where's the kaboom?
32 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 16 sec ago
where's the kaboom?
Okayokayokay, so I got my trusty EBL 14500 in my GTmicro. Last I checked it (days ago, not last month or anything), it blinked out 3.6V, which is low, but not in need of any immediate recharge.
Seems my cats, or at least one of ‘em, doesn’t know the meaning of the word “boundaries”, and climbs onto my table, etc., and swings his tail around like a club. I swear, he must have ankylosaurus DNA somewhere in his genome.
Well, after picking up my lights off the floor and putting ‘em back on the table for the umpteenth time, I notice that the ‘micro’s sideswitch is dark. Odd, but sometimes that glitch kicks in and the sideswitch light stays dark. Nope, totally dead. Tailcap’s on tight, so it’s not locked out or anything. Odd.
So I unscrew the cap to check on the cell, and it’s sloooowly sliding out. Wtf?? It’s wet! And it stanks. And the wrap’s completely split open like it overheated! Again, wtf??
Yep, the beastie leaked out inside the light. Okay, so that goes right into the garbage. I wash out the tailcap spring and everything with detergent and water (no corrosion anywhere that I could see). Then after rolling paper towels into tubes and running them through the battery tube multiple times, I finally wash out the innards by drizzling detergent into the tube and running hot water down the pipe multiple times. Whole thing’s drying off now.
So, it had to have happened recently, whether the little furball accidentally turned it on and it ran down because of no LVP, or it just self-drained in a matter of days from 3.6V to leaking. I’m just amazed it didn’t go all supernova if it leaked and/or heated enough to split the wrap. And no “uncontained failure”, either? Small miracle, if you ax me.
Either way, I’m definitely reconsidering keeping any cell in a light if not in active rotation.
raccoon city
raccoon city's picture
Last seen: 10 min 49 sec ago
nuclearexplosion
Lightbringer
That’s kinda what I was expecting when a Li cell would leak.
Figure conductive electrolyte shorting tip to case (reflector down, so it all pools by the driver), may’ve shorted the cell even more. Kinda like a half-puke making you gag from the taste’n‘smell of the puke to make you full-on puke even more.
skinny_tie
skinny_tie's picture
Last seen: 5 hours 8 min ago
I once used a 16340 light with a magnetic tail-cap while I was assembling a new gas oven, then left it inside during the oven’s first use. It was baked at 200℃ for around an hour. The cell leaked but there was no boom and the flashlight was fine.
Robin Dobbie
Last seen: 1 hour 45 min ago
200c or almost 400f and the rest of the light was still functional? That’s amazing.
d_t_a
Last seen: 1 hour 31 min ago
I’m interested to know what flashlight is that? Smile
Notmyrealname
Last seen: 29 min 34 sec ago
Are you sure your cat didn’t just piss on it and it shorted?
I feel sorry for people who don't have a hobby or interest to escape to.
pennzy
pennzy's picture
Last seen: 3 hours 41 min ago
I had a 16340 leak also without a kaboom. The light was never the same.
zoulas
zoulas's picture
Last seen: 6 hours 24 min ago
The only battery I had that leaked was a Nitecore. When I brought it to their attention, they did not seem interested in the least.
ggf31416
Last seen: 3 hours 38 min ago
pennzy
pennzy's picture
Here kitty kitty. Bad kitty.
kennybobby
kennybobby's picture
Last seen: 1 hour 52 min ago
On first read i thought it had split the case, and i was gonna ask about what the innards looked like and how it was constructed, e.g. jelly roll around a mandrel or flat layers of a rectangular pack, etc.
but then i see that it was only the wrapper split, so the leakage was out the vent under the cap. Seems strange that it got so hot and over pressurized enough to vent during a total discharge. i wonder if there is a datasheet available for that cell to look at the chemistry.
The big Kaboom with fire usually occurs during a charging session after a deep over-discharge event, but sounds like you had a close-call and were lucky.
Now i used to think that i was cool,
drivin' around on fossil fuel,
until i saw what i was doin',
was drivin' down the road to ruin. --JT
Dirty Water Guy
Dirty Water Guy's picture
Last seen: 3 hours 8 min ago
This was a good post for me as it acted as a reminder to have some serious respect for Lithium Ion batteries. I was going to suggest the alkaline battery cleanup with vinegar, but of course LiIon batts don’t leak a strong base like alkaline leakers thus your soap/water cleanup makes sense.
I found a few good links re: LiIon battery hazards and cleanup. I had one go south as in take off like a smoky rocket across my workshop one when trying to extract a 18650 batt from a vape pen, batt shorted I guess, scary shit.
https://www.large.net/news/8eu43mp.html
https://www.newpig.com/expertadvice/how-to-care-for-defective-lithium-io...
I think taking batts out of non-rotation lights is sensible. This thinking makes lights with non-removable batts less appealing to me now.
bushmaster
bushmaster's picture
Last seen: 1 hour 48 min ago
Are most or all non-removable li-ion batteries protected cells? Might be a stupid question but I actually don’t know.
Keep your nose in the wind and your eyes along the skyline.
Del Gue
Oli
Last seen: 5 hours 19 min ago
They don’t really go boom. They can spit a little fire if the can gets penetrated in some way. One little tiny cell in a flashlight isn’t going to be able to spit much fire. I think being in the flashlight is probably the safest place to keep them unless it’s a light with multiple cells. I would retrieve that from the trash and take it outside and look for dents in either end. Does that light have springs in both ends? It’s probably related to the fall in some way but was it a battery issue or did the flashlight do something to cause a quick short high drain?
