Wurkkos deal update!TS21,FC12, HD20 FC11 red/green/purple Deal code on Amazon!
416 posts / 0 new
pennzy
pennzy's picture
Last seen: 4 hours 41 min ago
Thanks. Just wondering if they all are high. Might want to turn off the switch light if it is.
rick_wang
Last seen: 2 hours 2 min ago
I think it’s happening at least on all Sofirn made Anduril 2 flashlights, my new Sofirn Q8 pro has the amble light comes on and off during the usage too.
It’s supposed to indicate the power bank function only.
spamyak
Last seen: 10 hours 12 min ago
Turns out I don’t seem to have anything that measures milliamps let alone microamps
dondizzurp
Last seen: 2 weeks 2 days ago
Same issue others are facing.
The blue indicator led on my TS21 doesn’t turn off.
The only way to turn it off is to unscrew the cap and cap it back on… But then there’s a faint amber light that’s always on.
dondizzurp
I can also hear a very high pitched squealing/whining from poor circuitry. Sounds like an old CRT TV or coil whine.
Honestly regret this purchase. Not at all the quality I was expecting.
Plasmatoast
Last seen: 5 hours 31 min ago
On turbo or all the time?
funwok
Last seen: 8 hours 54 min ago
Learn to use Anduril 2!
You can turn the amber button AUX LED off entirely.
Fescron
Last seen: 1 day 13 hours ago
Yeah mine has that pitch thing too. My Sofirn SC31 Pro has it as well but the TS21 is louder. I’d like to point out though that it’s also possible that the ceramic capacitors (of which there are quite a lot according to a TS21 teardown), with their big internal surface area can act as loudspeakers. Just a quick “the more you know” fact haha. But the coil (maybe in conjunction with the capacitors) and the high switching frequency (but in the audible range) can cause it too Smile
Fescron
Mine does not whine on turbo because the circuitry doesn’t switch. AFAIK in that case it’s just the battery through some mosfets straight to the LED. On higher “regulated” outputs I can hear it, and it gets louder the higher the light output is.
Plasmatoast
That’s why I was asking, I had experienced it with another light when on turbo Just wanted to make sure their issue wasn’t the actually normal. Btw. My red ts21 so far seems fine. No noises, I have the aux is turned off and the switch light increases brightness with ramp level while in use like it should according to the instructions
Tom E
Tom E's picture
Last seen: 8 hours 37 min ago
funwok wrote:
dondizzurp wrote:
Same issue others are facing. The blue indicator led on my TS21 doesn't turn off. The only way to turn it off is to unscrew the cap and cap it back on... But then there's a faint amber light that's always on.
Learn to use Anduril 2! You can turn the amber button AUX LED off entirely.
That's kind of like complaining to the doc "my arm hurts when I move it", and the doc saying "then don't move it".
I do like having a switch LED and is certainly one of the reasons I bought this light, but at least we have this option to turn it OFF as a work-around solution.
fogofwar
fogofwar's picture
Last seen: 2 hours 37 min ago
Does anyone know about how much current the Noctigon K1 or D4v2 switch Led draws?
Tom E
Tom E's picture
D4V2 here: https://1lumen.com/review/emisar-d4v2/ where all the colors are measured. The OFF # is right where it should be  at 25 μA (20-30 is expected), while the green and blue are somewhat reasonable in HIGH, and the low #'s are all reasonable. I'm not sure how many LED's but I believe it's 4 per color.
I assume the K1 is about the same.
merlot
Last seen: 4 hours 25 min ago
Any plans for Anduril 2 on the Wurkkos FC11?
FBsLights
Last seen: 1 min 56 sec ago
Just some feedback to Wurkkos…
I would have purchased a FC11 in each color if it had Anduril 1 or 2.
It’s not that the current UI is bad. Anduril just helps keep more of my lights with a common UI.
Frank
TheIntruder
Last seen: 2 hours 3 min ago
pennzy wrote:
Is the switch LED functional enough for voltage check and thermal control purposes?
I haven’t ordered one myself, and won’t, until the bugs (or the known ones anyway) are worked out.
So my opinion is based on the similar light setup in the SP32A, and SP35, which is fine as a brief indicator, but not going to be nearly as satisfying as the larger switches if one wishes to leave them illuminated all the time, despite the current drain.
A soup ladle can still dig a hole, but you really want a shovel for that.
dondizzurp
Late reply but the solution to this is in the manual LOL I should have read before posting
dondizzurp
No it goes away on turbo. Any other level and I can hear it loudly.
