Help needed with Lanyard
9 posts / 0 new
Rat
Last seen: 1 week 1 day ago
Hi people
I need to make a lanyard for my FW21 pro (I just love this light) But do not have a clue how to do it so if anybody knows how or has any links that would be great.
I did a search but could not find anything that shows you how to make one when having no hole to go through. I do not use the clip so it needs to go around the body and I would like to use one bead.
thx
mitsuki08
Last seen: 2 hours 24 min ago
Try using a clove hitch or a partial turks head then just tie the ends together? The clove hitch is simpler but the turks head feels more secure.
MascaratumB
MascaratumB's picture
Last seen: 19 min 40 sec ago
Hum, I would suggest picking some paracord (or a different type of thread) and making a lanyard around the flashlight tube.
The “turks knot can be a start, but the simpler “cobra knot” can also work!
Hope it helps Wink
pennzy
pennzy's picture
Last seen: 8 hours 42 min ago
A search in the Q8 thread should bring some ideas up.
https://budgetlightforum.com/node/65229
https://youtu.be/gwslNOmFleM
lampliter
lampliter's picture
Last seen: 3 days 18 hours ago
Try paracordplanet.com
It's only true if you believe it.
Rat
Thanks guys the Constrictor Knot/clove hitch knot did the trick to start it off. That’s what I was stuck on.
It turned out OK for my first lanyard.
thx
TIFisher
Last seen: 15 hours 28 min ago
Classy…I like it!
Just curious, as the tag end is out of frame, did you create a loop to run your hand through, or is it more of a “fob” with no anchor loop?
Nice work.
NeutralFan
NeutralFan's picture
Last seen: 1 day 7 hours ago
Looks very nice Rat!
I’d rather use my flashlight around the house than turn on the lights.
Rat
TIFisher wrote:
Classy…I like it! Just curious, as the tag end is out of frame, did you create a loop to run your hand through, or is it more of a “fob” with no anchor loop? Nice work.
No loop just two ends. I measured the skull so it fits perfect between my fingers for a good fit.
So I ended up starting with the clove hitch knot for a nice tight secure hold then snake knots finished with the diamond knot.
Have your guy got any to show?
I just ordered a new bead so will try some new (harder) lanyards.
Pirate chain
