【New Product】XTAR T2 pocket light
Exciting news! XTAR T2 pocket light was just released.
View more details on website:
Main features of T2 below:
*Max output 650lm, beam throw 65m
*3 lighting levels for standard mode, with runtime max 4.2h
*3 lighting levels for moonlight mode, with runtime max 45h
*Hidden strobe mode for self-defense and emergency
*Type-C port charging anywhere & anytime
*Switch lock function to avoid accidental turn on/off
*Magnetic tail cap & removable pocket clip
*Memory function to go to its previous lighting level
*Reliable and strong aluminum alloy body
*Mini size with length 7.5cm & weight 29.5g
Any ideas, pls comment freely.
Nice one! Does it use a 10440 li-ion battery? And is it removable? And what led is used?
I found the answers on your website: yes, yes, XP-G3
Nice light uses 10380 instead of 10440.
Looks pretty nice! But I am curious about the UI.
Not a good choice :frowning: Something like Samsung would be better in terms of beam pattern…
I wish it also used a 10440, for higher capacity.
XTAR, does it have visible PWM? Also, what is the price?
I feel tempted by this one!
Ouch. Not so common battery.
Looks nice but I’d prefer to see at least protection from rain
“Please keep it away from being splashed”
shame not use atleast 10440 battery more common…usb c cover in this type of light really not needed, better have more protection from water and liquids.
What is the price?
Everyone be sad bout the non common 10380 battery but if these perform similar to a rovyvon/nitecore tiki I’m all in
Very attractive light. So the battery is removable (NICE,) but the replacement is nowhere to be found—(
This in a 14500 would be awesome.
Xtar, this light should have been 14500 or at least 10440.
Only 90 minutes runtime at 130 lumens is not enough.
Other than that - good design overall. I think it can go without the onboard charging, but that’s just me.
Whats the UI? Why can’t manufacturers list the freakin’ UI on the product page. :person_facepalming: It’s an e-switch, so there’s no excuse not to have a good UI with shortcuts to moon and turbo. The form factor looks good, silly battery aside. Offer it with a good high CRI LED or at least don’t glue it shut so we can swap it ourselves.
Dump the Stobe its ridiculous, substitute with hidden Turbo. Make low 15 med 60 high 130. No PWM No Memory. 219c or SST-20 4000k
controversal model. built in charge + replaceable battery is strong side. But WHY 10380? it totally has no advantage over 10440. i hope UI is not sort o of sh*tfires.
suppose such castrated battery will be deal killer for lots of people.
I like everything but the built in charger and oddball battery. Would make a good light for my dad.
When the light is off, long press the switch to turn on, and single click to change lighting levels for standard mode: Low /Mid / High. Click twice to enter moonlight mode, and single click to change moonlight level: Low /Mid / High. Click 3 times to enter Strobe mode. And long press to turn off.
For lock function, click 5 times to switch-lock, and green indicator blinks once it locks; Click 5 times again to unlock, and enter standard low mode.
Now this T2 is available on our aliexpress store, and there is the link: https://www.aliexpress.com/item/1005002730993220.html
10380, why?
6lm - 4lm - 2lm are NOT the true moonlight modes :person_facepalming:
