Keeppower 26650 5200mAh P2652U (Blue-white) 2020
Official specifications:
- Voltage: 3.60V
- Rated capacity: 5200mAh
- Minimum Capacity: 5100mAh
- Discharge cut-off voltage: 2.50V
- Charge voltage: 4.20V +/- 0.05V
- USB Charge voltage: 5V +/- 0.5V
- Standard charge current: 1000mA
- Maximum constant discharge current: 8A
%202020/Keeppower%2026650%205200mAh%20P2652U%20(Blue-white)%202020-info.png)
A USB rechargeable LiIon 26650 battery from Keeppower.
%202020/DSC_4229.jpg)
%202020/DSC_4230.jpg)
%202020/DSC_4232.jpg)
%202020/DSC_4233.jpg)
%202020/DSC_4234.jpg)
%202020/DSC_4235.jpg)
%202020/DSC_4236.jpg)
%202020/DSC_4237.jpg)
%202020/Keeppower%2026650%205200mAh%20P2652U%20(Blue-white)%202020-Capacity.png)
The two cells tracks nicely and can deliver above 10A before the protection kicks in, capacity is nearly constant at all loads.
%202020/Keeppower%2026650%205200mAh%20P2652U%20(Blue-white)%202020-Temp-7.0.png)
%202020/Keeppower%2026650%205200mAh%20P2652U%20(Blue-white)%202020-Temp-10.0.png)
%202020/Keeppower%2026650%205200mAh%20P2652U%20(Blue-white)%202020-CapacityTime.png)
%202020/Keeppower%2026650%205200mAh%20P2652U%20(Blue-white)%202020-Energy.png)
%202020/Keeppower%2026650%205200mAh%20P2652U%20(Blue-white)%202020-PowerLoadTime.png)
%202020/Keeppower%2026650%205200mAh%20P2652U%20(Blue-white)%202020-TripCurrent.png)
%202020/Keeppower%2026650%205200mAh%20P2652U%20(Blue-white)%202020-Charge.png)
Conclusion
This is good looking 26650 batteries with good of capacity, protection and USB rechargeable
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Thanks for the testing!
Recent Reviews: Best Flashlights for Light Painting Photography 2022 // Battery and Charger Buying Guide 2022 // Olight Array 2S Headlamp // Acebeam E70-AL CRI95+ // XTAR VC4SL Charger // Sofirn D25LR Headlamp // Convoy T4,S21D,M3-C // Sofirn IF22A // Ants on a melon RGB Critter
Affiliate links: Olight AU // Olight USA // Acebeam
Instagram: @stephenk_lightart
