During my search for suitable chemicals to create a safe bleaching mixture, i found a site selling Sodium Tetraborate aka Borax.
Wow! i wonder how many packets they sell at that price? The 20-mule team strength of Borax is legendary, and wally world sells a 4 lb box for about $4.
The Oxi-bleach type mixtures seem to use Sodium Percarbonate powder, which when mixed with water releases Hydrogen Peroxide and Sodium Carbonate (aka Soda Ash).
Borax is also supposed to release Hydrogen Peroxide but i haven’t seen much of a reaction in my testing. Maybe the powder loses strength after you open the box.
i’ve tried soda ash by itself, and 3% peroxide by itself, and then mixed the two together. None are magic potions that you can just spray and play; the mixture works best, but still requires mechanical agitation, i.e. elbow grease, to really get rid of built up grime, mildew, algae, etc.
This procedure seemed to work fairly well:
- Scrap off loose and excess debris first
- Dampen the surface with water
- Spray the surface with mixture
- Scrub with brush to work mixture in and push debris loose
- Rinse with clean water
- Repeat 3-5 for heavy stains
[edit]
i tried it on an outdoor stairway made of pressure-treated lumber and the wood came out looking very fresh almost like new after it dried. But it took a lot of scrubbing and several cycles of 3-5, so very time consuming and lots of elbow grease.
i wasn’t expecting it and didn’t get any “before” pictures to compare, but quite dramatic results.
i’ve got some algae covered fence boards that i will test with some other solutions, such as chlorine bleach.
Wet n Forget: spray it on and gets rid of green algae in 1-2 weeks
Active Ingredient: Alkyl dimethylbenzylammonium chloride 9.9%
