I recently received fw1a and i used last night. And i realised a problem. it seemed to be under performed. i feel like fw3a had more throw. (i was correct)
So when i came home i did quick measurement. lumen seems fine like ~1300lm (turn on)
but when i measured throw its 15 kcd (i wish i could add photos here)
Then im so confused. i suspect op reflector is doing something and i swap gt nano’s smo reflector. throw incresed to 23kdc.
Factory specification is 40kcd. (im less than half)
What i have to do im so confused. should i try convoy s2 reflector? or something else? or contact with lumintop?
Does your FW1A use a large hole reflector with a big gasket? I’ve heard that the initial run used properly shaped reflectors, but for the FW1A Pro a different dual purpose reflector was designed for xhp50.2 compatibility. The new reflector replaced the old, and suffered in performance compared to the old one, but I suppose Lumintop didn’t want to mfg and stock 2 types of similar reflectors.
