LEP Real World Uses
66 posts / 0 new
xevious
xevious's picture
Last seen: 4 hours 13 min ago
Illuminating something at a very far distance (1000m plus) sounds impressive, except that it’s only a pinpoint of light relative to your eye. You’ll see SOMETHING there, but not enough for detail unless you’re also using binoculars. What’s the use case for something like that? Probably military. Think of it — operating the light on a servo-motor gimbal with one hand, while the other hand grips & focuses a tripod mounted magnifier (monoscope or binoculars) to observe something significantly far away at night. It wouldn’t be useful on a boat for that purpose—too much movement. Maybe with a stabilizing gimbal one could use it for signaling.
djozz
djozz's picture
Last seen: 4 hours 26 min ago
Firelight2 wrote:
I would also like to see a simple ultra-compact pocket LEP flashlight.
The new compact Lumintop is close… but it still has a wide bezel and a lot of unneeded trit slots and other elements that make the light bigger than it needs to be.
The Richfire LEP is a nice simple tube. But it’s sized for 21700 and the light itself is fairly large…. too big for pocket EDC.
To date, NOBODY has produced an ultra-compact LEP with a simple knurled tube as the body and head.
I have bought the Nextool 4tool L10 (no idea of quality, it is in the mail and could be weeks from receiving it, no reviews found either), this is rather compact and without the circus of the Lumintops, but it is still a 18650 light and with 32mm head. I agree on hoping for a 25mm wide tube-style LEP flashlight for 18350 cells, about 100mm long, and have about 200kcd throw.
nbjly
Last seen: 1 hour 52 min ago
I use a Niwalker MM18III around the “farm”. The combo of flood and throw work well. I’d like to see an LEP head combined with big flood like the Niwalker. 1000 feet is about as far as I need for throw.
In the meantime I’ll buy a Thor I because of the size/price and I like the way it looks – I was all set to buy similar parts for a build from Lumens Factory. But this is very similar and includes the LEP engine for about the same price.
dthrckt
dthrckt's picture
Last seen: 1 week 1 day ago
I use a haikelite ht35 from boat. Some places are first come first serve and we often drive miles in the dark checking for empty sites. Other places you reserve a site but still need to find it in the dark.
Spill is horrible because there is nearly always some fog/mist.
When beaching the zoom function is great.
I used to use a modded aspheric crelant vg5 but someone dropped it on concrete. Also modified a black shadow terminator to use 4 aspherics. This had a bigger focused beam and worked great. Both meant I needed a second light for landing, and zooming means I can keep Spill off the boat from tiller steering position.
I don’t think leps have enough lumens for my uses. I am sure they would help see buoys and campsite signs, but you need to see back into the woods to tell if canoe campers are there. 5k or less seems to pierce fog better. Hopefully xhp50.3 will come in warm tints so I can swap to that.
I can’t see far enough to use the throw they have over the ht35, and using binos in a moving boat while you drive is impractical.
When they get 2 or 3 times as bright, and under $100, I will certainly give it a try.
We are out on a lake right now. First 5 sites we checked were taken.
xevious
xevious's picture
Fenix had put out a combined emitter package in an interesting array — LED’s around the perimeter of the reflector for spill, and then a deep reflector LED for the throw. The LR40R.
I think it’s a pretty workable design and I hope they can see their way to putting an SBT-90 or CULMN1.TG in the center at some point. Or perhaps one of the other Chinese companies might clone the setup and tackle the need.
