What would happen if you took an AA Lumintop Tool and made the body out of TurboGlow instead of metal? Well that’s what we basically have here with the Lumintop Gift-G1 a flashlight where most of the light is made out of TurboGlow and copper. It’s available in a number of colors and has both Cree and Nichia emitter options too. Thanks to Lumintop for sending this to me to review. It’s a fun light so let’s take a closer look.
Watch this review on YouTube:
Follow me on Instagram: https://www.instagram.com/liquidretro/
Join the Facebook Page: https://www.facebook.com/LiquidretroReviews/
Enjoy this review? Buy me a Coffee/Beer: https://www.buymeacoffee.com/Liquidretro
Get 20% off the Gift G2 by using the coupon code 20G1GiftOFF at https://www.lumintoponline.com/lumintop-gift-g1-turbo-glow-600-lumens-ed... (No Affilate)
Packaging & Accessories
The Gift-G1 comes in a small cardboard box with minimal information on it, on the back you have the emitter chosen and the body color of the light. Inside accessories include the light itself, yellow lanyard, 2 spare orings. A glow ring and 14500 battery are both optional. No pocket clip is included with the light, more on that in a minute.
Construction
The Gift-G1 is made from TuboGlow with an internal aluminum sleeve for electrical conductivity, and at the head, the pill is made from raw copper. TurboGlow if you don’t know is the premium solid glow in the dark material. It has a much longer glow life then normal glow in the dark material. While there are several color choices available, especially with the Gift-G1 such as Lava, Red, Rainbow, Pink, Purple, Blue, and Green, I went with green because it’s the brightest color that lasts the longest.
The tail cap has a semi translucent black button inside and it has RGB LED’s underneath. These LED’s come on when you have a liion battery (14500) in the light, so you get a neat effect on the sides of the LED’s slowly fading between Red, Blue, and Green.
Internally the parts are the same as the AA Tool, and interchangeable if you have both lights. There is an aluminum tube under the TurboGlow for conductivity. At the head of the light there is a exposed raw copper pill with light engraving of the Lumintop name, and model number. It’s a nice functional heat emitter too.
Lastly at the front the front bezel is TurboGlow and easily unscrews to expose the TIR style optic. This exposes the MCPCB. This makes the light very easily modded if you wanted to do an emitter swap.
Size & Weight*
*I measured the length at 88mm, minimum width on the body at 19.21mm, diameter at the head at 21mm. Diameter of the glow ring is 30mm. Weight with the light, 800mAh Keeppower 14500, and Reylight Lan/Pineapple clip is 70g. The light is IP68 rated.
Retention
The Gift-G1 comes with a yellow lanyard as the only factory supplied retention option, that can be attached via an optional anti roll ring/cigar grip ring. This works if that’s how you want to carry the light like this, but for me if I am going to EDC a light I need a pocket clip, so I went through my lights to see what I had that might work, and I found that the clip from my Reylight Lan/Pineapples V3+ work decently well here, You basically get the entire cap section sticking up out of your pocket (20.5mm) which is a bit much for me, especially when running a 14500 and having the tail cap light up but it’s still better than no pocket clip.
I should note, with a clip like I had, I had more then one person stop me and said the light in my pocket was on when in fact it was just the tail cap LED’s or TurboGlow glowing. So it did draw some attention to itself.
LED & Beam Shots
The Gift G1 here is available with a Cree XP-G3 LED in cool white, or a Nichia 219C LED in Neutral white which is what I choose. It can be powered off of a AA or 14500 battery. I will include a chat here showing the claimed outputs for each emitter and battery combination.
I found the beam pattern to be nice for EDC, It’s got a medium large hot center with a large dim spill, good for general shorter range and medium range tasks good for maybe 200ft max. One quick note about TurboGlow is it really lasts a lot longer than your traditional GITD material. With this light when you use it, you get light leakage around the front of the light so it continuously charges it. It makes for a lot of fun, kids love it. I found no visible PWM here to the eye or camera.
Heat & Runtime
As mentioned before the light will run from 2 different power sources, either a AA 1.5v battery or a 14500 3.7V battery. You get the best performance and tail cap LED’s only if you run with the Liion 14500 but I did test both battery types.
With the 14500 the light stepped down from 100% relative output after 2 minutes and then ran at 55% relative output and declined in a slow manner. To me the curve looks unregulated. Total runtime was 1:10:00 but after this the light staid on in it’s firefly mode for about 2.5 additional hours. Maximum heat I saw was 48C at the 20 minute mark. The exposed copper does a nice job here with heat dissipation and adds some style points too. The light does have LVP.
I did my AA test with a Amazon Basics High Capacity NiMH battery. These have proven to be good performance in the past, and here we saw a very flat output curve maintaining 98% relative output for 2:12 minutes. Heat here was minimal and I saw the peak being 36C at the end of the runtime.
UI
The UI here is simple, it’s a 4 mode light, starting at the lowest mode. Once on, you can half press the mechanical button to go up in modes. There is a strobe mode, to access that, once the light is on, click give it a half press 6 times to get to strobe.
There is memory when the light is off for 3 seconds this will memorize the setting and the light will come back on to that desired setting. That said my light has a firmware bug, and this only works with a 1.5v battery, if I use the 14500 Liion, memory mode doens’t work. Lumintop confirmed that they are aware and plan to fix it on the next batch of lights.
Pro’s
- Fun
- Choice of Body colors and Emitter options
- Good beam profile for EDC
Con’s
- No clip is included, but there are options on the market that fit.
- The glow ring isn’t included and without it or a clip it leaves a gap on the body of the light.
- Memory mode firmware bug when using 14500 and doesn’t work.
Conclusion
The fun with the Gift-G1 is the TurboGlow body, it’s availability in several colors, and the LED’s in the tail cap that change color when using a 14500 battery. Inside it’s basically a Lumintop Tool which is a good EDC style light. For me the let down was no pocket clip, a must on a light this size if I am going to EDC it but luckly the clip from my Reylight Pineapple fit to make it more usable on a daily basis for me.
I think this would make a great gift, a nice addition to a flasaholics collection since there are very few lights made from so much TurboGlow or a gift for a child (kind of expensive) to get a kid into the hobby if you like.
Great review, pity the cigar ring is an ‘extra’ that’s a bit cheeky. I’m going to get one for my nephew, looks like green works well or maybe the light blue. I like the fact it’s just different, has copper, aux leds and decent run time performance.
CR888
wow…. i love it
That is pretty cool!
Thanks for the great review.
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
What the…., was expecting to see $29.95 not $79.95.
