Meet Wizard C2 Pro MAX!
27 posts / 0 new
Armytek
Armytek's picture
Last seen: 2 days 7 hours ago
Flagship product in multi flashlight lineup — brightness like never before!
_______________________________________________________________________________________________________________________________________________________
Impressive features of Wizard C2 Pro Max
Flashlight for those who need not just bright, but astonishing light.
Wizard C2 Pro Max is the newest model of the demanded all over the world multifunctional Armytek Wizard lineup with record light output of 4000 lumens.
The 3 in 1 multi flashlight for outdoor activities, hobbies and work is comparable in power to a projector.
The main advantages of the flashlight are wide beam angles 110°:150° and an even smoother transition between hotspot and side spill.
Combined with extended runtimes thanks to the larger capacity 21700 Li-Ion battery, these features make use on the head as comfortable as possible.
Multi flashlight 3 in 1
Headlamp
• Simple one-hand operation, reliable headmount.
• The flashlight is easily installed, removed and 180° rotatable in the mount.
• Quick-release rubber ring provides additional fixation.
Every Day Carry
• Compact design.
• Convenient side button.
• Strong built-in tail magnet and
robust removable steel clip.
• Special matt anti-abrasive finish without rough knurling.
Bicycle light
• Body made from durable and lightweight aircraft-grade aluminium.
• Improved shock resistance.
• Constant light without flickering.
• New springs for better battery and driver protection.
• Quick-release mount in the set.
Advantages of the new generation flashlight​
• Maximum LED efficiency: wide new generation LED ensures better light efficiency with impressive output of 4000 lumens;
• New optical system and TIR-lense:
transmits more lumens, provides comfortable wide beam with 150° spill;
• New magnetic charger: 21700 Li-Ion 5000 mAh battery is charged in the shortest time possible (5 h 20 min);
• Extended set: 21700 Li-Ion 5000 mAh battery, battery adapter for use of any 18650 batteries, magnetic USB charger and ABM-01 bike mount.
Bright light for bright results
Set records with Wizard C2 Pro Max. Place an order today and be the first to receive the new product!
Special for BLF users: Use the special promo code BLF20 to get 20% off!
BUY NOW
Thank you for choosing Armytek!​
Armytek Optoelectronics Inc.
www.armytek.com
Edited by: Armytek on 06/04/2021 - 10:13
Boro
Last seen: 33 min 30 sec ago
When will the warm option be available?
Melez
Last seen: 1 day 18 hours ago
Okay, shoot. Now I want a high-CRI version of this too. If I didn’t already have 2 18650 wizards I’d probably get one of these too. I wonder what the run time ends up on the lower modes.
Any thoughts on a Nichia 144AR version?
Unheard
Unheard's picture
Last seen: 2 hours 43 min ago
The lighter 18650 Wiz is better suited to running and shines long enough [for me].
I wonder why you haven’t started innovating your lights with the Prime.
Smile, you cannot kill them all.
Melez
It looks like they started updating the Prime series but I’m not sure why they went with the floody optic (like the wizards) for it.
The old Prime C2 pro with the XHP50 was great if you switched the stock optic for a better one like the Yajiamei 5deg. I dropped one of those in mine and it really made a difference.
bigtrav261
bigtrav261's picture
Last seen: 1 week 4 days ago
Wrong category. Should be posted here: https://budgetlightforum.com/forum/marketplace/commercial
raccoon city
raccoon city's picture
Last seen: 8 hours 59 min ago
Yep, and there's a link in my signature on how to move a thread.
SKV89
Last seen: 1 week 1 day ago
Melez wrote:
It looks like they started updating the Prime series but I’m not sure why they went with the floody optic (like the wizards) for it. The old Prime C2 pro with the XHP50 was great if you switched the stock optic for a better one like the Yajiamei 5deg. I dropped one of those in mine and it really made a difference.
Are you sure the Yajiamei 5deg works great? The 5deg optic doesn’t work with that light at all. The Yajiamei 10deg worked beautifully though.
Unheard
Unheard's picture
Ah, I forgot! Unfortunately the switch is no longer recessed. And with more flood, it cannot replace my C1 non-pro. Good. Saves money.
Armytek
Armytek's picture
Hello!
Wizard C2 Pro Max with a warm light is already available!
www.armytek.com
Armytek
Armytek's picture
Hello!
It is too early to talk about a Wizard C2 Pro Max with a high-CRI.
Unlikely that the project will begin to be discussed in the near future, we’ll see.
www.armytek.com
Armytek
Armytek's picture
Thank you for your feedback.
There is no cause for concern. We have planned an update our Partners! New Partner will be close to the Prime form and have a longer-range beam.
www.armytek.com
Robin Dobbie
Last seen: 12 min 47 sec ago
It might be good to host your own images.
Looks like it was attempted to use an attachment at taschenlampen-forum.de to host this image:
and this one
zoulas
zoulas's picture
Last seen: 9 min 35 sec ago
It would help a lot if you offered some discount to BLF members, like 20%.
D4v30
Last seen: 1 day 22 hours ago
I’m trying to buy a Wizard C2 pro Nichia in Canada but can’t seem to find one, I’ve tried PM’ing you but it tells me the username isn’t correct for some reason. The .ca doesn’t have them in stock and the .com won’t ship to Canada, any chance you could help me get a hold of one?
-ROYCE-
Last seen: 9 hours 34 min ago
I’m pretty sure they ship to Canada:
https://www.andrew-amanda.com/catalog-product-C2PRONICHIA/
Lumeniac
Lumeniac's picture
Last seen: 12 hours 47 min ago
hi
what is LED used in this model?
Armytek
Armytek's picture
Hi!
Cree XHP70.2
www.armytek.com
Lumeniac
Lumeniac's picture
not bad, not bad...hope it is the same well stabilized as C2 pro (i`m currently editing video review of this model - and it performed surpsingly good).
D4v30
Hi Royce,
Thank you very much for the link, the shipping fees there are pretty brutal though. I was hoping the person from ArmyTek on here would get in touch but I guess not.
puglife2
puglife2's picture
Last seen: 2 days 22 hours ago
Hi Royce,
Easy fix: don’t live in canada
D4v30
puglife2 wrote:
Hi Royce,
There’s no where else I’d rather be.
puglife2
puglife2's picture
Have you tried Mongolia before saying that?
D4v30
Well that would be my next choice. I do really like Wolf Totem by The HU.
Armytek
Armytek's picture
Hello! Sorry for the delayed answer.
Please notet that we have never experienced any problems with shipping to Canada via com.
In addition, if the requested flashlight is not available please write to shop@armytek.com(link sends e-mail)
Our manager will help you and you will receive a flashlight you need.
www.armytek.com
Armytek
Armytek's picture
Lumeniac wrote:
not bad, not bad…hope it is the same well stabilized as C2 pro (i`m currently editing video review of this model – and it performed surpsingly good).
Thank you!
Please be informed that stabilization in Wizard C2 Pro Max is similar to Wizard C2 Pro.
www.armytek.com
Armytek
Armytek's picture
Hi,
Sure! Please use the special promo BLF20 for 20% off ALL Armytek flashlights and accessories!
www.armytek.com