Good to know I’m not alone lol
Wurkkos
Wurkkos's picture
Last seen: 4 hours 15 min ago
Frank
thanks, will update the anduril 2 on FC13 new model, new LED and tir for a 18650 EDC
Wurkkos
Wurkkos's picture
TS21 anduril 2 with orange indicator , and blue indicator will show when Sudden voltage change, such as turbo and strobe (turn off auto 30 seconds later), so when turbo the purple will show because of orange and blue mixed
Wurkkos
Wurkkos's picture
HD15 will restock on 12th,Dec, here is a 15% code for BLFers—-WKHD15BLF
dondizzurp
Frank
New model FC13 Shocked
Any pictures?
Wurkkos
Wurkkos's picture
Frank
Any pictures?
Not yet, still in desiging Big Smile
Wurkkos
Wurkkos's picture
11st to 15th, Dec, deal models on website:
FC12 SFT40 2000LM Tactical EDC Light -Deal $24.99-$27.99
HD20 Dual LED Angle 21700 Light —Deal $28.99-$33.99
HD15 Dual LED Angle 18650 Light —Deal $28.99-$32.99
DL07 Multi Color Underwater Light 26650 —Deal $45.99-52.99
DL10R XHP70.2 4500lm Type C Rechargeable Underwater light—Deal $46.99-$51.99
DL20R XHP50.3 3200lm Type C Rechargeable Underwater light -Deal $34.99-$38.99
Wurkkos Terry
Wurkkos Terry's picture
Last seen: 2 days 19 hours ago
[12.12 Promotional Carnival Deals Update]
Wurkkos Website
DL20R XHP50.3 3200lm Type C Rechargeable Underwater light -Deal $34.99-38.99
Amazon—-Link———————————-Code——Price-Deals-FinalPrice—Time
FC11- http://amzla.com/ursdz9la1v8l ,4L99ML7S ,$29.99 ,20% ,$23.99 ,Now-12.31
5000k
FC11- http://amzla.com/s50pgi209jdu ,WATH7Z3V ,$29.99 ,15% ,$25.49 ,Now-12.31
4000k
FC11- http://amzla.com/urgt9tnafv3q ,24KPABEC ,$29.99 ,15% ,$25.49 ,Now-12.31
2700K
WK20S http://amzla.com/ubop1lmon4u0 ,UJBUKXLI ,$35.99 ,15% ,$30.59 ,Now-12.31
WK20 http://amzla.com/qxtcg5na2mhx ,JA6K47YE ,$32.99 ,15% ,$28.00 ,Now-12.31
WKC05 http://amzla.com/1ib0yt6qk4p4i ,TQCVC26O ,$49.99 ,15% ,$42.49 ,Now-12.31
WK30 http://amzla.com/rhr75dwe9vfn ,I4RAGHM6 ,$39.99 ,15%+5% ,$31.99 ,Now-12.31
HD20B http://amzla.com/trrcl8qgyqub ,VTQ6RWXE ,$48.99 ,15% ,$41.64 ,Now-12.31
HD20G http://amzla.com/1hbfz39e4×5bs ,VTQ6RWXE ,$48.99 ,15% ,$41.64 ,Now-12.31
DL30 http://amzla.com/1jew0z101846u ,4QQ24MIX ,$53.99 ,20%+5% ,$40.49 ,Now-12.31
WKC06 http://amzla.com/1hbiprgp0wwts ,EUSNKOQ4 ,$38.99 ,20% ,$31.19 ,Now-12.31
TS30 http://amzla.com/1k201aeducdgy ,V9BI4IKA ,$55.99 ,25%+$10 ,$34.49 ,Now-12.31
DL70 http://amzla.com/1k22ts153jznd ,AUKMPKDO ,$119 ,25%+$10 ,$81.75 ,Now-12.31
TS21 http://amzla.com/1k1ziz1uprkv7 ,9LOCAQUP ,$45.99 ,20% ,$36.79 ,Now-12.31
H200 https://www.amazon.com/dp/B08DKVBJ4K?th=1 ,QN2RN8WW ,$39.99 ,35% ,$25.99 ,Now-12.31
KC-UK https://www.amazon.co.uk/dp/B08XWC1QRF?ref ,DHFMF7YR ,£28.99 ,50% ,£14.49 ,Now-12.31
Wurkkos
Wurkkos's picture
new color 100 pieces limited
Wurkkos
Wurkkos's picture
TS21 code : HX3NKK7T
pennzy
pennzy's picture
I would like to purchase another TS21. Are there plans to address the standby drain and the quirky switch light in the future? A switch similar to the Sofirn SC 31 pro would be nice.
Plasmatoast
Always cool to have new colors. I’d like to put in a vote for a bright green next! Need some more colors in my collection.
mbp
Last seen: 6 hours 5 min ago
The ONLY thing I don’t love about the FC11 is lack of Anduril, very excited to hear about an 18650 EDC using Anduril 2 from Wurkkos. Please continue to use LH351D 90CRI, this LED looks very nice in a TIR.
