WildTrail WT90 - SBT90.2 1800m+ throw 90mm 3x 21700 With Texas_Ace driver
916 posts / 0 new
sarge12
Last seen: 4 hours 3 min ago
Usually bad batteries open when they fail, which would just result in the two good batteries carrying the load. I have never seen a battery show an internal short…can that even happen?
Texas_Ace
Texas_Ace's picture
Last seen: 8 hours 50 min ago
sarge12 wrote:
Texas_Ace wrote:
sarge12 wrote:
Artiet59 wrote:
sarge12 wrote:
Texas_Ace wrote:
MooreDubs wrote:
Direct Paypal payment?
It can be arranged if required. It is a bit more complicated but if you want to do that send me a message.
Just checked the WildTrail out compared to the Thrunite TN42V2. It seems to at least throw as far, if not further, but I have nothing real far away to shine both at yet. I like it better than the TN42V2 so far. It get 2 thumbs up from me so far.
Sarge, I was looking forward to your feedback because I knew you had the through night, awesome to hear that you like this even more! Hopefully mine will be in the next week or so can’t wait
Yes, I would consider those 2 lights performance nearly identical, but only after I modified the TN42 V2 by removing the insulator thread and adding insulator batteries from Thrunite, which allowed me to use orbtronic cells. My one concern with the WildTrail is this. In the very unlikel event of 1 cell of the 3 having an internal short, is their anything built into the carrier to protect the other 2 batteries from being damaged by the shorted one?
If you mean will they over-discharge, most likely, this is an issue with virtually all multi-cell lights.
If you mean will it somehow short out the remaining cells, most likely not, unless it is a catastrophic failure of some kind in which case you have other issues. The most likely outcome is it over-discharging the remaining cells.
Well what I mean is, an internal short of a cell in parallel may become a short for the other 2 as well. When it is shorted internally, would it not then measure zero ohms between the anode and cathode of the battery? If so it will be like putting a wire between the + and – terminals of the non- shorted batteries.
Yes, that is possible, but also a risk with any multi-cell light.
The reason I said unless it is a catastrophic failure above is that if that was to happen, first it will be a dead short of the cell that failed, the other 2 are just collateral damage at that point lol.
In reality most cells die slowly by getting higher and higher resistance so they self-discharge faster.
I have done some really messed up poop to cells over the years and never had one just randomly decide to become a dead short. Had a lot die in other ways though.
This is not to say it can’t happen, it can and does but like I said above, if that happens you already have issues from the cell that failed to worry about.
All of that said, if that was to happen and the full amps were to attept to transfer between cells, it would almost assuredly blow a trace, spring or FET before it could dump too much power into the dead cell. Not designed for that situation but I have had melted springs save me from inserting a cell backwards a few times.
sarge12
Like I said, I have never yet had a dead short in a battery, and have had many with an open condition. I think I might just remove the batteries from the carriage when not being used for over a day to be totally safe. Most of my lights with a carriage carrier have protected cells in them. If not, I do not store them very long in the carriage. That might be somewhat paranoid, but it will be no doubt safer. If such happened while holding it, the body of the light would likely let me know well before the cells vent.
myysteeq
Last seen: 23 min 4 sec ago
Heads up, 18650batterystore has P42As back in stock: https://www.18650batterystore.com/collections/21700-batteries/products/molicel-p42a
I’ve opened a dispute with PayPal over the allegedly fake cells I received from a different store earlier. In other news, my SkyRC MC3000 just came in. I’ll try to report discharge test results for everyone.
My clear WT90 came in yesterday. It’s awesome, as we all know. I’ve already delensed the emitter and bypassed all springs. The deep reflector and gigantic MCPCB made the job much more difficult than I expected.
Artiet59
Last seen: 1 hour 49 min ago
myysteeq wrote:
Heads up, 18650batterystore has P42As back in stock: "https://www.18650batterystore.com/collections/21700-batteries/products/m... ":https://www.18650batterystore.com/collections/21700-batteries/products/m... I've opened a dispute with PayPal over the allegedly fake cells I received from a different store earlier. In other news, my SkyRC MC3000 just came in. I'll try to report discharge test results for everyone. My clear WT90 came in yesterday. It's awesome, as we all know. I've already delensed the emitter and bypassed all springs. The *deep* reflector and *gigantic* MCPCB made the job much more difficult than I expected.
thanks For heads up on molicel P42a, I ordered up my 3 extra
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
Cochise334ever
Last seen: 5 days 13 hours ago
Cochise334ever wrote:
WT90 should be here in the next week. The Reason I say that is K1 was in Avenel, N.J. FOR 4 days….then to my PO.Basically took a week to go last 150 miles…probably customs related.
