Driver Surefire question
13 posts / 0 new
DesertSnake
DesertSnake's picture
Last seen: 3 days 12 hours ago
Hi, I have a flashlight and its batteries are dead. My friend and I put in new batteries, but it turned out that someone climbed into the circuit and replaced one transistor (he put bipolar, red cross paint), now the flashlight does not work, it turns on, detects the battery and goes into protection. The transistor itself is very hot, the only element on the board that heats up. I think I should put a field-effect transistor. It seems that his task is only to turn on and off the battery, like a key.
But I would like to ask for help, maybe someone has the same flashlight, will he disassemble it and take a picture of the transistor that is in the original?
All this is inside the body intended for charging. Model SF Beast II.
https://postimg.cc/gallery/kRwjtgz
Ab aqua silente cave
Edited by: DesertSnake on 06/03/2021 - 06:10
Quadrupel
Quadrupel's picture
Last seen: 2 days 11 hours ago
Find out is it on positive or negative side and replace it with N or P channel FET.
DesertSnake
Thank you! It looks like it is breaking “-” of batteries. N or P do you mean the type of NPN and PNP?
raccoon city
raccoon city's picture
Last seen: 38 min 31 sec ago
N or P probably means Negative or Positive.  :THUMBS-UP:
Quadrupel
Quadrupel's picture
“ – “, so N Mosfet
thefreeman
thefreeman's picture
Last seen: 59 min 44 sec ago
5 PCBs not counting the one with the indicator LED lol, that’s an HID flashlight right ? I didn’t know those needed that many components.
Anyway if it’s a low side NFET reverse polarity protection then it should be like this :
Check that the circuit matches with a to-220 (if that was the original package used ?) pin-out to confirm that it was indeed a reverse protection NFET originally.
Then choose one with low RdsON, a Vds and Vgs>=16V (needs to be more than 3×4.2V).
Or if you want to forgo the reverse protection then you can short the drain (bat-) and source traces (driver GND).
DesertSnake
Thank you all so much for your help! I will try to change the transistor and tell you about the results.
Yes, this is HID 2006 – 1*D1S 4300K (2000 lm) + 12*5 mm LED (20 lm)
So the board is disconnected, where there are 2 pads with solder, a 15 amp fuse was installed. Maybe in place of this suspicious transistor should be the same as these 3 on the left?
http://www.farnell.com/datasheets/1689945.pdf
My friend and I do not understand how everything works here, it seems that this missile control board
zoulas
zoulas's picture
Last seen: 1 hour 6 min ago
What kind of flashlight has all those electronics?
DesertSnake
Surefire Beast II, catalog page 60-61, but this is not in the head of the flashlight itself, it is in its li-ion rechargeable body. The catalog shows only the battery body for 20 CR123
http://flashlightguide.com/documents/SureFire%20Catalogs/2006%20SureFire...
zoulas
zoulas's picture
Interesting. Someone must have paid a lot of money for that.
max
max's picture
Last seen: 41 min 38 sec ago
I heard on the news that there’s a shortage of electronic chips…..
Now I know where they all went!
 max
NeutralFan
NeutralFan's picture
Last seen: 1 day 19 hours ago
Good one max! Big Smile
I’d rather use my flashlight around the house than turn on the lights.
snakebite
snakebite's picture
Last seen: 1 week 2 days ago
thats a teccor part.
all i recall them making are scr and triac.
neither of which have a place in this unit.
and the tab MUST! be soldered to the copper.
the board trace is the heatsink.
so look for a n channel with the lowest rdson and at least 40v.
should be easy.
same case as the 3 others.
maybe same part?
