Question about LVP in the S21A (12 mode)
14 posts / 0 new
manithree
manithree's picture
Last seen: 24 min 16 sec ago
It took 3 or 4 times seeing this happen before I figured out what’s going on, but I don’t see any docs for the biscotti-like 12 mode firmware in my S21A that indicate this behavior, so it’s a little surprising.
I keep this S21A in mode group 7 with mode memory on. It has lived on the handlebar of my commuting bike for the last few weeks. After about 5-6 hours of riding, bike strobe stops, and it just goes to a medium-ish solid on. The first time, I thought maybe I had bumped the button and changed the mode, so I tried to get back to bike strobe, and it wasn’t there. After I charged the battery, it was back to standard modes for mode group 7.
I’m playing with it again now, and it has a L-M-H (probably all lower than normal), party strobe, and beacon. No bike strobe. It was in bike strobe when I started my ride to work this morning. $10 says after I charge the battery, mode group 7 will return again.
I don’t see any docs that say LVP has a limited set of modes (and maybe even depends on the current mode group). Does anybody else’s S21A do this? I don’t see beacon in any of the normal mode groups, so I guess it’s a bonus you only get when you let your battery get to about 3.1 volts.
manithree
manithree's picture
I put the battery back in at 3.5 v, and the “beacon” mode is a battery level indicator mode, I think. Instead of 1 flash, it’s now 3 flashes. And bike strobe is back already.
Interesting.
Funtastic
Funtastic's picture
Last seen: 14 hours 15 min ago
At around 2.8 volts the low voltage warning triggers which is I think one flash every 5 seconds at a much lower brightness
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
manithree
manithree's picture
Mine’s never gotten that low, because bike strobe disappears around 3v.
Funtastic
Funtastic's picture
Bet you haven’t measured it under load though, only its resting voltage. Sounds like the correct behavior since before the low voltage warning it reduces to low output.
ggf31416
Last seen: 3 hours 1 min ago
Which battery are you using?
NeutralFan
NeutralFan's picture
Last seen: 29 sec ago
Group 7 is: 0.1%, 1%, 10%, 50%, strobe, biking, battery-check, SOS.
So you lost a level and the biking mode went away? What about the SOS mode?
Seems strange that the modes would change due to low battery voltage, but I’ve never tested it with my Convoy Biscotti drivers.
I’d rather use my flashlight around the house than turn on the lights.
Funtastic
Funtastic's picture
It’s not biscotti anymore, it’s a copy so behavior is a little different
NeutralFan
Interesting, but it appears to have the same functions and options.
manithree
manithree's picture
Yep, just in the charger. It’s usually still around 3.1 volts, actually, when I charge it. But that’s sometimes after quite a bit of riding on “medium” or something.
manithree
manithree's picture
No SOS mode, but apparently a battery level mode, at least when the battery is less than 100%. The cheat sheet is just copied from Biscotti, but it looks like there are some changes that aren’t documented.
aan
Last seen: 2 months 4 days ago
yeah my S21A also did that… i figur it out when the batt is 50% and lower.. bike stobe is just like 50% flat… maybe when strobeing its goes beyond 100% power.. so its preserve batt when 50% and under
CR888
Last seen: 3 days 3 hours ago
How do you change modes on the S21a…I just got one with the Osram led and it’s got 5 leveled of brightness then a strobe, beacon and something else then back to lowest level. How do you change modes & does it have a battery voltage check function?
CR888
Funtastic
Funtastic's picture
Just Google Convoy Biscotti firmware and instead of 10 taps it’s 20+
Here’s my video for my customers https://youtu.be/iLGAQ6NAuDg
