Today I have the Astrolux WP1 LEP flashlight. It’s capable of 250,000 candela, and 480 lumens out of the included 21700 Liion battery and it’s UI is a control ring. If you have seen my review of the Jetbeam RRT M1X Raptor you might notice a few differences more on that further on in my review. Thanks to Banggood for sending this light to me and providing a discount for my viewers.
Watch this review on YouTube:
Follow me on Instagram: https://www.instagram.com/liquidretro/
Join the Facebook Page: https://www.facebook.com/LiquidretroReviews/
*Enjoy this review? Buy me a Coffee/Beer: *https://www.buymeacoffee.com/Liquidretro
Get the Astrolux WP1: https://ban.ggood.vip/XSaT for $165.95 by using code BGYX06 (Affiliate Link)
Packaging & Accessories
The Astrolux WP1 comes in a large plastic case with a handle, on the front is a large sicker showing the light and listing a few headlining stats. On the back is another sticker showing a runtime chart and links to various social media platforms.
As far as accessories the light comes with an unbranded 5000mAh, 21700mAh battery with MicroUSB recharging onboard, A basic lanyard, an extras bag with 2 red orings, and spare tail cap, manual and a basic holster.
Construction
Astrolux brought out 2 LEP style flashlights earlier in 2021 that appear to mirror the Jetbeam RRT M1X and M2S WP-RX, in physical appearance and closely in performance with the main difference being the engraving on the body. I suspect the parent manufacturer for Astrolux is Jetbeam. The anodizing Jetbeam useses is a somewhat distinct gray in the flashlight industry, and it’s being used here as well. Side by side they look the same anodizing wize.
Starting at the tail you have a forward click mechanical switch and 2 tails where you can attach a lanyard. It will tail stand but it’s not very stable. There is minimal knurling on the tail and body tube that add some grip. Threads are square cut, nicely greased and anodized.
You do have a rubber tactical ring which is nice to allow you to cigar grip the light if you wish. The body tube has flats milled in for the labels and a little added grip. The body tube is also removable from the head, but not reversible. I was able to swap around the head, body, and tail from the Jetbeam RRT M1X as well. The orings on the WP1 are the same distinct red color as the Jetbeam.
The head features the rotating ring controls, with a total of 5 detents that are just over 180 degrees in total movement. They feel ok, not super crisp but not mushy either. I like rotary control on a light like this, they are simple and they work great with gloves on which is important this time of year. The bezel of the light is non removable. It does stand proud of the “lens” and the cuts in the side allow for some light to leak when head down.
Size & Weight
I measured the length at 158.3mm, minimum diameter at 24mm on the flats of the body, and maximum diameter of 36.7mm on the control ring. Weight with the supplied battery is 230g. The light is IPX8 Water rated. Here are few photos of similar lights or competitors that I own.
Retention
Retention options with the WP1 are the included lanyard which can be attached at the tail cap and then the holster. The holster has a velcro front cover and is made with a neoprene lined ballistic nylon. On the rear it has a belt loop that’s attached with a button and velcro.
Emitter & Beam
So instead of an LED, the WP1 uses a LEP or Laser Excited Phosphor. Astrolux calls this the WP-T2 LEP (Same as Jetbeam). LEP’s work by using a blue laser emitter on a layer of phosphor to create a “whitish” beam that is then sent through a convex lens.
The result is a beam that’s extremely concentrated. At 8ft it’s less than a 5 inch circle, it also has basically no spill like your traditional flashlight does. This concentrated beam does spread out a little at distance but it’s not as much and my night shots show that. When I compare it to my Jetbeam RRT M1X the beam here is larger, in shorter distances, but still quite small by LED flashlight standards. The tint here definitely has a blueish tint to it. There was no visible PWM to the eye or camera.
(Astrolux on the Left, Jetbeam on the Right)
Heat & Runtime
I expected that this light would produce more heat because of how intense it was but it doesn’t Maximum heat I saw was about 36C during testing, and that’s a regulated temp. With the smaller body it does get about 4 degrees warmer than the larger Jetbeam model. It does seem to have a timed stepdown, to 40% relative output after 3 minutes. Compared with other LED based throwers I have this is good, given the other LED based throwers generally produce a lot more heat.
Total runtime starting on high with the included fully charged 5000mAh battery was 5:14:00 with several step downs along the way. After 12 minutes your running at about 30% relative output but you can bump back up manually. When the light shut off I measured LVP at 2.974v. You don’t need a high output battery for this light either with the maximum amperage requirement I measured under 3A. So since this light is using a non proprietary button top protected battery (Long in length) you can choose based off of capacity rather then performance.
UI
The UI here is simple with the rotary switch at the front. It’s 5 position switch with detents at every point, total rotation is just over 180 degrees. Starting from the left most detent and working clockwise you have low, medium, high, strobe, SOS. The switch at the rear is a your on and off control without a momentary mode as it’s a forward clicky switch. Strobe is very fast here, almost to the point of it not being useful as a strobe.
Recharging
Recharging here is accomplished with the included unbranded (My guess is it’s the same battery Jetbeam supplies with their lights) 5000mAh 21700 battery. The battery itself has microUSB built into it, with a small LED at the positive side. Red when charging, green when charged. I would have loved to see USB-C instead here, especially on a premium light. It took a lengthy 7:31:00 to fully charge this battery which is quite slow, the fastest charge rate I saw was .75A, and it only decreased from there for the remaining 6 hours. Fully charged the battery measured 4.206V.
My recommendation would be to use your own charger like the Vapcell S4 Plus or Xtar VC4SL and charge at a more reasonable rate. This battery can very safely handle a 2A charge rate and that will cut the charge time to more than half. I tested the capacity of this battery with my VapCell S4 Plus charger at 4719mAh.
*Pro’s & Con’s *
Pro
- Simple Name
- Good size for in the hand use & filters are available to make the LEP more practical for more tasks
- The control ring is easy to use
- The beam is a little larger making it slightly more practical at medium distances.
Con’s
- Strobe is too fast
- Wish it came with the optional diffusers to make it more practical
- Not inexpensive.
- LEP tint isn’t great, very cool white.
Conclusion
Given this lights apparent similarity with it’s sibling Jetbeams cousins, I would say go with whichever you can find the best deal on. Banggood is known for it’s coupons so it might end up being the Astrolux versions. From a physical and performance stand point I can’t tell a lot of difference. I don’t have both to do direct comparisons on but from reading in the forums and looking at them, and comparing the Astrolux WP1 to my Jetbeam RRT M1X Raptor I think they are likely the same.
https://i.imgur.com/pMd6Es6.jpg
The big difference between the two models are their size of head and a bit of styling. The Astrolux WP1 here is a much smaller design thats easier to fit in the hand
While LEP’s are really fun, and the performance is incredible, I struggle to find many uses for them in general. The hot spot here is a bit larger then my other LEP’s which makes it better, but realistically this isn’t something most people need and still quite small with no spill. It does work well for that smaller hand held search light application, signaling, and possibly on a hunting rifle at lower settings or with filters but this isn’t something you would want to take camping or be super useful in a power outage. That said it has pretty solid performance, and a LEP is something every flashlight obsessed individual should have in their collection.
Astrolux WP1 LEP monitored with a thermographic camera (UNI-T UTi690B)
Fireflies E07 V2, XPL Hi V2 5A 4000K Neutral White, Matte Black | Astrolux WP1 LEP
