Best fast USB flash thumb drives
I did a bunch of research on these in November September of 2020.
The best fast USB flash drive that I could find is made by Mushkin.
https://www.amazon.com/Mushkin-MKNUFDVS256GB-256GB-Ventura-Flash/dp/B00E10U36G
https://www.newegg.com/mushkin-enhanced-model-mknufdvs128gb/p/N82E16820226441
PROS
It has extremely fast read and write speeds.
I own three of them, and I think that they are reliable.
They're not that expensive.
The bodies are made of aluminum, so they shed heat well.
CONS
The caps falls off very easily. I use duct tape to attach the cap to the tail, which means I don't use the cap to protect the head.
They cannot be used to boot a Windows PC, like many other flash drives.
They're hard to find in capacities other than 64GB, 128GB, and 256GB.
Do you know of any fast USB flash drives that are any good?
I'd like to get something cheap that is lower capacity (16GB would be nice) and will boot a Windows PC, but any recommendation is welcome.
I got 3 of the Sandisk USB 3 standard 64GB that seem to be slower than claimed, but I haven’t measured throughput and it might be due to having a hand crank, manual kick start computer:-). Price was good, and most importantly, they are reliable and PC Magazine gave them a “top pick” due to reliability.
Stunning that 2 TB drives are out there for mid $40 range. Just crackers. Beats loading floppys in I suppose….
Here’s one claiming higher than 3.0 (550MB/s ) coming in at 1tb. https://www.amazon.com/ROKHY-Portable-External-Smartphone-Chromebook/dp/B082PG7Z1Z/ref=sr_1_13?dchild=1&keywords=fast+flash+drive+2tb&qid=1623125978&sr=8-13
Comparable to a 1tb solid state HD n price at $190.
I have a SanDisk Extreme USB 3.0 64GB as well.
It's pretty slow, and although I didn't use it very much, it failed and doesn't work anymore.
I'm not going to get any more SanDisk USB flash drives.
Hmm, maybe time PC mag updated their reviews:-)
If I were to use it for backups I would go for the pricier ones. The other ones are okay for non critical stuff. I mean 128 - 256 gb of data if lost would be a pain.
I’m actually looking for ones that have a led in them. Makes it so much easier to gauge what’s going on. I don’t see many that have this feature anymore. Gotta keep looking. :slight_smile:
I like reliable flash drives, but the data is not critical.
The data on my flash drives are also on at least one hard drive, so if the flash drive fails, I don't lose any data.
The Mushkin flash drives that I linked to have a red LED light on the tail that blinks when the drive is active.
If you duct tape the cap to the tail like I do, you cover up the light, so you could just keep the cap in a ziplock bag and never use the practically useless cap.
Alternatively, you could use clear duct tape (or other transparent tape.)
SSD M2 case with disk of size you need. Light years ahead fastest USB thumb drive.
Mike
Really! I’ll look into it. Oh good tail cap trick too. :slight_smile:
Those look quite a bit bigger than a thumb drive.
If I want to transfer data with something bigger than a thumb drive, I use a portable (laptop) hard drive.
It's nice that they're so fast, but I don't think my PCs can take advantage of the speed.
My gaming PCs are so old, that they can only transfer data a little bit faster than 100MB/s.
Seems like a good choice for someone else.
Best ones are the 32gigameg ones I get for free at MicroStore when they send out those postcards trying to luuuuure me back in.
This is the fastest one I own…
ARCANITE
It is really fast in Windows, but on a Pi 4 running Debian 10 it is not seen as a SuperSpeed drive.
I have used these in Windows and Linux, the fastest I have worked with yet.
Corsair
If you use a Pi 4, this is the best way to go… SSD native case with active and passive cooling.
Argon 1 V2 SSD
yea the corsair flash voyager series is my goto if I want speed
The pny 3.0 turbo attache series is also pretty good.
There’s a benchmark site at http://usbspeed.nirsoft.net/ but it’s not very user friendly
Don’t get the ones on Vipon—They are Turds — They work great for giving someone software or a movie though
That’s about all I use ’em for, just temporary storage or sneakernetting something from A to B.
What’s everyone else use ’em for?
^ what he said.
99% of “fast” USB 3 drives are only fast at sequential reads and writes (few large files), and choke HARD on lots of tiny files.
Actual fast USB drives will use actual SSD controllers. Or just get a m.2 to USB adapter and buy your own m.2 SSD (careful to check compatibility though)
What is special about this drive that you can’t boot to it if the boot files are loaded? Does a computer bios not recognize it?
I use a flash drive to boot laptops to run and restore from Easus to do image files. It is rare, but in a day of ransomware, and the possibility of total failure of my SSD hard drive, I am somewhat paranoid about backing up my 5 most used laptops. I actually do a 1:1 clone of my most used one monthly. I keep image files for a year in case a corrupt file had been around longer than I knew. I have not done a traditional re-install in 10 years at least.
@sarge12:
The flash drive uses a nonstandard sector size, and will not boot anything that I have tried on Windows 10 machines.
Here's the error message that I get:
OK…well Easus to do uses a modified linux file to boot, it is after all a program to recover from total hard drive failure, so windows has no effect. At boot, all that matters is the computers bios and whether the usb has a bootable operating system. It only has files to boot and load better USB files that will allow the usb to search an external usb hard drive for image file. You put in the usb stick and set the bios to boot to it, then after the simple OS and Easeus to do program loads in memory you unplug it and plug in any usb external hard drive to find the image file. It is almost like dos used to be. It may not boot into a windows boot, but as long as the bios can see the drive, it will boot to the modified linux boot. It is a pain to create the bootable stick, because easus to do does not just supply the necessary files and they are open source. I have never encountered any flash drive that I can’t make bootable. How to Create EaseUS Bootable USB, CD/DVD, and ISO Image with EaseUS Todo Backup - EaseUS It also makes that flash drive useful only for the boot drive, as it creates a boot file that does not play well with windows. It is made from an ISO cd file and it is not just very simple. It will boot even if there is not even a hard drive in the computer. It has been a while since I made about 5 of the bootable flash drives, so I would have to read up on how to do it now.
