Keeppower 16340 800mAh P1680U (Blue-white) 2020
Official specifications:
Voltage: 3.60V
Typical capacity: 850mAh
Minimum Capacity: 800mAh
Discharge cut-off voltage: 2.50V
Charge voltage: 4.20V +/- 0.05V
USB Charge voltage: 5V +/- 0.5V
Standard charge current: 330mA
Maximum constant discharge current: 1.8A
A LiIon 16340/RCR123A that can be charged from USB.
The cells matches nicely and can deliver the rated 1.8A with not that much capacity loss.
Conclusion
This looks like good 16340 cells with fine capacity. The basic cell is smaller than standard unprotected 16340, for this reason the final cell is only 2mm longer than the standard for 16340 cells.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