Above is Partial post of mine…#699.on June 6th.
It is what is…a little frustration is building even though I know what to expect from previous experiences.
Mine has been in New Jersey now for 4 days….150 miles from me.
TA I will apoligize ahead if you are offended.
My little bitch is that this is Not Free shipping…$10 and its still following the same time table as other Chinese purchases that were Free or $2 or something.
My One week prediction from arrival in USA..NJ to me…which would be Monday June 14th may be in jeopardy.
It is out of my control….so I just wait..got my frustration out of the way.
Tom E
Tom E's picture
Last seen: 7 hours 21 min ago
Just fyi, my tracking status sat idle for days, until one day the flashlight simply showed up at the door - it happens. Even for China, shipping costs the seller but sometimes with Ali and others it's rolled into the retail cost.
Cochise334ever
Tom E wrote:
Just fyi, my tracking status sat idle for days, until one day the flashlight simply showed up at the door – it happens. Even for China, shipping costs the seller but sometimes with Ali and others it’s rolled into the retail cost.
Thanks…maybe that will happen today! Big Smile
Texas_Ace
Texas_Ace's picture
Honestly it sounds like it is stuck in customs which they have no control over at all. The only way to speed that up is to use an express shipping method that would cost $50-75 and I doubt anyone would want to pay that. Also those express shipping options generally have much higher Tax/Vat fees as well.
It is annoying but sadly unavoidable without seriously jacking up the cost.
Cochise334ever
Tracking states Cleared Customs on June 7th then picked up by..UPS MAIL INNOVATIONS that same day in Avenel, NJ…went from there to Swedesboro, NJ And been stuck there..4 total days in NJ.
USPS still awaiting item.
Texas_Ace
Texas_Ace's picture
I would not put a ton of weight on what the scan says about clearing customs, I have seen packages say they cleared customs only to be scanned again later at customs many times over the years.
That said who knows what the issue could be, the list is too long to count lol.
It sucks but don’t worry, it is on the way.
Artiet59
WT90 should be here in the next week. The Reason I say that is K1 was in Avenel, N.J. FOR 4 days....then to my PO.Basically took a week to go last 150 miles...probably customs related.
Above is Partial post of mine...#699.on June 6th. It is what is...a little frustration is building even though I know what to expect from previous experiences. Mine has been in New Jersey now for 4 days....150 miles from me. TA I will apoligize ahead if you are offended. My little bitch is that this is Not Free shipping...$10 and its still following the same time table as other Chinese purchases that were Free or $2 or something. My One week prediction from arrival in USA..NJ to me...which would be Monday June 14th may be in jeopardy. It is out of my control....so I just wait..got my frustration out of the way.
Honestly it sounds like it is stuck in customs which they have no control over at all. The only way to speed that up is to use an express shipping method that would cost $50-75 and I doubt anyone would want to pay that. Also those express shipping options generally have much higher Tax/Vat fees as well. It is annoying but sadly unavoidable without seriously jacking up the cost.
Tracking states Cleared Customs on June 7th then picked up by..UPS MAIL INNOVATIONS that same day in Avenel, NJ...went from there to Swedesboro, NJ And been stuck there..4 total days in NJ. USPS still awaiting item.
I would not put a ton of weight on what the scan says about clearing customs, I have seen packages say they cleared customs only to be scanned again later at customs many times over the years. That said who knows what the issue could be, the list is too long to count lol. It sucks but don't worry, it is on the way.
Ive been following this back and forth, and I CAN TOTALLY RELATE lol...
But also, i will second TA here - I would put Zero stock in it saying that it has already "cleared customs." I have had them state that, then go back into "customs" allegedly. I have also had Alix and BG orders say they were delivered at my house, then the next day change back to they are in NJ waiting for USPS (that was a long day waiting to see if someone just stole my light off my deck ...).
I was most anxious for my light to ship, now that it has, i understand the lack of control and the waiting game of the shipping carriers. mine shipped 12 days ago, no USPS pickup yet, i havent been able to get a reading on parcelsapp.com in 5 days since it hit the US, supposedly.. but I'm not worried. i understand that the "reporting" of the postal service and customs and all of that is weird in this stage of shipments coming from china. I am just expecting it to show up sometime in the next 2 weeks (i am only about 200 miles form Avenal, NJ too). All will be good @Cochise334ever
EDIT: now, if it was a month of being stuck in Avenel NJ or customs, yes i would be worried lol.
