LEP Modul
10 posts / 0 new
Xandre
Xandre's picture
Last seen: 1 day 1 hour ago
LEP Modul
We bought 3 LEP Moduls from Ali
and do some tests.
It is written in German,
but datas are international:
https://www.taschenlampen-forum.de/threads/lep-modul-600-lm-tlloe01.81906/
Thanks @ sma and Andi
Regards Xandre
Henk4U2
Henk4U2's picture
Last seen: 14 min 56 sec ago
Nice work! Any ideas how to proceed from here?
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
cyberpunk
cyberpunk's picture
that looks cool
djozz
djozz's picture
Last seen: 50 min 6 sec ago
Can those modules be driven with the same drivers we use for flashlights? I know that the voltage is a bit too high for 1 li-ion, but apart from that, are lasers any different from leds to drive?
pinkpanda3310
pinkpanda3310's picture
Last seen: 19 hours 13 sec ago
Cool Cool
I love to buy one of those and make an lep host. Maybe one day….
Xandre
Xandre's picture
Yepp
the same drivers but I am not an expert .
2 S is good,the LEP needs 4 Volt.
Regards Xandre
The_Driver
The_Driver's picture
Last seen: 2 months 5 days ago
We bought modules without a pre-collimator lens on the phosphor. This makes them suitable for use with a reflector. Because of the small size of the emitting area (0.25mm2 i.e. one quarter of the size of a white flat1) you need a precise reflector to really make use of theses modules (electroformed reflectors and glass reflectors are probably needed).
The luminance of these modules is similar to that of a white flat LED with wavien collar. The benefit is that they are easier to use in a flashlight because there is no collar to align and large metal precision-reflectors are cheaper and much lighter compared to large glass precision-aspherics.
Xandre
Xandre's picture
We use this driver for testing:
http://www.mtnelectronics.com/index.php?route=product/product&path=67_11...
and it works well
max 4A and the phosphor is still alive
but we made only short tests max 30 seconds @ 4A!
Most important is the heat transfer.
We pressed the modul in a cooper “heatsink”
https://www.taschenlampen-forum.de/media/img_20210423_205023-jpg.34053/full
Without heatsink the modul reached
100 degrees @ 2,5A within 4minutes
Regards Xandre
JaredM
JaredM's picture
Last seen: 2 hours 43 min ago
Two words. Awww sum Thumbs Up
Sunnysunsun
Sunnysunsun's picture
Last seen: 51 sec ago
Neat stuff! This is probably the diode inside those modules https://sites.google.com/site/dtrslasershop/home/diodes/nubm08-455nm-4-3...
The bottom of this page gives instructions on driving a laser module. I’m not sure which ones are mandatory and which are best practice for longevity. https://sites.google.com/site/dtrslasershop/home/laser-drivers
