace's picture
Here are some pictures of the reflector and LED:
zoulas
zoulas's picture
The manufacturing pictures are very impressive.
I cant imagine they make S2+‘s like that and sell them for ten bucks?
Texas_Ace
Texas_Ace's picture
S2+ are made with a similar but much simpler process. They are made with only a lath and in a single machine step I am guessing and they will be made out of tubing to further reduce the machining. Where this light need multiple machines and multiple steps on the machines to finish everything, that really adds up quick.
JordanZHP
2A charging is fine in my opinion. This is a flashlight first, the battery pack feature is a nice bonus.
