Emisar D4 V2 ti ordered by mistake a Samsung 30Q Button Top
8 posts / 0 new
From0toHero
From0toHero's picture
Last seen: 1 day 16 hours ago
Hi all together
I just got a new Emisar D4 V2 ti flashlight. By mistake i ordered instead of a flat top Samsung 30Q battery i ordered a button top Samsung 30Q battery. I inserted the battery and the flashlight closes fine and works. Should i avoid using it? Can i damage anything inside by using it?
I’m thankful for any advice
zoulas
zoulas's picture
Last seen: 8 hours 13 min ago
If it fits probably not. You need to judge how much force you need to put the tail cap on. If the battery sticks out more than 3/8 inch, its probably too long.
From0toHero
I made a pic of the battery looking only around 4-5mm out. The button top is real small on the Samsung 30Q compared to a flat top. But still it’s a strange feeling using a wrong battery and i don’t want to damage my new flashlight lol
https://ibb.co/hLvncLp
thefreeman
thefreeman's picture
Last seen: 10 min 24 sec ago
Button tops are spot welded, you can pry them off if you want, carefully because the case is negative around it.
Robin Dobbie
Last seen: 1 hour 43 min ago
The top might “cave in” at some point, but I have a few like that and they’ve been fine for single-cell uses. Not sure what the implications would be if a venting took place. The vents aren’t completely sealed, it’s just the middle that’s further down.
how2
Last seen: 3 hours 10 min ago
Hold it in one hand like pic and push the battery down, does it take a lot of force?
From0toHero
Thank you for your reply. No it does not take much force to insert the battery. I went out to buy a 18650 Battery and found a Samsung 35E 18650 Battery. It’s a flat top model. I know a 30Q would be much better, but i hope the 35E will do till i find a 18650 30Q flat top.
how2
It’s fine no need to worry.