Lightbringer
Nope, it’s thoroughly waterproof, even from the inside. LOL
Seriously, battery tube from head was a chore to unscrew, so drizzled detergent down the hole and completely drownded it in hot water coming full blast from the faucet. Once I did unscrew it into 3 pieces, I was able to completely clean out everything.
No condensation under the glass, not a hint of fogging, nuttin’.
Dropped in a LFP cell (had it handy), and it still worked fine.
Lightbringer
I had a pair of ’123s go all China Syndrome in my MH20 for some reason. Both wraps were split and crinkled, both cells down to almost 0V, but no leakage. Nfi how that happened.
Still chugging along, thankfully.
sarge12
Last seen: 4 min 14 sec ago
No, all li-ion are not protected, in fact none are from the factory to the best of my knowledge. The protection circuits are added post production and re-wrapped. All have intentional weak spots to reduce the violence of venting from the factory, so actual explosion is not what they do. normally. IMR, and INR chemistries are less volatile than the ICR that was used previously. Usually a battery venting might have fire but not an explosion. Inside a light there is less oxygen, so I am not surprised a tiny 14500 did not have flames. Had the same happened in a light containing 4×18650 cells it might be different. Had this been an ICR battery, it might have been the kaboom you speak of, but the stored energy of a 14500 is not going to be enough to be an extremely impressive kaboom. The fact that the cell vented without flames at all is fortunate even with IMR, and INR. You can easily see on the internet, videos of controlled intentional ventings by doing insane things like dead shorts or hitting them with hammers, with sometimes less than impressive results. That being said, even the INR and IMR can if venting cause flames. It can, if depleted too far, cause venting and flames if attempting to recharge. That is why most chargers, will refuse to recharge batteries that are too low in voltage. Some expensive re-chargers have special re-charge teqniques to recharge very depleted cells, but I would not risk it. I have had a house fire before, so I tend to take li-ion batteries and their potential dangers very serious, and do not push the envelope with their use. If a battery is too depleted to accept normal charging, I toss it. I do store some batteries in single cell devices with the tailcap loosened, but most I store in plastic boxes. None are stored long term in multicell devices. It is not that hard to remove them and put them in 2 cell plastic boxes for their storage. I have never seen or heard of a battery self depleting, and then venting due to low charge, and better li-ion batteries can hold their chages for years in storage…self depleting very slowly. Most violent venting events are due to the batteries mis-use or as in videos, intentional acts.
Lightbringer
A lotta people have lights all over the place with cells in ‘em: in drawers, in the garage, in the basement, scattered all over the place like they’re old plastic D-cells-and-hotwire-bulb flashlights, and if you forget the check on ‘em, or forget about them completely, that’s exactly what can happen to them. Best case, the cells take a dump and ruin the light, but worse case?
I only keep cells in a haldful of lights, that those that are in daily use, and only a (very) few that go in’n‘out of rotation. All of the latter, though, are tailcap-locked-out.
Lightbringer
Long gone, no visible damage to the cell except for the split wrap and of course its spilled innards.
Au-coated spring on the tailcap and just a flat nubbin on the driver board.
(click me!)
shows the driver and profile of the tailcap.
Didn’t fall more’n like 8” and roll another 1’ or so the rest of the way.
goshdogit
goshdogit's picture
Last seen: 16 min 31 sec ago
sarge12
My previous post missed the non-removable from your post, and I suspect that non-removable battery devices have protection circuits.
pennzy
pennzy's picture
Had Tenergy 9v. NiMH melt inside a device last week. It was not the device’s fault. Put a new one in and works fine. What would cause it to melt is beyond me.
NeutralFan
NeutralFan's picture
Last seen: 1 day 1 hour ago
How old was the 14500 battery and where did you get it from? Seems strange that a small drop would cause the battery to leak. And when was the last time it was charged?
Glad it didn’t ruin your GT Micro (and perhaps your cat saved it)!
I’d rather use my flashlight around the house than turn on the lights.
Lightbringer
First shots fired in the War With The Machines?
Lightbringer
EBL 14500s, April 2018 (looked it up), Amazon.
Can’t say it was a drop, as he knocks things over all the time. Either swinging his tail around, or rubbing his face on things. Nothing to purposely knock things over like you see some cats do.
Don’t recall when it was last charged. Blinked out 3.6V a few days before, which is about when I’d top it off When I’d Get Around To It.
I’m hoping so. I always keep ‘em facing me (lit sideswitch) so I can see where they are in the dark, and it was fine one day, dark the next.
pennzy
pennzy's picture
At least no kitties were hurt. When I was a kid, we had a cat that burned his lips off biting a lamp cord.
NeutralFan
Maybe it was a bad battery? I’ve read that it’s risky to buy Li-ion batteries on Amazon and eBay.
Dirty Water Guy
Holy $hit, EXACT same thing happened to Max (13 YO and still with the living) Saw the idiot chewing an extension cord and it shorted in his mouth. Damn cat must’ve jumped 4 ft in the air. Not sure if his lips were burnt because I didn’t check. Hasn’t happened since…Stupid Max
Lightbringer
Don’t think so, as I got a few “in service”, and they’re fine. All came pretty close to stated capacity.
Did get 1 dud out of 16 (2 orders × 8 cells), grexed, and their CS sent a whole new 8pak!
They seemed to be pretty good, all in all.
pennzy
pennzy's picture
There is no mistaken it. All you saw were teeth looking at him. My memory is getting bad. It wasn’t my cat but someone I knew. Either way, curiosity almost killed the cat.