Cochise334ever
I hope you are right. I talked to the United States Postal Service and they told me to call UPS. They’re the company that hands it off to the United States Postal Service. UPS told me the package was lost and to start to file a claim. They tried to blame it on the United States Postal Service and they don’t even have the package yet. So I’ll wait and I’ll hope that it shows up on my doorstep.
Texas_Ace
Texas_Ace's picture
Yeah, a package getting misplaced happens way more then you think. It could be lost for real but I would give it a week or so and see what happens. A lot of delayed packages were “lost” at one point.
If it has still not shown up next week I would indeed start the claim process. Contact wildtrail and they can file a claim on there end as well.
Cochise334ever
At TA.
I bought it off of AliExpress what does wild Trail have to do with it if I have to go that Avenue? I couldn’t find any information on that company.
I’m just going to wait now. But if you could give me that information I would appreciate it just in case I need to use it. I would think UPS is still responsible. But I know it’s going to be a big headache and a bunch of BS between the post office and UPS if it indeed is lost.
Robin Dobbie
Last seen: 13 hours 1 min ago
Anytime I can recall having a package delivered with UPS mail “innovations” involved, it was slow with a several-day wait at one location in tracking. Domestic order.
I just got something yesterday that I wasn’t expecting for another 3 weeks. Tracking never showed a thing. Banggood.
My last order from Aliexpress had an item arrive early and tracking gave up days earlier.
My last ebay order, same thing. Early arrival, tracking useless.
Texas_Ace
Texas_Ace's picture
At TA.
They would simply be filing a claim just like you only from the senders side.
Things have changed a bit but when when I used to ship 5-10k packages a year they pretty much always needed the sender to be part of a claim. I think those rules have relaxed now but it won’t hurt anything to have them file a claim as well (technically it would be the same claim really).
Cochise334ever
At TA.
I am Not clear on Who “They” are? WildTrail? Aliexpress?I have no info on Wildtrail who you recommended me to also file a claim?I asked for that info in my previous message.
I used a credit card not Paypal. I will wait until Wednesday then call my bank and have them get my money.
I am hoping it shows up..if not I will fight whoever I have to fight to get my $180 back.
I.lost out a few years ago when Paypal said I had to pay for return shipping to Banggood for a defective light….$70 to ship back.Never shipped it back..lost $100 .
..Thanks
Cochise334ever
Thanks for sharing your experience and giving me hope!
The other side of that is Tom E.and some others who live in Eastern USA already have had theirs for at least 4 or 5 days.I would think they paid the $10 shipping and used the same UPS Mail innovations.
Hopefully half the crew got drunk Beer Beer Beer and called in sick..and its just delayed!
Texas_Ace
Texas_Ace's picture
I am not sure what your issue is to be honest? You seem far to upset for it just to be a late arrival of the order, I have not been able to read this thread as much as normal, did I miss something, is there something else that is upsetting you?
Far as I know at this point the package simply has not been delivered at this point and UPS said it might be lost?
This is a really straight forward issue, it is normally solved by simply waiting. Worst case you file a claim with UPS and wait a bit longer and then wildtrail gives you the option to resend it or refund you.
There is positively zero need to file a paypal claim, wildtrail will take care of you be that ship another or refund you for this one.
You will not loose your $180, that much I am sure of.
Let me know if I am missing something.
P.S. I have ONLY been talking about filing a claim with UPS, a paypal claim is completely unnecessary at this point. In retrospect I think you might of been misunderstanding me.
Cochise334ever
1.Yes..you are missing Two things. I asked you twice about Wildtrail.You mentioned in previous message that I should also file a claim with them if I need to if it doesn’t show up. Who is wild Trail besides the flashlight? Is that you?I never got their info from you.
2.If you re-read my post I said I did not use PayPal so I am not filing a claim against PayPal.I used my bank… credit card.
So yes at this point there’s nothing to do but wait and then I’ll do what I have to do. Thanks
Texas_Ace
Texas_Ace's picture
Different countries generally get mail faster or slower.
The USA has special shipping arrangements with China so we generally get faster shipping them most due to that.
Texas_Ace
Texas_Ace's picture
Ok, as I thought it was a simple misunderstanding.
