haikelite mt09r turbo mode not working
12 posts / 0 new
lightboy112233
Last seen: 1 month 1 week ago
Hi everyone, I bought a new Haikelite mt09r my device is working normally but Turbo mode is not working please anyone can help ?
Edited by: lightboy112233 on 05/08/2021 - 11:49
sp5it
sp5it's picture
Last seen: 5 min 39 sec ago
Cells can handle current consumption on turbo? Unprotected cells?
If it is new, contact seller and replace with working one.
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
 If a lot of people listen to Slayer, the world would be a better place to live" - Tommy Wiseau
lightboy112233
I do not know the suggested values from which cell I should use. Can you recommend one?
sp5it
sp5it's picture
US18650VTC6 30A button top for example.
lightboy112233
Thank u so much my dude. U helped a lot.
lightboy112233
my battaries protected . I guess protected battaries is not suitable for turbo mod am I right ?
sp5it
sp5it's picture
Not at all.
mortuus
mortuus's picture
Last seen: 19 hours 2 min ago
stay away from that brand, bad quality overall.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Funtastic
Funtastic's picture
Last seen: 2 min 11 sec ago
Not exactly a helpful suggestion when someone already owns the light. He was using protected batteries, not an issue with the light itself Smile
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
d_t_a
Last seen: 7 hours 47 min ago
Protected batteries are meant to protect the battery from giving too much power to the device using it (depending on the protection, I’ve seen protected 18650s that trip at a low 3 Amps current, with most I’ve tested that trip at 6 Amps. I think some trip at 8+ Amps — I’ve not been able to test some higher ones since I’ve read about those protected high-drain 18650s but don’t have one — usually more expensive flashlight-branded rewrap).
The MT09R will need a lot of power in Turbo mode, I’m not sure how much, but will likely draw more than 6 Amps of power per battery, thus Turbo mode will blink once then shut off the battery.
Lightbringer
Lightbringer's picture
Last seen: 12 min 21 sec ago
Yeah, the ’09R is the only light that I feed with VTCsomethings. 5, 5A, 6, forgot.
I figured it needs beefier cells to make the most use of the brighter end of the scale.
I really should use protected cells (4S), but I think mine are nekkid. I just don’t draw it down too much without topping off.
CR888
Last seen: 15 hours 3 min ago
This is the 3×21700cell pop can size 4x SBT90.2 25ish thousand lumen powa-sukka! Yeah I’d get the highest max discharge unprotected cells I could find. I don’t find it surprising turbo doesn’t work with protected low discharge cells. Samsung 30/40T’s? Molicell 4200/Vapecell INR21700 30Amp continuous discharge. Maybe the Sofirn 4000mAh 40Amp cell. I’ve wanted this light for a while now…the $500 price tag had made me really think about it.
CR888