I was only talking about a claim with UPS about a lost package. You are the receiver, wildtrail is the sender from aliexpress (aliexpress is the china ebay BTW)
I was saying you could contact wildtrail (send a message to the seller your ordered from on aliexpress) and let them know UPS said the package was lost so they can also file a claim with UPS.
Generally takes a week or 2 for them to get a trace on the package. If it is lost, they will offer you a replacement most likely or a refund if you want that.
Although at this point I would give it a bit longer before worrying about it. My rule of thumb is a month for anything from china before worrying.
Cochise334ever
I checked my order I have to wait until August 10th, 2021 to file a claim that its lost! Lol.
Nothing more to say.Next post will be if my light appears or on August 10th!
Signing off
Texas_Ace
Texas_Ace's picture
Signing off
As I said, contact wildtrail next week and let them know that the package might be lost, they can start a claim with UPS then and get the ball rolling.
The claim with aliexpress is completely separate and different. That is a claim about the order, not the package.
Aliexpress is just the china ebay. You can talk to the individual seller and are encouraged to in cases like this.
There are only a handful of times out of the ~10,000+ purchases online over the years that I was not able to work something out directly with the seller without involving any kind of claims or governing bodies.
Artiet59
  I hope you are right. I talked to the United States Postal Service and they told me to call UPS. They're the company that hands it off to the United States Postal Service. UPS told me the package was lost and to start to file a claim. They tried to blame it on the United States Postal Service and they don't even have the package yet. So I'll wait and I'll hope that it shows up on my doorstep.
@ Cochise334ever, just to give you a little peace of mind- I am from CT, a couple,hundred miles from NJ, and my light has had no update whatsoever since june 7, I have no idea when mine is due. and on top of that my light shipped 5/31 which I felt like was a week after most everyone else. Aggravating - yes! A little, but not really
But, no reason to panick, I mean I'm not trying to say you are, but I feel like when you contacted the usps is where things got tense here. I feel like the UPS most definitely jumped the gun telling you the package was lost and blaming the usps.
all of that to say, I know it's aggravating when there is an eta ship date, but It doesn't surprise too much when these flashlight orders from China start going passed that eta date.
I think if you and I both wait another week or so, we will have good news and hear about our order coming in. I know I praised wildtrail and TA in this thread a lot , but I'm being honest. I am pretty certain your and my packages aren't lost, just delayed, I had this exact situation happen with a recent FireFlies release, took 6 weeks to ship to me, I was probably one of the last people to receive the new light.
 Oh, and just for general information- wildtrail is the manufacturer just like astrolux or FireFlies. The model of the light is the wt90, and TA just helped design it with the design team and employees that work for wild trail.
sarge12
Rayoui wrote:
Try performing a factory reset on the one that’s misbehaving.
I had an issue with a NOV-Mu which was acting strangely after a cell swap due to poor anodization on the threads causing the light to power on and off many times very quickly while removing and replacing the head. A factory reset cleared it up. Now when I switch cells I slightly unscrew the head to remove power, then remove the cell via the tailcap (which has unanodized threads). Not ideal but it works.
I don’t have any issues toggling back and forth between simple and advanced UI but I can see how it could be frustrating. To be fair, that isn’t really Fireflies’ fault; it’s the default behavior for Anduril 2.
I finally took your advice for the factory reset….Not sure if it fixed it, but looking good so far. The 10 click issue was once again difficult, but finally got it back into advanced UI. Hopefully, my issue with this light is gone, but only time will tell. Thank you for the suggestion, even if the issue returns.
Tubercle
Last seen: 9 hours 59 min ago
Got my light. It’s amazing. Everything’s perfect, beam pattern is perfect. Battery carrier and charger works perfectly. Hydraulic-feel when you take or put in the battery cage into the tube. Good milling on the handle for grip. For $175$ + tax shipped this is absolutely amazing and blows everything else on the market out of the water. If this was made in the USA or made by a name brand would easily be $250++ and probably not as good.
Thank you our Chinese overlords for actually able to factory-produce gadgets and knives worth shit and doesn’t cost an arm and an leg and thank you TA for designing the light.
Funny how some ppl’s still whining about paying $10 for shipping and expect it to be DHL express-lvl service. No it’s just to cover their usual shipping costs. $150 base price for the light is so dirty cheap they probably don’t make much margins at all. FYI I paid $24 for shipping + 13$ tax.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 22 min ago
The SBT90.2 Family…
KB1428 “Live Life WOT
Texas_Ace
Texas_Ace's picture
I like how the silver stands out from the pack.
